New Hot Bodies Buggy!!???????
Does anyone know if there is a 32mm flywheel that works with the stock clutch parts? I have a 3mm chassis and currently run the motor mounts upside down but would prefer to just use a smaller flywhweel. Also on this topic, which bell can I use besides the stock one? There is a Mugen/Ofna style and a Kyosho style. Whats the difference?
On another note is it standard practice to fill the diffs with fluid or only to the top of the spiders as the instructions show?
Clutch trim pic here
It will make it hit harder for more power out of the corners.
It is cut already and the spring doesn't go through the contact area underneath. So the shoe will wear all the way down without having to worry it's spring being scrubbed by the clutch bell.
You don't have to put washer to install them 'coz the shoe already have it built-in.
And it really hit harder out of the corner
Does anyone else have trimmed button head screws on their center diff? Is it rubbing the brake cam?? Every time I change my diff fluid I have to dremel them to get them off. If there a quick fix to this or would picking up the lightweight cams solve the problem? The lightweight cams look a bit different than the stock. The stock work just fine for me besides killing 100 button head screws a season.
Lightweight brake cams is the best solution.
Brake cams...dremel the rear brake cam edge so it doesn't hit the button head screws when at full throttle. Make sure you dremel the 'inactive' edge and not the edge that acts against the brake pads.
I havent had any problems with mine hitting on the screws in my d8 or ve8.
Not sure whihc clutch you are running, but I am using the Answer Flywheel, 34mm, with no clearance or interference issues. I have the motor mounts mounted correctly also.. Stock Clutch parts will work with answer flywheel, but the answer stuff is just as cheap, and a bit nicer, IMO..
Okay great. Thanks for the tips! I'll dremel the cam until i pick up the lw cams. After I took a closer look at the cam I could actually see where it was hitting the screws. Is there a certain amount I should take off or does it not matter.
That actually wouldn't get caught up enough to make the car feel like it was glitching would it? Ive been having a throttle glitch lately and Ive been going crazy trying to track it down.
Thanks again!
Thanks again!
well the D8 army is starting to form locally...2 more guys are making the switch over after seeing/driving my car comparred to their own...actully let one of them run my car for a qual. today and ONLY running my car for the 3 mins of warm up and the 6 min qual he was throwing down faster more consitant lap times over his losi 2.0 that he has had for over a year...way to go HOT BODIES!!
answer rc 32mm flywheel works
I like Kyosho 32mm flywheel as it protects front bearing from dirt, but it needs kyosho style bell
Where are you guys finding the revised servo saver for d8. The one with the large nut.
There are 790 pages to this thread and although I'm sure the answer is here somewhere I thought I'd ask, what items are needed in addition to the kit? I see the WCE front shafts mentioned as to the chance of them popping out of the cups but I also see optional long shocks and shocktowers? Just trying to get a list together before ordering at amain, recently switched to the d8t and I'm very pleased...Thanks
If you are with the D8T hop over to this thread.
http://www.rctech.net/forum/nitro-of...d8-truggy.html
All I have on my D8T are the ACE towers and extended mounts, Kingheadz Servo Saver Arm and top plate. Towers for longevity, motor mount because he has them, servo saver arm to reduce flexing along with the top plate. The Kingheadz stuff was just within the last 2wks to see if they help. Good truggy and hopefully you do good with it too!!!
Perhaps I wasn't clear, I switched to the D8t about a month ago and am pleased with the move, I am now getting ready to order the buggy and wanted to know the items needed such as the wce driveshafts etc...
Get the hot bodies aluminum servo horns. Thats it imo.
