Old 05-01-2008, 05:24 AM   #1
LogiK's Avatar
Trader Rating: 11 (92%+)
Default Tyre Glueing
Hi,
Just wondering if once a tire starts peeling off the rim what is the best method of cleaning them and re-gluing them?
What about brakes parts cleaner on the bit of the tire exposed (dirty) and cleaning well and re-gluing?
LogiK is offline   Reply With Quote
Old 05-01-2008, 05:44 AM   #2
best way would be to use some fine sand paper or dremel with wire wheel to clean the rim bead where you need to do the repairs. Then clean that spot on rim as well as the tire with either rubbing alcohol or thinners. then use a couple small drops of CA glue and place a rubber band around the wheels to apply pressure to the tire or just hold them tight.
Proline make a good glue you should be able to get from your LHS.
also here is a fitment guide which may help...
http://http://www.prolineracing.com/...emounting.aspx
pracy is offline   Reply With Quote
Old 05-02-2008, 12:56 AM   #3
LogiK's Avatar
Anyone else? Im more so talking about the whole glue doesnt stick to dirt thing, whats the best way to clean dirt off the surrounding area.
Old 05-02-2008, 06:33 AM   #4
UN4RACING's Avatar
Trader Rating: 22 (100%+)
I use motor spray. Some real fine sand paper to scuff the area and a tooth brush with some motor spray to clean it, wipe with towel and glue. Scuffing it up is the most important thing to do. And be sure to put a rubber band around it to keep it tight to the rim or you will get a big gap that will just come unglued again.
UN4RACING is offline   Reply With Quote
Hudy Auto Tyre Truer and Trinity Tyre Warmers Rody Australia For Sale/Trade 4 04-18-2007 08:35 PM
glueing graphite? streetracer745 Electric On-Road 7 11-07-2006 11:57 AM
Glueing Tires Bigmaxy Rookie Zone 3 08-25-2006 12:59 PM
Glueing Tires RoadRat Electric On-Road 9 07-23-2003 10:38 PM
Glueing tires on wheels.....Help!! GKHTC3 Electric On-Road 6 11-15-2002 09:52 AM
