Old 04-29-2008, 04:33 PM   #1
buckeye34's Avatar
Default BEST WAY TO CHANGE FRONT BEARING
what is the best way? ordered new tko ceramic for my v-spec (already has ceramic rear)......
mbx5r
v-spec
jp-3 pipe
hitec 5955tg/steering
ko propo 2367/throttle
m-11
buckeye34 is offline   Reply With Quote
Old 04-29-2008, 05:33 PM   #2
jaylude22's Avatar
Trader Rating: 93 (99%+)
Use this tool: http://www.amainhobbies.com/product_...oducts_id/3528
jaylude22 is offline   Reply With Quote
Old 04-29-2008, 05:48 PM   #3
1)do complete disassembly of engine and clean case
2)throw new bearing in freezer
3)heat case on a hotplate with the front bearing down
4)lightly tap out front bearing with brass punch
5)lightly tap in new bearing
6)lube up engine parts with after run oil and reinstall
blowpopracer is offline   Reply With Quote
Old 04-29-2008, 11:43 PM   #4
THE BEST TOOL FOR REMOVING FRONT BEARING IS JP RACING #93862(http://www.jpracing.com/en/products/...essories/).FOR REMOVING THE REAR AND PUT A NEW ONE(FRONT OR REAR) THE BEST ARE FROM RB 01150(MOUNTING) AND 01400(BEARING EXTRACTOR)(http://www.rbproducts.com/mainEn.php...ille=DIV&go=go
).OF COURSE ALL THESE ARE A LITTLE EXPENSIVE BUT YOU WON'T DAMAGE YOUR ENGINE.YOU MUST HEAT UP THE ENGINE AND WITH THESE TOOLS.IT IS BETTER
deeph is offline   Reply With Quote
HELP!!! How to Change the rear bearing in my novak brushless motor rcracerjunky Electric Off-Road 3 05-16-2011 11:03 AM
Change engine bearing! jameslow Onroad Nitro Engine Zone 5 06-17-2008 08:52 AM
Quickest way to change out front belt. Loveless Nitro On-Road 7 09-19-2007 07:50 PM
Bearing change alltech Rookie Zone 3 04-18-2005 05:17 PM
How to change the engine bearing? dino.tw Onroad Nitro Engine Zone 5 12-24-2003 06:54 PM
