Old 04-29-2008, 10:39 AM   #1
Tree's Avatar
Send a message via ICQ to Tree
Default Nitro Engine Tuning Dials.
Check out these dials that go on the the HSN.
http://rchardware.com/
Team Holy Rollers
HiTec Servos
"N-Tune" Nitro Engine Tuning Dials
Tree is offline   Reply With Quote
Old 04-29-2008, 10:49 AM   #2
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
looks like a pretty decent idea, little pricey i think but still. wonder what the difference in the "race" and "sport" ones are. and if they didnt loosen up on you and rotate due to vibration. my motor wasnt listed of course.
MONKEY BUSINESS RACING
Flinging poo at a track near you! Winning hearts and minds everywhere!
www.graphicmonkeydesigns.com
Brooksphotodesign.net
Flying Monkey is offline   Reply With Quote
Old 04-29-2008, 10:52 AM   #3
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
I'm still waiting for the fake "Blow Off Valve" that goes "psssshhhht" when you let off the throttle.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 04-29-2008, 10:56 AM   #4
Tree's Avatar
My engine wasn't listed either but I took the measurements of the HSN housing and I found the right one. It fits like a glove.
It doesn't come loose and I didn't havr to lock-tite it.
The race dial has a positive and negative marker on each side of zero so you can clearly see if you are on the rich side or lean side of your zero. The sport dial goes from 0 to nine clockwise.
I personally like the race dials.
This really helps when having to return to (zero) or factory settings. No need to count turns anymore.
Team Holy Rollers
HiTec Servos
Old 04-29-2008, 11:17 AM   #5
very cool. i may pick 1 up just to have it. least if someone is helping you at the track you can tell them "clockwise 1 tick" if they dont know much about the motors and not have to worry about them going too far or not enough without you havign to come off the drivers stand.
Old 04-29-2008, 12:32 PM   #6
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Another fella on another site commented this about these and I thought this would be the only reason I would want one of these dials.
Posted by: cooterstow
I think these are cool, they would work, like on race day and it is 80 Degrees out side you could tune it and chart it and next time at a race with the same temp you would have a good starting point and would not have a chance of burning up your motor.
UN4RACING is offline   Reply With Quote
Old 04-29-2008, 12:47 PM   #7
Tree's Avatar
On the R/C Harware website they have a link to a tuning and tracking sheet. You cant track and monitor your exact settings and and see if you have a performance gain with different dial settings, plugs, fuel, etc.
http://rchardware.com/ntunesetupsheet.html
Team Holy Rollers
HiTec Servos
Old 04-29-2008, 04:59 PM   #8
Tree's Avatar
Flying Monkey
The difference between the "Sport" and "Race" Dials are:
"SPORT" After a base tune is dialed, loosen the set screw and
Rotate the Dial until the HSN Reference Point aligns with "3"
Snug the set screw.
When making tuning adjustments, the tuning direction is easy to remember. The higher the number = more fuel (rich) and the lower the number = less fuel (lean). This "starting point" is only an average from engine to engine. Ideally the tuning distance to
"0" is for leaning out the engine to produce maximum power. Turning the HSN all the way to "0" is set to be the upper limit for engine performance and temperature.
Use the tuning dial to record and track HSN settings.
__________________________________________________ ____________________
"RACE" After a racing or base tune is dialed, loosen the set screw and Rotate the Dial until the HSN Reference Point aligns with "0"
Snug the set screw.
As running conditions change, controlling engine temps and performance with exact needle adjustments are more manageable. Use the +/- signs for decisive adjustments for a rich or lean fuel mixture.
Use the tuning dial to record and track needle settings.
Team Holy Rollers
HiTec Servos
Old 04-29-2008, 06:18 PM   #9
cool. thanks for that info.
Old 04-30-2008, 08:50 AM   #10
Send a message via AIM to slawhammer Send a message via MSN to slawhammer Send a message via Yahoo to slawhammer
Default Tuning Dial
Yes ..This tuning Dial works great I have used it for the past 6 months..
Very easy to get dialed in ..The ref sheet you make will help for different conditions with day or evening temps and humidity and makes easy too get dialed in..It is will worth the money spent...
Just my 2 cents worth...
slawhammer is offline   Reply With Quote
Old 04-30-2008, 09:10 AM   #11
Tree's Avatar
I agree with Slawhammer, The tuning dials are great. Well worth the money. You may know your needle settings but your pit person doesn't. These dials will make it easier for your pit person to make adjustment during a race.
The way I use them is I put them on the HSN with the Factory needle setting during break-in. If I have any issues during the break-in process and I need to go back to factory settings it is much easier to line the HSN screw with zero instead of counting turns.
Once I have the engine broken-in with a slightly rich race tune, I loosen up the Tuning Dial and line up the HSN screw with zero. As temperature and/or race conditions change you or your pit person can make precise adjustments.
It is so much easier to monitor settings and track engine performance with these dials. In my opinion, I feel it is definately worth the money.
Team Holy Rollers
HiTec Servos
Old 04-30-2008, 09:36 AM   #12
salteen's Avatar
Trader Rating: 90 (98%+)
Oh I want that!!
salteen is offline   Reply With Quote
Old 04-30-2008, 11:35 AM   #13
RBMike's Avatar
That would be funny.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 04-30-2008, 09:05 PM   #14
Tree's Avatar
I just think this is a pretty cool product. It is good for the newbie and the racer. If anybody does decide to purchase one of these please let us know what you think of them.
I recived an e-mail from Mark the owner of R/C Hardware, and he said if your engine is not listed to contact him via e-mail so he can update his engine list on his web page. He said he will give those who help him update his list a deal on the tuning dials.
Team Holy Rollers
HiTec Servos
Old 04-30-2008, 11:52 PM   #15
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Nice idea, but not needed. Does it really make a difference how many hours you turn the needles? If really depends on what the engine is in need of, not a specific turn on the needles. Every engine will need different settings to get them perfect, close, but almost never identical.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
nitro .21 engine tuning help? downunder23 Rookie Zone 14 05-16-2013 08:52 PM
Re-Tuning a New Nitro SH.18 On-Road Engine - Help paul73rc Onroad Nitro Engine Zone 0 01-07-2008 11:23 PM
Nitro Engine Tuning 101 x 4 mad-dog Onroad Nitro Engine Zone 0 08-27-2007 07:48 AM
Nitro engine tuning atr4tigers Nitro On-Road 2 06-24-2006 09:07 PM
Reset Nitro Engine for Tuning ..How? e420x Electric Off-Road 0 08-09-2004 10:34 AM
