Old 04-28-2008, 08:46 PM   #16
Nik
Nik's Avatar
I have not had any problems using simple green, but I do not use it at full strength. About 50/50 simple green/water.
Denatured alcohol dries out plastics so it is wise to coat plastics with WD40 afterwards. I do not like D. alcohol.
I pull out the engine, radio tray, and fuel tank. Then its simple green + brush > hose > air compressor > WD40 > air compressor.
For the engine, clean it with a stiff brush. Plug the exhaust, carb, and fuel nipple (leave the plug in) > compressed air.
Radio tray and fuel tank.. I clean with a rag and a little bit of simple green.
Nik is offline   Reply With Quote
Old 04-28-2008, 09:17 PM   #17
Turbine_au's Avatar
I take the big pieces off whole (tank, engine, front suspension etc.) spray them with WD40 then wipe clean with a rag. Never had a problem. Just take the radio tray off seperately and brush clean.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 04-28-2008, 10:06 PM   #18
Trader Rating: 22 (100%+)
Ya, I clean my car with Nik's air compressor + WD40 on race days
thanks Nik
phixd is offline   Reply With Quote
Old 04-29-2008, 04:44 AM   #19
buckeye34's Avatar
just be careful not to get the wd40 on your brakes...i got a little on mine and it took a while for it to wear off enough to have solid brakes again...
mbx5r
v-spec
jp-3 pipe
hitec 5955tg/steering
ko propo 2367/throttle
m-11
buckeye34 is offline   Reply With Quote
Old 04-29-2008, 07:21 AM   #20
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
We use simple green + blow off with compressor, then denatured alcohol to de-slime + blow off again. WD40 on the "moving parts" like hinge pins, bearings, steering balls, etc.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 04-29-2008, 07:32 AM   #21
Default Simple Green
Looks like the majority suggest Simple Green to use first. I have never bought Simple Green. Does it come as a concentrated liquid and then you mix it? Then you let it set for a while, and then air it off? Am I still correct so far? And then last, spray truck down with WD-40 and wipe off for that "look like new" shine? Are my steps correct? Thanks guys. P.S.----Brake parts cleaner, is that basicly a no-no, not really necessary?
BChiz is offline   Reply With Quote
Old 04-29-2008, 06:00 PM   #22
houston's Avatar
Trader Rating: 91 (100%+)
go to neo buggy and ask truhe how he cleans his cars .
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 04-29-2008, 07:04 PM   #23
HEAT's Avatar
Trader Rating: 26 (100%+)
I pull out all of the electronics and the motor then clean the motor with simple green and then spray the whole car down with simple green , scrub it then blow it off with an air compressor then spray it dowen with WD and let it seat over night . Your buggy/truggy will look brand new .
HEAT is offline   Reply With Quote
Old 04-29-2008, 08:51 PM   #24
Vsfriedmugan's Avatar
Send a message via MSN to Vsfriedmugan
its simple and its green!
MBX6>>FUTABA>BYRON FUEL>O.S>ProTek>HITEC
and a mask to inhale nitro fumes
Vsfriedmugan is offline   Reply With Quote
Old 04-29-2008, 09:26 PM   #25
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
everyone use simple green i see i also use Grease Lightning and Orange cleaner ......if that not around some good ole ajax dish liquid soap do the trick
bobbyblaze is offline   Reply With Quote
Old 04-29-2008, 10:35 PM   #26
oldguyzrule's Avatar
Trader Rating: 74 (100%+)
Default no waaaaayyy!!
Originally Posted by houston View Post
denatured alcohol / air compressor / lemon pledge !!! dirt comes off super easy the choice of the pros
Aww, c'mon Houston why should we do it like the top drivers in the world.
Just does'nt make sense. +1 for denatured and pledge!!!
oldguyzrule is offline   Reply With Quote
Old 04-29-2008, 10:44 PM   #27
You guys are putting way to much work into it.
Remove engine, pipe and radio tray. Put car in dishwasher (topshelf if possible), add a capfull of soap and come back in an hour.
The car will look like new.
largeorangefont is offline   Reply With Quote
Old 04-29-2008, 10:45 PM   #28
Registered User
Dont use WD40....
WD40 makes rubber go hard and shrink, its ok to clean metal parts but not anywhere near rubber, like bearing seals.
Loop&Roll is offline   Reply With Quote
Old 04-30-2008, 10:31 AM   #29
bobbyblaze's Avatar
Old 04-30-2008, 10:52 AM   #30
jgtruggy's Avatar
Hey OLDGUY,
Jason here, what's the pledge do? Will it shine up the plastic?
Losi SCTE
Tekin RX8/Tekin Pro-4 4000kv
Topgearhobbies.com
jgtruggy is offline   Reply With Quote
Best way to clean/keep clean your RC's z28mccrory Rookie Zone 19 01-06-2008 01:35 PM
clean out bootheman Australia For Sale/Trade 6 01-04-2008 05:19 PM
XB8 with .21 OS VZB JP-1 CLEAN!! FastEddy R/C Items: For Sale/Trade 4 02-13-2007 12:51 PM
What do you use to clean Totalfixation Electric On-Road 5 01-13-2005 11:29 AM
WTB:Clean LRP V7.1's TexRacer R/C Items: Wanted to Buy 0 12-16-2003 08:31 AM
