Old 04-27-2008, 03:56 AM   #1
Default New Mugen MBX5R engine selection help please
Hello all,
I am about to order a Mugen MBX5R and I am having trouble deciding what engine is best suited. I will be racing a good technical track so I need some low down power but am just looking for a good reliable engine over-all.
I am mostly looking at Novarossi Engines..
Can you guys give me your opinions on what engine I should get please?
Also do these engines come with flywheel, cluth bell etc or do I have to purchase these too?
Purchasing the Mugen Kit, Engine and already have electrics (Futaba 3PM, Hitec Servo's)
What else would I need to purchase to complete the buggy? etc flywheel..
thankyou all!
pracy is offline   Reply With Quote
Old 04-27-2008, 04:06 AM   #2
GenReaper's Avatar
Send a message via MSN to GenReaper
REQUIRES: Radio: 2-Channel with 2 Servos, high torque servo recommended for
steering
Receiver Battery: 6V
Radio Batteries: 8 AA size
Engine: .21 cu in (3.4cc) rear exhaust
Exhaust System: Muffler, manifold, and manifold spring
Starting Equipment
Paint: Polycarbonate for body
I have one also, and race a technical track, either an Go Tech 5 port with 056 pipe or a O.S V-spec is good maybe even a NR P5.
I run an OS donk tho its modified and it goes well even on our rough track, plenty of bottom end power and cheap too, could buy two for the price of one NR :]
Video of my beast.
http://www.zone3adelaide.com/rcmovie...actice2008.wmv
http://www.youtube.com/watch?v=ashwJMaIavs
Trex 700E 12S Scorpion 4035 560kv
Trex 600E
HPI Baja 5B SS
My videos : http://www.youtube.com/profile?user=genreaper
GenReaper is offline   Reply With Quote
Old 04-27-2008, 04:36 AM   #3
cheers for your reply, where did you find the required parts list?
as for engines...
O.S. Max 21VZ-B V-Spec-T (P) Off-Road Competition Buggy Engine $299
is the cheapest V-Spec I could find on Amain and..
Novarossi Plus 21-5KT Off-Road 5 port Competition Buggy Engine (Turbo Plug)
$344.99
So for the difference I think I would still go nova...
Old 04-27-2008, 04:41 AM   #4
lowey79's Avatar
If bottom end punch is what you want, then you cant go past the AXE X1 Cobra or RB C6 BB.... both have a crazy bottom end and a strong top end!
lowey79 is offline   Reply With Quote
Old 04-27-2008, 04:46 AM   #5
GenReaper's Avatar
http://www.ocrpitshop.com.au/index.p...d&productId=38
I bought my OS from Australia in Perth for about $275AU , $304AU delivery across the country.
Go Tech 5 port is just as good IMO.
Axe have a longer stroke and dont rev as hard IMO.
PS: may be too much power and also hard on clutch setup for some one new.
http://www.amainhobbies.com/product_...oducts_id/2939 was the Nova motor i was on about, tho the one you listed has balls too.
Trex 600E
HPI Baja 5B SS
Old 04-27-2008, 05:45 AM   #6
Vigilante212's Avatar
steering
Starting Equipment
Video of my beast.
+1 But I would use an 086 pipe on it instead.
Mod 13.5 Associated B5M Lite
Stock 17.5 Associated B5M
Vigilante212 is offline   Reply With Quote
Old 04-27-2008, 06:13 AM   #7
TonysScrews's Avatar
Originally Posted by pracy View Post
Hello all,
thankyou all!
The 5R kit comes with the short old MBX5 shock springs. I would get the new updated 5R/5T springs (Part # E0529 and E0532). Then for the brakes use only the metal calipers and buy the Thunder Tiger option brake discs (Part # PD1861 I believe). The 5R comes with a flywheel and clutch set up so you're good to go there. Other than that, the only thing I would get is some Mugen shock and diff oils (350Wt & 400Wt shock oil. 2K, 3K, 5K, 7K and 10K diff oil is all you'll need).
Best of luck,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 04-27-2008, 11:44 AM   #8
Hey Tony
Do those new longer springs make a big difference? If so I'll order a set too.
THANKS!
topcat-lll is offline   Reply With Quote
Old 04-27-2008, 12:10 PM   #9
Vsfriedmugan's Avatar
Send a message via MSN to Vsfriedmugan
sneaky.s. speed with a 2035 ttr pipe. dynamite alum. shoes and 13t mugen clutch bell works very well
MBX6>>FUTABA>BYRON FUEL>O.S>ProTek>HITEC
and a mask to inhale nitro fumes
Vsfriedmugan is offline   Reply With Quote
Old 04-27-2008, 03:08 PM   #10
slow coach's Avatar
os v-spec or new ninja by os
Kyosho MP9TKI2 soon to be TKI3, Novarossi, SMD, GM Racing, www.grccc.org
a great wife and lovely kids
what more can you ask for
a win on the lottery :D
slow coach is offline   Reply With Quote
Old 04-27-2008, 03:34 PM   #11
I love my falcon .21 awesome power and super reliable. Its kind of like the old ninja(pre os) with a different crank. I have seen my share of go techs and v specs and it seems like all of those have to get replaced far too often for me. Thats why I wont buy a go tech or a os product cause they just dont seem to last as long as the others. The os products do seem to have tons of power and do hold a tune well but they just dont seem to last for the long haul.
I would recommend the falcon engine line but you also cant go wrong with a nova rossi or a rb product.
blowpopracer is offline   Reply With Quote
Old 04-27-2008, 05:12 PM   #12
Pracy,
So you decided to get a Mugen MB5R, good choice mate, great buggy, other advantages are if you break parts and don't have any spares on the day, just buy them from Aston.
If going to buy a MBX5R might as well purchase a OS speed..
Jesussaves is offline   Reply With Quote
Old 04-27-2008, 05:30 PM   #13
MadRussian's Avatar
GRP !!!
MadRussian is offline   Reply With Quote
Old 04-27-2008, 07:11 PM   #14
tony montana's Avatar
Trader Rating: 65 (100%+)
if you want reliablity and power, go with an rb. I have run lots of different engines and I just got a rb s7 l2g engine and so far it is by far the best I have owned. Vspec is good but I had alot of issues with mine
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 04-27-2008, 10:30 PM   #15
nova 3 port bf 21 is a good engine
Mugen MBX5R - retireded Passion
22 3.0 SR Hobbywing 3.1 Stock Spec Trinity 17.5 24k Reilley Motorsports
B6 Hobbywing 3.1 Stock Spec Fantom
22 SCT 2.0 Exotek Hobbywing 3.1 Stock Spec Fantom
Tekno 410SCT Hobbywing ProSC
mugenlife is offline   Reply With Quote
Mugen MBX5R buggy, Novarossi engine and more Starter box R/C Items: For Sale/Trade 9 07-09-2008 12:40 PM
Engine selection help needed!! ASAP Strosek Nitro Off-Road 11 06-21-2008 10:27 PM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
Mugen MBX5R, Ninja Engine, Hitec 5955 Servo Breakin2 R/C Items: For Sale/Trade 18 02-28-2007 04:02 PM
