Old 04-27-2008, 08:01 AM   #16
Maximo's Avatar
Originally Posted by BSchorr View Post
PUT IT BACK IN AND RUN IT!!!!
I agree as well, but be sure to add a few drops of ARO first, it will help restore the lost compression !
Maximo is offline   Reply With Quote
Old 04-27-2008, 08:20 AM   #17
Obviously something went through the motor. Lets see a pic of the top of the pistion. It will need a new piston and sleeve at least.
largeorangefont is offline   Reply With Quote
Old 04-27-2008, 10:45 AM   #18
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Get a new motor, simple as that.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 04-27-2008, 11:06 AM   #19
I'm not sure what did this.
The wrist pin clips are still in place, haven't broke any plug coils.
There was no left over debris from whatever it was.
The filter was ripped off in a crash once, something could have possibly got in. That was a while ago though, maybe it took some time to manifest.
The damage to the bushing on the Rod, is from pliers. I got it stuck in the sleeve and had to pull it out.
So, I'll need a new Rod too, because of the bushing?
The crank shaft looks fine. I haven't taken it out of the block, but it spins fine with the flywheel.
The rear bearing also, looks good.
So, I should take the crank out and check it still? Is there anything else I should do before getting a new P/S/R?
A new P/S/R would be about $60. It's an HPI G3.0 and the damage happened on the rear side of the engine.
Here's the top of the Piston. There are some really small marks on it and the head button.
Woof is offline   Reply With Quote
Old 04-27-2008, 02:13 PM   #20
ezveedub's Avatar
From the looks of the piston top, that engine was detonated and/or sucked in dirt.
Old 04-28-2008, 12:26 PM   #21
So, I gave the engine one last look over and I'm pretty sure it only needs a new Piston, Cylinder and Rod.
I have a question.
The Head Button has some very small marks on it from what ever was in the engine.
I don't need to replace that too do I?
The head button shouldn't be contacting anything, so the little marks should be ok?
I can't believe this little head button cost $14.
Old 04-28-2008, 01:26 PM   #22
R40Victim's Avatar
If I were you, I'd just replace it. That engine prolly isn't worth rebuilding, unless you are on a Super Tight Budget.
R40Victim is offline   Reply With Quote
Old 04-28-2008, 04:37 PM   #23
Why isn't it worth rebuilding?
The new parts would be $60 or New engine $100.
I can use the $40 saved for tires or something. Unless theres a good reason not to rebuild it?
Thanks!
Old 04-29-2008, 07:47 AM   #24
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
$100 engine? Replace it.
That damage is probably related to your filter coming off before. I bet your bearings are a little rough too... spin and feel for ANY lack of smoothness, and listen for any noises like grinding if you are even going to think about rebuilding. At the very least it needs a new piston, rod, and sleeve.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 04-29-2008, 08:37 AM   #25
air8's Avatar
Agreed. $60 and half worn other parts, compared to $100 and all brand new. Easy choice and you'd know everything else is ok.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 03:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 01:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 04:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 04:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 02:13 PM
