Old 04-26-2008, 02:04 PM   #1
buckeye34's Avatar
Default CLUTCH ISSUES
what would make the springs break? i have broken one spring in each of the last two weekends (total of two springs). they were brand new mugen 1.0 springs with mugen aluminum shoes that are also brand new. they were installed correctly just never had an issue with springs like this.
mbx5r
v-spec
jp-3 pipe
hitec 5955tg/steering
ko propo 2367/throttle
m-11
buckeye34 is offline   Reply With Quote
Old 04-26-2008, 05:43 PM   #2
I have had the same problem with their springs. I was not using aluminum shoes, but the Mugen carbon shoes. One thing could be heat related or material used to make the springs.
Sponsored by VISA
Shooky is offline   Reply With Quote
Old 04-26-2008, 09:50 PM   #3
tex1's Avatar
Send a message via Yahoo to tex1
Red face Sorry to hear that.....
I have had several customers with the same complaints on the Mugen springs. Every one of them have switched to the Ofna springs and have not had a problem since.
Just a suggestion.
Good luck on what ever you do.
TEX
tex1 is offline   Reply With Quote
Old 04-26-2008, 09:54 PM   #4
houston's Avatar
Trader Rating: 91 (100%+)
Talking
use kyosho springs and you will not have a problem !!!
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 04-26-2008, 11:13 PM   #5
Thanks for the suggestions!
Sponsored by VISA
Old 04-27-2008, 02:09 AM   #6
Maikaitan's Avatar
i have used their springs for the past 2 years and never had a problem with them... the thing is that i NEVER put back the same springs when they are out, even if they are still in good condition... my opinion is that they are cheap enough to be replaced and not cause you your race...
2 cents....
HobbyThingzBlk 201-E, Tampines Street 23, #01-118, Singapore 520201. Tel: 65-67828311, HP: 65-97465015. www.hobbythingz.com, team@hobbythingz.com
Regional Sole Distributor for Team Associated, Orbit Electronics, J Concept and PolyButler. Dealer for Tamiya, Kyosho, GS, Proline, Byron, Os Engines, RB, Futaba, Sanwa, KO.....
Please note that we are closed every Tuesday and P.Holiday. Hours are: 12pm-9pm.
Maikaitan is offline   Reply With Quote
Old 04-27-2008, 03:49 AM   #7
GenReaper's Avatar
Send a message via MSN to GenReaper
Ive had the same problem with mugen 1.1 springs brand new, 1 race and two broken springs using mugen silver alloy shoes and mugen CB.
Not real fond of these springs, the the last set seem to be holding up pretty well but IMO not reliable enough if racing, shame cause they work pretty good when they are in one piece.
Trex 700E 12S Scorpion 4035 560kv
Trex 600E
HPI Baja 5B SS
My videos : http://www.youtube.com/profile?user=genreaper
GenReaper is offline   Reply With Quote
Old 04-27-2008, 05:12 AM   #8
buckeye34's Avatar
thanks guys, i've switched to the fioroni turbo twin sliding clutch..i just have one more problem...it seem real boggy on the bottom...any more suggestions?
mbx5r
v-spec
jp-3 pipe
m-11
Old 04-27-2008, 05:28 AM   #9
Trader Rating: 19 (100%+)
Use the hard springs
FIO-OT-FR59 Fioroni Hard Sliding Clutch Springs (6)
They let the motor rev up more before the clutch engages.
pooldoc is offline   Reply With Quote
Old 04-27-2008, 06:09 AM   #10
lowey79's Avatar
reguardless of which clutch set-up you use, it will bogg under acceleration if it engauges too early. For maximum acceleration you want the clutch to engauge just as the engine comes "on pipe".
You should see good smoke from the exhaust at the point when the clutch hooks up.
lowey79 is offline   Reply With Quote
Old 04-27-2008, 06:32 AM   #11
buckeye34's Avatar
after some further ivestigating, the clutch shoes are rubbing on the cb when the engine is not running so any rpm and the shoes engage the cb...would it be ok to trim the carbon shoes to get more clearance?
mbx5r
v-spec
jp-3 pipe
m-11
Old 04-27-2008, 06:35 AM   #12
Integra's Avatar
the Fiorono Twin Turbo clutch is JUNK IN YO TRUNK....seriously its JUNK.....u cant load up the shoes with enuff springs before the shoes want to collapse on themselve's.....it will ALWAYS have a boggy bottom end and its NOT the motor....Get the 2 shoe shoes...and get a pack of hard springs as stated and use 1 hard on the bottom deep spring seet and 2 normal springs and u should be good to go.....consider it a 35$ lesson learned.
Old 04-28-2008, 07:38 AM   #13
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
If I understand correctly, there was a bad batch of Mugen springs... I don't know if this is resolved or not. In the past there were no problems like this, but my bud has broken a couple also recently.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 05-08-2008, 05:05 PM   #14
garen's Avatar
buckeye, your twin turbo clutch is an excellent clutch. what clutchbell are you using? are the shoes properly fitted in the flywheel? I use this clutch in my IGT car and I also have one in my buggy (the one in the buggy is a mix of black and white shoes, standard and stiff springs) and I have had great results with both. If you assemble the shoes properly, they will work just fine, and it will not have a boggy bottom end. If you need help, send me a PM.
bpengines-usa.com fioroni-usa.com motonica-usa.com
Airtronics Avid RC Byron Fuels VOX Engines
VMR Tires - available at http://motonica.ipower.com/store
garen is offline   Reply With Quote
Old 05-08-2008, 06:49 PM   #15
buckeye34's Avatar
garen, thanks for the offer but i sold the flywheel,shoes,springs,nut and washers.
mbx5r
v-spec
jp-3 pipe
m-11
Shim between inner clutch bell and clutch shoes razor_clawzz Nitro Off-Road 8 02-03-2008 09:24 PM
New kyosho flywheel and clutch bell plus 2 unopend clutch shooes tlxxx4driver R/C Items: For Sale/Trade 0 07-17-2007 02:54 AM
yamaha gt 80 dirt 4 speed clutch clutch bike 4 speed clutch cheap savage123 Other Items: For Sale/Trade or Wanted to Buy 8 08-10-2006 12:34 PM
WANTED:Savage parts-clutch bell, clutch shoes, rear driveshaft,etc..Orlando, Fl. 10gter Florida Racing 0 01-26-2004 08:54 AM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 04:01 PM
