Old 04-25-2008, 09:15 AM   #1
Default Part for P5 engine
Hi All.
I need to do an overhaul for my Novarossi P5 engine and I'm looking for a place (online) to buy the parts. I need the sleeve, piston and the rod.
Till now I've found it in Ace Hobbies, Nitrohouse.
Also, in the RC-Mushroom website (www.rc-mushroom.com) they have a kit for the MLC B7EVO engine which has the SAME partnumber as the P5 (and I know that MLC share some modells with P5).
Please let me know if you think the MLC part will suit (as the price on rc-mushroom is much lower than on the other sites) or recommend a place to buy the part
Thanks ALL
knfevg is offline   Reply With Quote
Old 04-25-2008, 10:36 AM   #2
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
That MLC p/s/r set should work fine. Check Ebay, as you just missed some JP Racing ones this week for about $125.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 04-25-2008, 11:46 AM   #3
zJatoRad's Avatar
Trader Rating: 31 (97%+)
Send a message via MSN to zJatoRad
AMainHobbies.com
Novarossi P5 Parts:
http://www.amainhobbies.com/index.php/cPath/1_68_158
Novarossi P5 Sleeve/Piston/Rod Kit:
http://www.amainhobbies.com/product_...oducts_id/2183
"Smooth is Slow, and Slow is Fast"
zJatoRad is offline   Reply With Quote
Old 04-25-2008, 01:28 PM   #4
Thanks for the info. Could you please send a link to that auction in Ebay?
Old 04-25-2008, 02:00 PM   #5
ezveedub's Avatar
YGPM!
Old 04-25-2008, 04:29 PM   #6
definately go and try amainhobbies.com they've got everything
wallnutz684 is offline   Reply With Quote
Old 04-26-2008, 01:45 AM   #7
Default Thanks all!!
One more thing:
I'm doing an overhaul because of a lose of a compression. The engine got bad because I wasnt careful enought with it (dirt got in).
I dont know if I should change only the sleeve/piston or should I do the conrod too?
Old 04-26-2008, 04:17 AM   #8
ezveedub's Avatar
Does the conrod have play on the crank pin? Also, the rear bearing might be toast also.
Old 04-26-2008, 08:19 PM   #9
22Racer's Avatar
Trader Rating: 67 (100%+)
If the engine is in pretty good condition you might be able to just get by sending it to someone and have the sleeve pinched. I pinch engines and I only charge $15.00 to pinch a sleeve, $35.00 if you send the whole motor. I have also had good luck replacing Novarossi parts with Go parts. A Go rod is under $19.00 piston sleeve and rod is $93.50.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
need the engine breakdown with part # for JP Mods engines mremtr Nitro Off-Road 4 05-28-2008 10:21 AM
RB V12 5 part turbo engine for sale cheap~~ must see fatlong R/C Items: For Sale/Trade 18 04-27-2006 02:14 PM
Engine Part Needed!! markallen R/C Items: Wanted to Buy 0 06-28-2005 08:33 PM
srio 5 port engine part zizgp Malaysian R/C Racers 1 04-25-2004 09:48 PM
