Old 04-20-2008, 10:40 PM   #1
vti-chris's Avatar
Default Diff-Inner gear shimming
How can i know whether the inner diff gears are shimmed correctly?
Is there a way to find out.
I had trouble with one of my diffs...it was working freely but sometimes it was locking and found out that the teeth were barely meshing.
So i removed two thick gaskets and left one thin one to seal the diff...this did bring the gears closer but how can i know i'm at the right spot?
I tried holding the crown gear and one of the diff cups while trying to turn the opposite cup and see the movement...should it be just like the spur and clutch bell movement or more...and how much?
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 04-20-2008, 11:41 PM   #2
asw7576's Avatar
Keep adding shims ( usually 1 more, or 2 more max ).
How do you know when the gear meshing become too tight ? The gear meshing become too tight when you feel gritty on diff action.
I use more shims in my hyper8 and xray xt8.
Old 04-20-2008, 11:46 PM   #3
vti-chris's Avatar
Do we add shims only on the 4 small gears or we can add the bigger shims behind the two large gears?
Xray/OS/Savox/Sanwa
Axial XR10
RCO
Old 04-20-2008, 11:51 PM   #4
asw7576's Avatar
I prefer the large gear get the shim(s) first.
Old 04-20-2008, 11:52 PM   #5
vti-chris's Avatar
Some diffs don't use a large shim...some do use but don't allow more than one...
Xray/OS/Savox/Sanwa
Axial XR10
RCO
Old 04-21-2008, 12:19 AM   #6
asw7576's Avatar
then stop.
in my hyper 8, I can only install 1 more ( 1 side only )
in my xt8, I can install 2 more ( both side ).
Old 04-21-2008, 12:42 AM   #7
vti-chris's Avatar
So as long as the pin goes freely through the diff cup then it should be OK and the diff working fine of course i can add shims???!!!
Xray/OS/Savox/Sanwa
Axial XR10
RCO
Old 04-21-2008, 12:46 AM   #8
asw7576's Avatar
YES.
Gear Diff VS Ball DIff NOVICE4EVER Singapore R/C Racers 23 08-29-2012 09:03 PM
Diff gear oil catkchun Malaysian R/C Racers 2 08-29-2007 08:24 PM
Square diff lock hub and gear diff oil for TT-01/R/D Drift Demon Australia For Sale/Trade 0 12-12-2006 09:34 PM
kyosho 777 STR diff shimming TENCHO Electric Off-Road 2 10-30-2006 08:16 AM
front lock diff vs gear diff rhed Nitro On-Road 4 11-29-2005 01:20 PM
