Old 04-18-2008, 03:14 PM   #1
Default Switching from 20% to 30% fuel?
Very quick thread, Does switching from 20% fuel to 30% fuel make a big difference?
I tried searching and found some info but not quite enough.
I read about some adjustments I might need to do with the HSN and LSN ect...
I also read about "shims" Now what are those? Where do you get them? Give me ALL and ANY info you can about those, ive never heard of them and am interested to learn about em!
new to rc cars is offline   Reply With Quote
Old 04-18-2008, 03:19 PM   #2
KThatcher's Avatar
Trader Rating: 64 (100%+)
What engine?????
- Picco - Triton RC - 818 Designs - Team-CRP - RCRenew.com -
Pro Motion T-shirts -
KThatcher is offline   Reply With Quote
Old 04-18-2008, 03:32 PM   #3
Originally Posted by KThatcher View Post
What engine?????
LRP z.28 spec
It has had 1.5 gallons through it, first was sidewinder 20% for .5 gallons. second was a whole gallon of Nitrotane, cant remember the %. now all my LHS has is 30%.
And I dont race at a track, I race/bash with a friend out in the country.
Thanks.
Old 04-18-2008, 03:38 PM   #4
racingboy14's Avatar
Trader Rating: 25 (96%+)
I was wondering the same thing
Bk Graphics Custom Painted Bodies
Email me at bkessie@woh.rr.com for a custom quote!
We also do vynil mask sheets!
racingboy14 is offline   Reply With Quote
Old 04-18-2008, 03:44 PM   #5
ok, I found what shims are, dont know why I didnt google it in the first place...
But I still need to know what to change and how to tell if I need more shims or what?
would these fit my engine? (it is not a Novarossi .28 528XR, its a LRP s.28 spec PS)
http://carolinasrc.com/Webstore/Scri...idproduct=2446
http://carolinasrc.com/Webstore/Scri...idproduct=2447
All engines have very thin shims between the cylinder head and the sleeve, and these shims are used to set the clearance between the two parts. You can increase power by removing shims or installing a thinner shim. This will make the combustion chamber smaller and will increase the engine's compression.
To remove the shims, you'll have to remove the cooling head, so take out the screws that hold it in place. You will see the shims on top of the sleeve, or they might be stuck to the head where it meets the sleeve. Remove one shim (if there is more than one) and reinstall the head. Be sure to check the piston/head clearance by manually spinning the crankshaft through one revolution to see whether the piston hits anything. If it does, replace the shim you just removed. The shims are very thin and bend easily, so be careful when you handle them.
Don't do this unless you're an experienced engine tuner. Too much compression and/ or insufficient head clearance may damage your powerplant.
Old 04-18-2008, 03:56 PM   #6
gfx
gfx's Avatar
What is HSN, and LSN?
gfx is offline   Reply With Quote
Old 04-18-2008, 04:07 PM   #7
imaxx21's Avatar
Send a message via AIM to imaxx21
a .28 engine should already be shimmed for 30% fuel..
you can just switch over without need any more shims.
HSN is high speed needle (main needle)
LSN is low speed needle
you might have to do a slight retune, but overall you'll be gettin more power and cooler temps with the 30 over the 20
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 04-18-2008, 04:09 PM   #8
whatr about an o.s. .12 tg motor, what should I do to switch from 20% to 30% with that motor, btw I use o'donell.
Old 04-18-2008, 04:16 PM   #9
gfx
gfx's Avatar
Okay... got it, thanks!
Old 04-18-2008, 04:52 PM   #10
imaxx21's Avatar
id stay with 20% in a small block personally...
-Crash
Old 04-18-2008, 06:15 PM   #11
allright, thats what I like to hear.
Im not sure what shims I have in my engine, its just a stock LRP .28 pullstart edition. I like it because I think its a Truggy engine and I have it in my buggy and it hauls pretty good
I wont know if its running badly or not because im not that experienced yet!! How do you tell if you need more/less shims?
unrelated question: if your engine smokes too much, do you lean it out a little bit?
Old 04-18-2008, 06:22 PM   #12
imaxx21's Avatar
dont worry bout the shims, you're good
smoke is good
-Crash
Old 04-18-2008, 07:27 PM   #13
Yea I just switched from 20 - 30 back to back and it was a noticeable difference in power and I had to fatten it up about 3 hours.
Furadi is offline   Reply With Quote
Old 04-18-2008, 07:36 PM   #14
smoke is good
How come you wont teach me about shims!! :'(
good, thats awesome, I didnt think I could get my buggy goin any faster!! damn
you mean "fatten" is richen it up? open the needle? counterclockwise?... just making sure
Old 04-18-2008, 07:50 PM   #15
imaxx21's Avatar
yes fatten = richen = ccw
-Crash
switching from EP to GP uniquexme Nitro On-Road 4 05-24-2006 04:23 AM
Switching Engines Decer Onroad Nitro Engine Zone 13 10-04-2004 09:24 AM
Switching Fuels? DOMOisCOOL Onroad Nitro Engine Zone 3 05-06-2004 10:59 AM
switching from 20% to 30%, got a couple q's speedydave Onroad Nitro Engine Zone 5 04-21-2004 08:16 AM
Help with switching to 30%. rcpilot Nitro On-Road 17 06-21-2002 06:56 AM
