Old 04-16-2008, 02:44 AM   #1
Default clutch bell
help i am putting a novarossi plus 21 in the losi 8 can any one tell me which motor mounts to use the ones that came with the car are too tall. does the quick change mount work?
rcrt is offline   Reply With Quote
Old 04-16-2008, 04:26 AM   #2
JQ
The ones that came with the car work ok with all .21 engines.
JQ is offline   Reply With Quote
Old 04-16-2008, 04:40 AM   #3
Do you have the rtr? If so you have to get the motor mounts from the kit.
clebo3 is offline   Reply With Quote
Old 04-16-2008, 04:58 AM   #4
What does this have to do with clutch bells, lol.
new to rc cars is offline   Reply With Quote
Old 04-16-2008, 06:33 AM   #5
slaytanic's Avatar
Trader Rating: 20 (95%+)
Most RTR kits come with mounts that are slightly taller than the kit versions. This is because RTR's have either a pullstart or some form of rotostart. This requires more clearance on the bottom of the engine due to the size of the backplate. If you have kit mounts and wanted to put a pullstart on you could by shimming the block up off the mounts a bit. With a bumpstart engine the RTR mounts can put the flywheel to high to make contact with the wheel on your starter box.
slaytanic is offline   Reply With Quote
Shim between inner clutch bell and clutch shoes razor_clawzz Nitro Off-Road 8 02-03-2008 09:24 PM
clutch bell Truggy007 Nitro Off-Road 2 10-21-2007 05:36 PM
New kyosho flywheel and clutch bell plus 2 unopend clutch shooes tlxxx4driver R/C Items: For Sale/Trade 0 07-17-2007 02:54 AM
WANTED:Savage parts-clutch bell, clutch shoes, rear driveshaft,etc..Orlando, Fl. 10gter Florida Racing 0 01-26-2004 08:54 AM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 04:01 PM
