Old 04-15-2008, 07:19 PM   #1
NEMESIS44's Avatar
Send a message via AIM to NEMESIS44
Default Restrictor Question
I know restrictors are used for obvious traction reasoning but how much fuel mileage will I be sacrificing switching from a 7.5 to a 9 in my Sportwerks .26?
Losi 8ight 2.0,Werks B6, Spektrum, Savox HVs, AKA
Loving me some FRC!
NEMESIS44 is offline   Reply With Quote
Old 04-15-2008, 07:34 PM   #2
mugenb46's Avatar
to much if your racing, ther smaller restrictor will allow the air to hit the fuel with more force or valocity, this is where the increase in runtime comes from using a smaller insert.
Brian Carey
Pro Twister Mods
[email protected]
615-838-5373
mugenb46 is offline   Reply With Quote
Old 04-15-2008, 07:47 PM   #3
Trader Rating: 5 (86%+)
I haven't played with restrictor selections yet, but as stated above, it would be great if someone could explain what's the use of a larger diameter restrictor
And they're called restrictors because the restrict bad fuel economy? Not performance?
razor_clawzz is offline   Reply With Quote
Old 04-15-2008, 08:48 PM   #4
NEMESIS44's Avatar
I understand the dynamics of a carb, I guess what I was asking was a rough estimate of runtime I would lose going from a 7.5 to a 9. Would it be close to a minute or would I lose several mins? Also,would dropping down to a 6.5 to gain fuel mileage be a very noticable change in power?
Loving me some FRC!
Old 04-15-2008, 09:01 PM   #5
wes95_z28's Avatar
No they are called restrictors because they restrict air. Less air requires less fuel for an optimum air/fuel ratio. That is where the increased fuel economy comes from. If you leave your needles the same going from a 9mm carb to a 7.5 mm carb, the motor would be extremely rich, you would lean it down, run similar temps as the 9 mm setup, just have a lil bit less rip.
Just remeber this. It takes fuel to make horsepower, the more air a motor pumps, the more power it makes, of course like i mentioned, the more nitro you will burn.
Wes
Kyosho 777 WC w/ big bores, RB S5, ACE 1313 s., Air 357 t., JP-3
HPI Savage X SS, Axial .28, Hitec 5645 Steering servo
Nitro TC3, O.S. .18 CV-R
Associated RC18T, Brushless, Lipo
wes95_z28 is offline   Reply With Quote
Old 04-15-2008, 09:17 PM   #6
Registered User
Here ya go, runtimes as follows 7.5 = 7 1/2minutes, 9 = 9 minutes...
Loop&Roll is offline   Reply With Quote
Old 04-15-2008, 09:27 PM   #7
imaxx21's Avatar
Send a message via AIM to imaxx21
thats very wrong...
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 04-15-2008, 09:34 PM   #8
Nik
Nik's Avatar
heh heh. good one mr. engineer.
Nik is offline   Reply With Quote
Old 04-15-2008, 10:32 PM   #9
NEMESIS44's Avatar
Yeah, I should probably put some air in my tires to huh?
Loving me some FRC!
Old 04-15-2008, 11:13 PM   #10
Registered User
Actually u do need air in your tires, and u should try both restrictors and see which u like...
Old 04-16-2008, 06:33 AM   #11
lowey79's Avatar
This is true but it also depends on how efficient your engine is....
Example: My first nitro engine was a modded Nosram evo 21 and it had good power, but used a tank in around 7 minutes...
My current engine is an OS Speed and it make more power than the Nosram and burns a tank in 11-12 minutes
Therefore, the Speed is using almost half the fuel to make more power!
Just food for thought!
lowey79 is offline   Reply With Quote
Old 04-16-2008, 05:55 PM   #12
wes95_z28's Avatar
True, design is a huge part of it. But just saying a high end .28 is more powerfull than a high end .21 is going to burn more fuel. Not only because of the cc increase but also because to the fact power takes fuel.
Wes
Carb Restrictor TC3ElectricGuy Nitro Off-Road 35 04-05-2009 05:50 PM
what restrictor in the rb ws7iii? jamminnay Nitro Off-Road 7 07-30-2008 01:34 PM
Restrictor duffman1977 Nitro Off-Road 2 10-02-2007 08:02 AM
Mugen X12... better without carb restrictor? Wildewinds Onroad Nitro Engine Zone 3 09-10-2004 07:49 PM
Carb restrictor thefuzzclub Nitro On-Road 5 09-13-2003 08:47 PM
