Old 04-13-2008, 04:17 AM   #1
busta774's Avatar
Send a message via MSN to busta774
Default newb question but can you drill holes in your fuel tank
busta774 is offline   Reply With Quote
Old 04-13-2008, 04:27 AM   #2
Yes I have seen people do this to their tank. Make sure you drill a hole smaller than the fuel tubing you wish to insert. It's also a good idea to seal around the tubing with sealant that is fuel resistant.
LosiMadMan is offline   Reply With Quote
Old 04-13-2008, 04:43 AM   #3
busta774's Avatar
Old 04-13-2008, 07:18 AM   #4
xlgraphicspro's Avatar
Originally Posted by busta774 View Post
hi i was wondering if you could drill holes in your fuel tank so you can put fuel tubing holder on there thanks busta
If this is just for a holder, and you want to use a screw to hold it on I wouldn't suggest putting a hole in your tank, you might loose the compression it needsto allow the fuel to be pushed to the engine!
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 04-13-2008, 09:18 AM   #5
dieseldog20's Avatar
Send a message via AIM to dieseldog20 Send a message via Yahoo to dieseldog20
yoo bro thats why he said make a small enough hole for the tube and put some sealant around it. a hole smaller than the tubing will provide sufficient enough pressure but sealant is and added bonus so there is no tuning issues.
dieseldog20 is offline   Reply With Quote
Old 04-13-2008, 09:35 AM   #6
captain america's Avatar
Kinda depends where you plan to drill the hole. In the vertical splash-guard, not a problem. If you want to put the holder(s) on the actual reservoir portion, you'd be better off using CA glue, no holes.
captain america is offline   Reply With Quote
Old 04-13-2008, 09:49 AM   #7
Tree's Avatar
Send a message via ICQ to Tree
I think you would be better off using CA glue or epoxy. I wouldn't drill any hole in a fuel tank. Just my $.02
Team Holy Rollers
HiTec Servos
"N-Tune" Nitro Engine Tuning Dials
Tree is offline   Reply With Quote
Old 04-13-2008, 09:55 AM   #8
petevette's Avatar
Send a message via Yahoo to petevette
Agreed, just scuff up the tank a little and use CA glue. Worked great for me.
petevette is offline   Reply With Quote
Old 04-13-2008, 10:15 AM   #9
imaxx21's Avatar
Send a message via AIM to imaxx21
CA Glue!!
dude dont drill a hole in you tank
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 04-13-2008, 06:31 PM   #10
busta774's Avatar
ok thanks for the suggestion
Old 04-13-2008, 08:44 PM   #11
I'm sorry I misread i thought you ment for a fuel pick up. Yes as others have said CA glue will work just fine. Sorry about leading you the wrong way. You can put holes in tanks as long as you seal them with fuel resistant sealant. I would go the CA route tho. You can also use some 3m clear double sided tape. The stuff is sticky as as anything, and won't stop the tank from flexing like a hard spot of CA.
Cutting out engine, intake and fuel tank holes in 1/8 body? jt415gz Painting, Designs, Graphics and Photography 10 01-25-2011 07:38 PM
Questions of Cutting Fuel and Vent Holes in the Body? SlamMan Nitro On-Road 5 05-19-2007 11:35 PM
Where to drill the holes in a new body Shodin Painting, Designs, Graphics and Photography 8 02-14-2006 03:52 PM
HELP: How to drill holes in bodies BSchorr Painting, Designs, Graphics and Photography 11 11-22-2005 10:34 AM
Sealing fuel tank question SeventyGTX Nitro On-Road 6 02-10-2004 01:23 AM
