Old 04-17-2008, 09:55 AM   #16
insaneracin2003's Avatar
Send a message via Yahoo to insaneracin2003
There is a guy, i am not sure of his name, that runs in the South that has an 18tz in his buggy....i was impressed by the power it had. i would also like to know what pipe and header they run on buggies....i may be making a switch to try this out...
Paul Schulz
Team Insaneracin
Very Special Thanks to my Sponsors:
Mugen Seiki USA / Mikes Hobby Shop / Byrons Fuels / Gulf Coast Raceway / Insaneracin Designs / Paint by "Smiley"
insaneracin2003 is offline   Reply With Quote
Old 04-17-2008, 09:54 PM   #17
gacjr0's Avatar
Trader Rating: 15 (100%+)
I run the .18 tz in my Hyper 8.5 and it's SWEET!
It has more power than the Dynamite .21 I had and better responsiveness too.
What it takes to install:
1:On the hyper 8.5 the motor mounts need a drill and tap for the closer spaced motor mounting tabs. Use the forward set of holes and drill a pair in the middle where the other holes are needed.
2: I chose to use a hpi clutch nut because the tz I was using was a threaded shaft; used the stock flywheel and MIP clutch.
3: Get the ofna clutch spacer kit for a set of washers needed to get the flywheel and clutch out to the chassis hole and to the spur gear. The tz block is much shorter than a .21's.
4: 13t clutch bell for the small track I'm on, might try the 14t.
5: I used a regular rc10gt pipe and rear exhaust manifold, sealed the pressure hole because it points at the tank, and put a new pressure nipple where it clears the tank. The new factory team smoothy pipe for the gt2 looks like a cleaner option.
note: my tz was also a rotary carb, you might laugh but the traxxas 2.5/3.3 carb fits nicely
on low bite days i got 12-15 minutes out of it, on super high bite (slicks on dirt!?) I only got 9.5, although I was trigger happy with all the bite.
I got my tz on clearance for $75
This setup also is 200g lighter than a .21 engine/pipe combo
gacjr0 is offline   Reply With Quote
Old 04-19-2008, 02:55 PM   #18
thecman26's Avatar
Trader Rating: 98 (100%+)
Thumbs up
Thanks for the info, I will be running a losi 4 shoe clutch on my .18TZ and its a slide carb already! Just gonna have to see about making a pipe fit in a Losi 8ight...
Thanks all!!!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 06-26-2008, 11:49 AM   #19
gacjr0's Avatar
Here's a coupl photos of a tz in a buggy:
OS .18 TZ in 1/8th scale?-cropped-bug2.jpg   OS .18 TZ in 1/8th scale?-cropped-bug-1.jpg
Old 06-26-2008, 10:20 PM   #20
griz11's Avatar
Send a message via MSN to griz11
Default A guy here wins with one all the time
There is a guy that runs in Austin that has a 18tz in his buggy and he wins all the time. I ran one in my pro mod drag car against the .21's and won lots of races with it. On road motors are generally balanced better from the factory rev faster as a result. Off-road racing is point and squirt and a quick revving engine is perfect.
Griz
PRO MOtion FOtos
Racing Images
www.youtube.com/griz11 Photos are here www.pbase/griz11 www.elroyjetson.info
Canon 7D EF400 EF70-200 EF40 Tamron SP70-300
griz11 is offline   Reply With Quote
Old 06-27-2008, 09:22 AM   #21
jabroni racing's Avatar
Trader Rating: 36 (100%+)
Send a message via Yahoo to jabroni racing
So the TZ fits in the 1/8 motor mount, but just needs to have new mounting holes drilled???? I
www.facebook.com/jay3638
jabroni racing is offline   Reply With Quote
Old 06-27-2008, 01:38 PM   #22
smac's Avatar
One of the Losi drivers ran one in his 8ight at the '07 nats here in St. Louis and almost made the A Main.
Scott McDonald
VelocityRC/Scale Motorsports/Checkered Flag Hobbies/SmacTrac
smac is offline   Reply With Quote
FS: NIB Kyosho Mini-Z Auto Scale Collection 1/27th Scale Bodies limbohz R/C Items: For Sale/Trade 3 07-21-2008 11:16 AM
Nsram ISTC, KO-PROPO 12th scale servo, JR and Hitec 10th scale servos crabboy Australia For Sale/Trade 2 07-14-2008 02:23 AM
Starting a 1/10 scale truck on a 1/8 scale setup starter box Cain Electric Off-Road 0 02-13-2007 12:48 PM
HUGE LOT OF 10TH SCALE & 12TH SCALE PAN CAR PARTS RED-LINE M03 R/C Items: For Sale/Trade 11 10-12-2006 03:57 PM
1/1 scale car super charger race against 1/10 scale touring car? edwintklee Malaysian R/C Racers 1 09-30-2006 03:00 AM
