Old 04-11-2008, 10:27 PM   #1
mike williams's Avatar
Trader Rating: 45 (100%+)
Default cleaning diffs....
just wondering what is the best way to clean the gears in the diffs for my losi 8 buggy....i've heard laquer thinner, mineral spirits, but not sure whats the best and safest for the materials. any suggestions would be greatly appreciated as always..thanks in advance..
LOSI MF2 ....... too fast for me!!!!!!!!
mike williams is offline   Reply With Quote
Old 04-11-2008, 10:28 PM   #2
Cog
Mainly use Naphta, works great and cheap.
Cog is offline   Reply With Quote
Old 04-11-2008, 10:35 PM   #3
GH Racing's Avatar
+1
GH Racing by Golden Horizons. Buy Direct At: WWW.GHHOBBY.COM
FOLLOW US ON TWITTER NOW: twitter.com/GH_Racing
High Quality Machined Aluminum Parts and Accessories. Vancouver, Canada.
GH Racing is offline   Reply With Quote
Old 04-11-2008, 10:40 PM   #4
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Never tried that stuff, but I will dump most of the oil out and use some type of Quick dry cleaner followed by the trusty Q-Tips. Might have to give that stuff a try.
Teufel Racing is offline   Reply With Quote
Old 04-11-2008, 11:33 PM   #5
imaxx21's Avatar
Send a message via AIM to imaxx21
check this out
http://www.unlimitedengineering.com/...ad.php?t=19075
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 04-12-2008, 04:11 AM   #6
Originally Posted by imaxx21 View Post
I also use this method and it works awesome.
blowpopracer is offline   Reply With Quote
Old 04-12-2008, 05:46 AM   #7
mremtr's Avatar
YUP !! That stuff works too I happen to use Dupont Cold weather enamel reducer but basically the same thing and it works AWSOME !!
If you go to your friendly body shop and ask them "what they use to remove silicone based materials from the paint just before prep" you will have your local answer ,as this is just what you need ,something to cut through the silicone .
mremtr is offline   Reply With Quote
Old 04-12-2008, 09:03 AM   #8
Vigilante212's Avatar
Simple green should work if your worried about plastic parts. I usually disassemble mine complete and soak it in brake cleaner since mine are aluminum.
Mod 13.5 Associated B5M Lite
Stock 17.5 Associated B5M
Vigilante212 is offline   Reply With Quote
Old 04-12-2008, 09:32 AM   #9
I use a glass mason jar...filled half with Naptha...put all the gears and pins in a Diff Dunker (GMK supply makes it)shake it around for 20 to 30 seconds and the gears are free of all oil...let dry on a towel and you done! I just let the diff cases set so the oil will drain out...by the time the gears are dry the cases are ready to reassemble.
lovell is offline   Reply With Quote
Old 04-12-2008, 10:05 AM   #10
fhm555's Avatar
Actually, GMK only sells the dunker. It's a tea brewing device for using loose tea, available at most any grocery store.
fhm555 is offline   Reply With Quote
Old 04-12-2008, 10:15 AM   #11
captain america's Avatar
Ditto that.
I use a magnet to get all the steel parts out of the jar afterwards. I'd avoid any harsh solvents on the plastic parts though: use a similar glass jar with rubbing alcohol in it to safely clean your plastic bits: just drop in the jar, close the lid, shake, and you're done
captain america is offline   Reply With Quote
Old 04-12-2008, 10:18 AM   #12
imaxx21's Avatar
Naptha wont hurt the plastic
-Crash
Old 04-12-2008, 10:24 AM   #13
Trader Rating: 47 (100%+)
The Diffdunker is just a tea brewer that has been
re-taged and marked way up in price. They can be
found at Target and other stores like that for $2.99
rageworks is offline   Reply With Quote
Old 04-12-2008, 10:27 AM   #14
imaxx21's Avatar
yeah we wouldnt want the spend $2 extra to support the small RC companies trying to help all of us out....
-Crash
Old 04-12-2008, 10:29 AM   #15
sounds like the naphta is the product of choice....but just wondering if you can use the naphta to clean the plastic parts... if not someone sair rubbing alcohol..is this the best product for the plastics??sorry if someone already answered this and i did not catch it...
thanks for the advice. i know that i can count on rc tech'rs
Mike
crt pro diffs spudly12 Nitro Off-Road 7 03-01-2008 03:27 PM
metal spider diffs or ball diffs in mini inferno? JEFFRO503 Micro and Mini Scales 3 01-11-2008 10:48 AM
Ball diffs versus gear diffs Cole Trickle Electric On-Road 20 05-16-2003 03:43 PM
cleaning my diffs wahturi Nitro On-Road 8 01-10-2003 10:51 AM
One-Way Diffs vs. Diffs in Kits eBoi31 Electric On-Road 14 04-13-2002 10:02 AM
