Old 04-12-2008, 10:32 AM   #16
imaxx21's Avatar
Send a message via AIM to imaxx21
Naptha will not hurt plastics...
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 04-12-2008, 10:33 AM   #17
mike williams's Avatar
Trader Rating: 45 (100%+)
thanks imaxx you answered my question before i even typed it
LOSI MF2 ....... too fast for me!!!!!!!!
mike williams is offline   Reply With Quote
Old 04-12-2008, 10:35 AM   #18
imaxx21's Avatar
ive even watched dudes clean their diff o-rings in the jar with no ill effects...
-Crash
Old 04-12-2008, 10:42 AM   #19
hey imaxx...make it easy on me. what can't i clean with Naphta??
no seriously...will it damage anything cause Nitro Blast is freakishly priced so i started used Brake Parts cleaner from the local auto supply house and seemed to work as well....
Old 04-12-2008, 10:49 AM   #20
captain america's Avatar
Imaxx is right, naphtha (lighter fluid) won't attack most plastics. I tend to use acetone myself to clean the metal hardware on my car, which WILL attack plastic, so I have to segregate plastic & metal. The advantage with acetone is that it evaporates fast & doesn't leave any residue on your parts like naphtha does; not necessarily a bad thing on gears but bad for screws.
captain america is offline   Reply With Quote
Old 04-12-2008, 10:51 AM   #21
i guess i will get some naphta and acetone...thanks
Old 04-12-2008, 10:55 AM   #22
imaxx21's Avatar
well i only use it to clean the diff gears...
i use simple green on everything else, then the garden hose, then WD40
-Crash
Old 04-12-2008, 11:01 AM   #23
Old 04-12-2008, 07:29 PM   #24
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Not sure about other brands, but Mugen and Kyosho diff cases are not harmed by Acetone. Even the diff gasket comes out fine. It comes out oil free like a new one.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 04-12-2008, 08:59 PM   #25
fhm555's Avatar
I always had good luck using about 3 oz of dawn with about 5 oz of hot water in a jar. Drop in the parts (except bearings) and give it a good shake then just let it sit for a bit, but not long enough for the water to cool off much. Pour the whole mess through a big tea strainer and give it a good rinse with more hot water. I toss everything out on a clean rag and use my heat gun to dry it all off. If you are real anal, a q-tip is about all you'll need to get the diff cup spotless and a quick wipe with a rag or paper towel will take care of everything else. The bearings all get put on a folded paper towel and soaked with denatured alcohol then wiped clean.
Dawn take grease out of your way......
fhm555 is offline   Reply With Quote
Old 04-13-2008, 02:25 AM   #26
Dave_x8's Avatar
Send a message via MSN to Dave_x8
petrol or thinners is da best
GO-TECH 21 5-port DOMINATOR
hyper 10 ON-ROAD toyota supra
Dave_x8 is offline   Reply With Quote
crt pro diffs spudly12 Nitro Off-Road 7 03-01-2008 03:27 PM
metal spider diffs or ball diffs in mini inferno? JEFFRO503 Micro and Mini Scales 3 01-11-2008 10:48 AM
Ball diffs versus gear diffs Cole Trickle Electric On-Road 20 05-16-2003 03:43 PM
cleaning my diffs wahturi Nitro On-Road 8 01-10-2003 10:51 AM
One-Way Diffs vs. Diffs in Kits eBoi31 Electric On-Road 14 04-13-2002 10:02 AM
