Old 04-11-2008, 09:37 AM   #1
Default Change bearings when new or after breakin?
Just like the title says, I have an os-v-spec and am wondering if changing the bearings to ceramic when new before break in is a good idea? Point being that the small metalic shavings created by the break in process may find their way into the ceramix before break in is complete and fowl the bearings? Is there any substance to this? If so replace after 1 gallon? thanks for your advice
clarksib is offline   Reply With Quote
Old 04-11-2008, 09:50 AM   #2
TMizzle's Avatar
If you are going ceramic do it from the start.
there is nothing wrong with the stock bearings in the new Vspecs though. But if you know for a 100% fact that you are wanting to go ceramic i say go ahead and install them, flush the engine out good while you have it apart and break that boy in.
Speeds come with ceramics, so do other engines... you wont hurt em.
Chassis:
Team Magic B8rs - USA Team
Sponsors:
GO TECH ENGINES (Factory Team) | VP Pro (Factory Team) | EB MODS (Factory Team) | RICHES BREW FUEL | COMPETITION PRODUCTS
TMizzle is offline   Reply With Quote
Old 04-11-2008, 09:55 AM   #3
cool will do then. Thanks for your quick response.
Old 04-11-2008, 10:13 PM   #4
i agree, if you are going to go ceramic, go TKO, i have 8+ gallons on my EB modded Vspec with the very same ceramic bearing the motor came with. Solid motor and bearing...cant go wrong!
AVID Bearings- The best bearings hands down
Upgrade-RC- Keeps the bling going
BCE Speed- Holds it down
Tonys Screws- Keeps you from getting screwed
Byrons Fuel- Makes the RC world go round
Jesse is offline   Reply With Quote
Old 04-11-2008, 10:58 PM   #5
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
It may not hurt to replace them after break in either if that is what you want to do. I have never had an issue with bearings during break in unless the bearing was bad to begin with. It happens from time to time. I have ran the ceramics and like them with no issues either.
Teufel Racing is offline   Reply With Quote
Old 04-12-2008, 01:09 AM   #6
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
I recommend after the break-in. That way, the bearing sees less stress and should last longer. I also check and clean the engine after break-in when the new bearing goes in. If your going to chuck the old bearing, might as well use it for the break-in.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 04-12-2008, 07:19 AM   #7
im sure others think differently when it comes to breaking in your engines..
but to me, part of break in is seating your rear bearing, also its a good idea to take the bearing out before you run any fuel at all so you can still sell it as new and get some money out of it.
Old 04-12-2008, 08:02 AM   #8
ezveedub's Avatar
I personally would not buy a bearing pulled from an engine. New or used. As far as seating a bearing, that would apply to real engine bearings, not ball bearings. I have never heard of break-in or seating a ball bearing.
Old 04-12-2008, 08:48 AM   #9
superdave2's Avatar
god dam 8+ gallons the most i ever had on a engine was i think 5 how much longer do you think it will last
Team Terribles~ARCS Hobbies~Have Fun Hobbies~Answer-RC~Torco Fuel~Fastlane Graphix~ Caster Racing Products~Maxamps~Clockwork Racing Engines~BCG Industries
losi 8t dps .28 jr z9100s jr z9000t
spektrum dx3
superdave2 is offline   Reply With Quote
BREAKIN IN A XXX NT HELP LOWGEARED Nitro On-Road 8 02-10-2007 09:25 PM
KANZEN Bearings vs Boca Bearings vs Other Bearings rmdhawaii Nitro On-Road 6 04-29-2006 08:38 AM
Breakin Period omalley Onroad Nitro Engine Zone 2 10-11-2005 09:20 AM
o.s. engine breakin wlvrn Electric Off-Road 14 09-08-2005 08:56 AM
help breakin ns12s5 rcjayy Nitro On-Road 5 07-10-2004 09:03 PM
