Old 04-10-2008, 12:23 PM   #1
desertbird's Avatar
Default Differential Oil
I've found a little bit on diff oil searching the forum. Just wondering when I see 5-5-3 what is the sequence; is it Rear, Middle, Front? Also, is there any good threads/reads on this subject? Any info on this subject is appreciated.
Thanks.
Neil
desertbird is offline   Reply With Quote
Old 04-10-2008, 12:28 PM   #2
that's actually 5-5-3 as your front,center,then rear differential
vroom88 is offline   Reply With Quote
Old 04-10-2008, 01:38 PM   #3
buckeye34's Avatar
hey bird, try this page.should answer all of your questions....
http://xtremerc.com/pages/howto.php?howto=24&page=3
mbx5r
v-spec
jp-3 pipe
hitec 5955tg/steering
ko propo 2367/throttle
m-11
buckeye34 is offline   Reply With Quote
Old 04-10-2008, 02:35 PM   #4
Nice post, good read
nayslayer is offline   Reply With Quote
Old 04-10-2008, 02:54 PM   #5
desertbird's Avatar
That was some good info. Thanks!
Old 04-10-2008, 05:53 PM   #6
Trader Rating: 5 (86%+)
How do you guys quickly get rid of all that black silicone oil? It's so sticky it takes about 10 mins for it to pour out from the diff case Any quicker way?
razor_clawzz is offline   Reply With Quote
Old 04-10-2008, 06:51 PM   #7
wd 40
Old 04-10-2008, 07:12 PM   #8
Originally Posted by nayslayer View Post
wd 40
LOL, thanks!
I usually used tissue paper - stick it inside the diff case and take it out, repeat 5 times Really messy
Old 04-10-2008, 07:40 PM   #9
dabro15's Avatar
Yea the black grease they put in is a pain to get out. What I do is take apart the entire diff and scrub it all out with degreaser. I run 5-7-3 in my diffs.
dabro15 is offline   Reply With Quote
Old 04-10-2008, 09:39 PM   #10
desertbird's Avatar
I would think WD40 would work great since it is a solvent. How about brake parts cleaner?
Old 04-10-2008, 09:48 PM   #11
desertbird's Avatar
Old 04-11-2008, 05:58 AM   #12
buckeye34's Avatar
i use mineral spirits or denatured alcohol to clean my cases and spider gears.
mbx5r
v-spec
jp-3 pipe
m-11
Old 04-11-2008, 08:18 AM   #13
a special blend of cleaners and a $50 ultrasonic parts cleaner from northern tool
www.carolinasrc.com
derricklong38 is offline   Reply With Quote
Old 04-11-2008, 08:51 AM   #14
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Soak the parts in denatured alcohol or mineral spririts, then blow them with compressed air. If no air, then a can of buggy blast should clear out whats left, plus it dries quickly also.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Differential Oil Doggie Singapore R/C Racers 3 08-05-2011 10:50 AM
Differential Problems... JMan8108 Electric On-Road 6 04-19-2006 04:28 PM
Differential question ballou Electric Off-Road 3 08-03-2004 07:31 PM
One way differential?? revnine Electric On-Road 6 02-19-2004 05:42 AM
Differential help Evil_S10 Monster Trucks 7 03-31-2002 03:46 PM
