Old 04-08-2008, 11:18 AM   #1
Default Big Bore shocks Turmoil?
Hello,
Does anyone here know if there is a set of big bore shocks that would fit onto a Turmoil Pro? Thanks
Blake
superx421 is offline   Reply With Quote
Old 04-08-2008, 11:27 AM   #2
IanWright's Avatar
Location: If i'm not in England i'm in Southern California
Send a message via AIM to IanWright
Set of Jammin's (Hong Nor) go straight on there if you use the Turmoils own rod ends i believe.
IanWright is offline   Reply With Quote
Old 04-13-2008, 08:17 PM   #3
What do you mean by Hong Nor? Is that a certain type of Jammin Big Bore shocks? Also, do you just mean using the standard shock shafts off the standard shocks? I really would like to get a set of these big bores for my Turmoil Pro, but want to make sure they will work. Thanks
Blake
Old 04-14-2008, 02:37 AM   #4
IanWright's Avatar
Hong Nor is how jammin is branded in Europe. Sorry, i should have made that clear, i know this is a mainly U.S forum.
I fitted a set to a Turmoil for someone a few weeks back and he is very pleased. We used the shock rod ends (The bit that attaches to the wishbones) from the Turmoil. I can't remember if we used the stand offs that came with the shocks or the originals already on the turmoil though.
It did change the car for the better, the Jammin shocks are very, very sweet. However i think that it would be better to save the money and put it towards a better car in general. The Turmoil is a great starter car but once driving has reached a certain level rather than throwing money at the car to hop it up i think it's better to sell the Turmoil and go for something more competitive.
I don't know what level you're at or age of your car or anything, that's very general advice. Hope it helps.
Old 05-18-2008, 07:28 AM   #5
speedrj's Avatar
Default Big Bore Shocks
I´m using Jammin Super Big Bore Shocks 16mm without adaptations. This shocks are great and if you planning to change your buggy remove from actual and place in a new one, also I´m using them in a Xray XB8 either.
speedrj is offline   Reply With Quote
Old 05-18-2008, 08:35 AM   #6
So you are running the standard Jammin S.B.B shocks on the stock Turmoil shock towers and arms or did you have to use a different shock tower and/or lower a-arm? Any info would be greatly appreciated. THANKS!
Old 05-18-2008, 07:20 PM   #7
UN4RACING's Avatar
Trader Rating: 22 (100%+)
I had a set of jammin standard shocks on mine but I had to change the stand offs on the shock towers to the jammin standoffs.
They worked great it was like a whole new kit. 37.5 losi in the rear and 40 losi in the front. Standard jammin piston.
UN4RACING is offline   Reply With Quote
Old 05-21-2008, 12:26 PM   #8
speedrj's Avatar
Default BBS
Use stock tower and braces, the only thing you have to change is the ball end post. Turn on engine, warm it up and in the first lap at your local track you´ll see other car running. Enjoy.
Old 05-21-2008, 01:14 PM   #9
Default Shocks
Speed,
What do you mean by "endball post"? Are you referring to the post that screws onto the actual slider rod that has a ball at the end of it? I just want to get the fact straight before I spend the money on these shocks. A little more explanation would be GREAT. Thanks so far!
Old 05-21-2008, 02:48 PM   #10
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Originally Posted by superx421 View Post
Speed,
Definitions for you:
Stand offs are the bolt and fitting that go through the shock tower and hold the upper end of the shock. The stock ones are probably too short, which would make the shock body and spring hit/rub the shock tower. If you use the Jammin ones they will positively be long enough.
The ends they mean are the lower ends that go on the end of the shock shaft to bolt to the lower control arm. Use the stock ones from Sportwerks is what the folks here are saying. Note that I have never tried this...
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 05-22-2008, 03:22 PM   #11
speedrj's Avatar
Default Turmoil with Jammin´s sbbs
See at:
http://www.amainhobbies.com/product_...ducts_id/16935
Replace stock for this.
Old 05-22-2008, 03:29 PM   #12
speedrj's Avatar
Default Turmoil + Jammin´s SBBS
If you are planning to buy this shocks look at Ebay.
See:
http://search.stores.ebay.com/Jennys...566615QQsofpZ0
Great Seller. I recommend.
Old 05-22-2008, 03:35 PM   #13
speedrj's Avatar
They also have a great stock of Turmoil Pro parts and you can buy them for a good $ .
Old 05-22-2008, 03:46 PM   #14
speedrj's Avatar
Look.
Is this great or not?
Old 06-08-2008, 01:52 PM   #15
speedrj's Avatar
Default Great race
I finished in 5th place in Rio de Janeiro Championship 4th round, behind XB8EC, MBX5R and Losi 8ight.
Turmoil Pro, X1X´s SBBS, quad brake, Byron 20% Gen2, Picco P7R EVO2 + JP-4, JR XS3, Hitec servos.
New To Big Bore Shocks MadRacer Nitro Off-Road 1 08-14-2008 09:40 PM
Jammin Big Bore Shocks Starter box R/C Items: For Sale/Trade 7 07-09-2008 12:41 PM
Big Bore shocks cbaranski R/C Items: Wanted to Buy 0 04-27-2008 06:24 PM
WTB Big Bore Shocks Black R/C Items: Wanted to Buy 0 04-05-2008 04:22 PM
WTB: Big Bore Shocks wes95_z28 R/C Items: Wanted to Buy 4 02-18-2007 04:30 PM
