Old 04-07-2008, 08:01 PM   #1
Default Mixing digital and analog servos - good/bad?
Hello,
Is it not bad to do, or is it BAD, to mix a digital steering servo with an analog throttle servo? Just curious. I just purchased a digital steering servo but will have to wait some time to get enough money to buy a good digital throttle servo. I would really like to use the steering servo to see how it is, but I don't know if I should mix the two? What do you think? Thanks
Blake
superx421 is offline   Reply With Quote
Old 04-07-2008, 08:06 PM   #2
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
That depends on your radio system. If its a Futaba with HRS, you cannot run the analog servo in HRS, you have to switch to PPM. You won't get the full advantage of the digital servo in this mode though.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 04-07-2008, 11:15 PM   #3
I was told before that it may work but its not recommended because of the different systems and power requirements of a analog and digital servo. In a way it would confuse the receiver or be more prone to glitching. Although I have tried it in the past and it worked fine.
Genius is offline   Reply With Quote
Old 04-07-2008, 11:47 PM   #4
Trader Rating: 26 (100%+)
Send a message via AIM to cheesecake
i run digital for steering and analog for throttle in my buggy and truggy
cheesecake is offline   Reply With Quote
Old 04-08-2008, 12:07 AM   #5
MadRacer's Avatar
Trader Rating: 33 (100%+)
Spectrum runs both with no problem, have done for yrs in my stadium.
Before i went to spectrum my Ko Mars r will only operate digital servos.
Boondal vintage Tamiya's
https://www.youtube.com/watch?v=vtmCddStNyM
QLD State Titles winner in 6S EB CAT
MadRacer is offline   Reply With Quote
Old 04-08-2008, 05:27 AM   #6
Default servo
Hey all,
I just bought an M11 radio with the Sepktrum Pro reciever/transmitter set-up. You would think that this quality of a radio would be able to handle the two different types, right? Thanks again for the info, I greatly appreciate it.
Blake
Old 04-08-2008, 06:44 AM   #7
The Spektrum doesn't care if the servo is digital or not. Only the Spektrum/Futaba HRS does.
AreCee is offline   Reply With Quote
Old 04-08-2008, 06:46 AM   #8
buckeye34's Avatar
i ran both with my m-11..it was even the 2.4ghz dsss system..and had no problems...
mbx5r
v-spec
jp-3 pipe
hitec 5955tg/steering
ko propo 2367/throttle
m-11
buckeye34 is offline   Reply With Quote
Old 12-29-2009, 09:19 PM   #9
Thumbs up
THANK YOU FOR THIS POST!
I thought my receiver had fried and was about to toss it. Then I thought it was the servos, when I started having the same problems as in the first post.
I was mixing analog and digital servos in HRS mode. I had forgotten about it completely that they wont work. If I applied the brakes without the load on the servo, all was fine, till I mounted the linkages and then all would stop. I guess the servos have some sort of protection?
I am using Hitec HS-645MG for steering and Hitec HS-7966 for the throttle/brakes.
Falconeer is offline   Reply With Quote
Old 12-29-2009, 10:18 PM   #10
wingracer's Avatar
Trader Rating: 23 (100%+)
Never had a problem mixing with Airtronics FM.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 12-29-2009, 11:58 PM   #11
Roelof's Avatar
Send a message via ICQ to Roelof
The Hitec 645/625/925/945 can not stand HRS mode, they can even burn out!
I have made a small electronic interface to use analoge servo's on a HRS system and it works fine, it helps me to use other cars with older servo's om my Futaba/Spectrum HRS system.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 12-30-2009, 06:09 AM   #12
portyansky's Avatar
Trader Rating: 54 (100%+)
+1, i have been doing the same for 4-5 years now with no ill affects (5955, 985)
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Old 12-30-2009, 08:53 AM   #13
merdith6's Avatar
Default Heck
I still run an Airtronics FM radio. Never had a problem with mixing before, and now that everyone has these new radios, I have my own channel. No interference, no glitches, and no runaways, no binding, hehe....
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Ko Propo Digital & Analog Servos Hebiki Electric On-Road 54 06-28-2006 07:29 PM
Digital vs. Analog Servos mwcet8k Monster Trucks 19 06-14-2006 11:03 AM
Digital versus Analog Servos Ducati-Rider Rookie Zone 7 06-04-2004 04:16 PM
Digital and Analog Servos voodoo Electric On-Road 2 10-04-2002 05:38 AM
Digital vs Analog servos nnick Electric On-Road 13 07-19-2002 08:44 AM
