Old 04-11-2008, 06:50 PM   #16
houston's Avatar
Trader Rating: 91 (100%+)
are you running the engine in a buggy or a truck ? the reason i didnt suggest the pipe being the problem is i haven't ever really had that sort of problem running any pipe header combo (i have ran alot of different pipe/header combos). pipe/header doesn't really effect the throttle down effect but more over the way it builds its power . anyway , hope you figure it out topcat
monty
if you have a tight fitting body , try the rb header , its made for that and still gives you the length .
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 04-12-2008, 04:26 AM   #17
mremtr's Avatar
Topcat , I too had this same trouble ,I found it was the damn throttle linkage causing the slide to "vibrate back to final closed" This issue drove me nuts! It did the EXACT thing you are discribing. Also had the slide boot "balloon" as it was closing and this too caused the same issue. fixed it with a stonger throttle return spring and a little bit of cleaning and polishing.
mremtr is offline   Reply With Quote
Old 04-12-2008, 08:52 AM   #18
superdave2's Avatar
i think any nova,rex,top motors are good
Team Terribles~ARCS Hobbies~Have Fun Hobbies~Answer-RC~Torco Fuel~Fastlane Graphix~ Caster Racing Products~Maxamps~Clockwork Racing Engines~BCG Industries
losi 8t dps .28 jr z9100s jr z9000t
spektrum dx3
superdave2 is offline   Reply With Quote
Old 04-13-2008, 08:58 PM   #19
Jammin57's Avatar
Trader Rating: 120 (100%+)
I think the P5 is one of the best all around motors you can buy. I have a p5 that probably has about 7-8 gallons on it and never had a problem with it you can let it sit and idle all day and it wont die always runs about 215-220 temps and has just as much power now(if not more) as what it had new.
Jammin57 is offline   Reply With Quote
Old 04-14-2008, 09:40 AM   #20
ok well went racing on sunday.
first race with it ran a bit lean came it bit hot
then richened it up and lost a grub screw in drive shaft so had pull in outa of that 1
next race ran really well a lot of low end and every quick down the staright loved it but bit mor epower full than i was used to as for fuel times after a 6-7 min heat i had 1/3 of a tank left very efficent indeed during the 10 mintute heats didnt want to chance it so pitted anyway.
but over all was very good performence.
adz06 is offline   Reply With Quote
Old 04-27-2008, 09:49 AM   #21
air8's Avatar
So how is everyone liking the P5?
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 04-28-2008, 02:15 AM   #22
Well was racing on sunday there i decided during the practices to run it until it ran dry so first time i got 9.48 seconds 2nd time i got 9.39 seconds whilst racing. i feel i could have gotten longer runtimes if the track conditions had not of been very skiddy and dusty as i couldnt grip and had loads of wheel spin due to wrong tyre choice.
was using the stock insert 8mm i think with jp-3 pipe and rb.no6 plug.
overall performence and reliablilty was excellent.
Old 04-28-2008, 06:22 AM   #23
tex1's Avatar
Send a message via Yahoo to tex1
Questions?? P5 for buggy racing.....
Hey Monty,
What pipes are you finding best for run time on these P5s? I have 2 brand new ones for the season and have a bunch of pipes to try. Right now the JP-3 seems to be my leader for power and fuel.
Have you tried a JP-4? RB2045 with different headers? Any other suggestions?
Also, what would cleaning it up for a fuel mod do for it? Before you ask, I do have one of the best engine mod guys around. This guy used to travel with the likes of Paris and BK to the onroad worlds events. He was responsible for tuning and engine setup. I asked him but he was wondering if it would make too much power for what we do in offroad. Just really looking for runtime here. Horsepower is good. But runtime you can take to the bank.
TEX
tex1 is offline   Reply With Quote
Old 04-28-2008, 07:58 AM   #24
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
For run time, a ceramic bearing should help. Reducing drag always helps. Lightened crank also, but will change the feel also. The filled S421B crank fits in the P5 and has the same timing.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
novarossi .21 rx21p5xs engine checkered flag Nitro Off-Road 6 05-04-2008 08:08 PM
does anybody know where to get a novarossi R PLUS 12-3CT tuned engine for a good pric srsracer Nitro On-Road 9 11-29-2007 04:52 PM
NOVAROSSI rx21r1wc "Kangaroo" Engine (1/8 Onroad) $225 or Trade for truggy engine! BIGTACO R/C Items: For Sale/Trade 15 08-30-2007 09:21 AM
Ofna Picco .21B 3 Port engine, good budget engine Cain Electric Off-Road 1 03-26-2007 07:32 AM
New Novarossi equip...good prices Izitbrokeyet? R/C Items: For Sale/Trade 1 11-16-2004 08:53 AM
