Old 04-06-2008, 02:58 AM   #1
Default Landing on front end over jumps, any advice please?
Hi guys
I have a Kyosho Inferno with a 21 engine. It has a fair few alloy hopups all over the car but more on the font end. Over alot of jumps i am landing on the front end of the buggy.. I am new to this so i am hoping there is a skill to landing them properly. Over the same jumps my mate's Swift buggy lands fine but all its body is standard and already carbon fibre.
Is there anything i can do or adjust to get the front to come down and even out for the landings?
thankyou!
pracy is offline   Reply With Quote
Old 04-06-2008, 03:22 AM   #2
MaTt 93's Avatar
Send a message via MSN to MaTt 93
just give the throtle a quick bleep while in the air. that should keep the front up
TLR 22 - Spektrum - 7.5 Speed Passion V3 - LRP
Durango DEX410R - Spektum - 5.5 Speed Passion V3 - LRP
SECOND PLACE IS THE FIRST LOOSER !!
MaTt 93 is offline   Reply With Quote
Old 04-06-2008, 03:28 AM   #3
I will try that but i think its the weight biased in the buggy as my mate who is new to jumping as well was going fine most of the time over the jumps. I may have been applying the brakes without reliasing.
Need a new front shock due to the landings snapping the shock shaft and i'll get back out and do some testing.
whats shocks you guys recommend for a inferno?
Old 04-06-2008, 03:47 AM   #4
Maikaitan's Avatar
try a little stiffer springs and heavier damping for the front shock... i should think that'll do the trick...
2 cents...
HobbyThingzBlk 201-E, Tampines Street 23, #01-118, Singapore 520201. Tel: 65-67828311, HP: 65-97465015. www.hobbythingz.com, team@hobbythingz.com
Regional Sole Distributor for Team Associated, Orbit Electronics, J Concept and PolyButler. Dealer for Tamiya, Kyosho, GS, Proline, Byron, Os Engines, RB, Futaba, Sanwa, KO.....
Please note that we are closed every Tuesday and P.Holiday. Hours are: 12pm-9pm.
Maikaitan is offline   Reply With Quote
Old 04-06-2008, 03:58 AM   #5
BOOST's Avatar
You could be onto something there....If it continuously noses dives then the pads are dragging on the disc or even just the front brake more than the rear. I use trinity spring things on my 8's and they fit between the pads to keep the pads apart to eliminate drag.
BOOST is offline   Reply With Quote
Old 04-06-2008, 04:41 AM   #6
thankyou for your reply's again. this will al help.
here is the buggy. does it look front heavy? would thick oil in the front effect anything?
Old 04-06-2008, 04:52 AM   #7
associatedguy's Avatar
Try taking some of the rpeload in the rear shocks out.
CEN Matrix FRE Buggy
Novarossi P5 with a 9886 pipe
KO Helios w/ spektrum
associatedguy is offline   Reply With Quote
Old 04-06-2008, 05:36 AM   #8
IanWright's Avatar
Location: If i'm not in England i'm in Southern California
Send a message via AIM to IanWright
When you come to upgrade the car strt with the shock towers when you bend them (I am assuming it's the 7.5 sport, that's what it looks like) then the actual shocks to the 777 shocks.
Do check the brakes are not dragging, if it's not that it's the shocks. The car should not need huge adjustment in the air. Talk to the guys at your local track and ask about springs (A lighter spring in the back is you general start, that wil help the car "Pop" into the air") and oils.
For now, pick the car up and drop it from a few inches onto a surface and look at the distance of the chassis from the surface. If the back is a lot higher than the front, then take some preload out and even the ride height out from front to back and try that.
There is a lot of info on shocks and jumping on the web, Google is also your friend
IanWright is offline   Reply With Quote
Old 04-06-2008, 03:05 PM   #9
thankyou for your advice. will check all of these!
what shocks do you guys recommend as i broke 1 front shock?
I thought google was my friend but no yesturday, i tried all different search terms with no luck!
Nitro buggy biased to front while jumping etc...
Nitro buggy landing on front end jump...
I kept going though!
Old 04-06-2008, 03:39 PM   #10
IanWright's Avatar
http://www.rc411.com/pages/howto.php?howto=42&page=1
Good links here:
http://www.rc-truckncar-tuning.com/r...on-tuning.html
http://www.rc-truckncar-tuning.com/rc-suspension.html
Getting in depth:
http://users.pandora.be/elvo/
I would say just replace the one shock or go out and treat yourself to Kyosho 777 shocks... but thats a money thing, keep spending and at some point you may as well have bought an upgrade in car... i'm still assuming it's the Kyosho 7.5
Google with rc buggy suspension tuning. If you learn how the suspension works then trouble shooting will get easier the more you learn
Old 04-07-2008, 04:07 AM   #11
slow coach's Avatar
get hold of the xray xb8 manual and their manual for the setup station both contain very useful set up info the set up station a little more
slow coach is offline   Reply With Quote
Old 04-07-2008, 03:34 PM   #12
petevette's Avatar
Send a message via Yahoo to petevette
It is highly unlikely that the car is nose diving due to excess weight in the front. The most likely culprit is going to be setup of the car as other people have mentioned. The slightly drag brake in the front will cause the nose to come down. make sure there is no brake at all on the front when you let go of the throttle.
Have any other drivers driven your car to see if it does the same to them? Just trying to eliminate that it is something your doing. I doubt it, but it is a good idea to eliminate yourself as part of the problem.
petevette is offline   Reply With Quote
Old 04-07-2008, 04:49 PM   #13
superdave2's Avatar
either your giving it brak while its in the air or there is too much drag brake check those and when your in the air give it gas to tip back and give it brake to nose dive
Team Terribles~ARCS Hobbies~Have Fun Hobbies~Answer-RC~Torco Fuel~Fastlane Graphix~ Caster Racing Products~Maxamps~Clockwork Racing Engines~BCG Industries
losi 8t dps .28 jr z9100s jr z9000t
spektrum dx3
superdave2 is offline   Reply With Quote
Old 04-07-2008, 09:44 PM   #14
thankyou for you good advice everyone. I have the parts to fix my shock now so i'll be testing out tomorrow. cheers!
I will check brake drag but i'm sure they're fine. but i know i was gassing off to early now. thankyou
Old 04-07-2008, 11:19 PM   #15
Just a tip since you said that your friend was jumping it fine. You may be lifting off the throttle too early in the approach of the jump causing it to nose dive. Try lifting off while your in the middle of the jump face and adjust your timeing from there.
Genius is offline   Reply With Quote
UK track... with jumps. IanWright Racing Forum 5 03-13-2008 03:00 AM
Excellent Jet with retractable landing gear-world exclusive famousrcmodel RC Flight 1 12-07-2007 08:20 AM
jumps firestorm1967uk Electric Off-Road 7 05-21-2007 03:03 PM
how to do great jumps? sonicboom141 Monster Trucks 6 08-29-2005 09:38 PM
Need advice: Electric motor occasionally just stops working after front-on crash... Bob Nilsen Electric Off-Road 12 03-31-2004 09:59 AM
