Old 04-02-2008, 11:04 PM   #16
Originally Posted by 22Racer View Post
I was suprised when I took a Go 3 port Sport apart. I was expecting a cheaper crank and other internals. It has the same crank rod, piston and block as all the Go motors with a little less machining on the block. It has a different head and the sleeve has more basic cuts, and an aluminum carb. With a little modding I bet one of these would run as strong as a 3 port race spec!
Rex
I wouldn't want any more So far I have run at length with a few sportwerks .21's and a werks B3. Im pretty much even with them on the straights or pulling. and mind you, I'm not running a race tune and am using an 8mm reducer.
The hype for these engines is all true.
Furadi is offline   Reply With Quote
Old 04-03-2008, 01:49 PM   #17
22Racer's Avatar
Trader Rating: 67 (100%+)
I'm going to compare the sport to the race 3 port next week just measuring the sleeves to see if the timing is the same. I'm thinking that by modding the motor it will smooth out the power on the bottom and give it more on the top.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 04-03-2008, 03:00 PM   #18
Vigilante212's Avatar
The 3 port R has a more linear powerband making it easier to drive. The 3 port sport has a ton of low end great for tight tracks, but is a lot harder to control. The 5 port is kind of the middle of those two its the one I got.
Mod 13.5 Associated B5M Lite
Stock 17.5 Associated B5M
Vigilante212 is offline   Reply With Quote
Old 04-03-2008, 06:27 PM   #19
mugenb46's Avatar
the 3 port sport is stupid when modded with turbo head and race carb. Ther race carb helps some in keeping it under control, i didn't go that far on timming before i saw it would become a light switch, i don't mod my motors to have that feel, but modded yes they are a freakin blast
Brian Carey
Pro Twister Mods
brian@protwistermods.com
615-838-5373
mugenb46 is offline   Reply With Quote
Old 04-03-2008, 09:50 PM   #20
UPDATE: I finally set it to a race tune today with temps in-between 227 - 230. Traction off the bottom is still an issue even with the V-spec reducer. I took off the stock losi clutch and installed my Fioroni 3-shoe adjustable so i'll see if that helps. (Just wanted to see how the kit clutch performed)
So what are safe temps to run these things at? I usually don't go over 230 with my engines but this thing isn't happy when I back it off even an hour.
Old 04-03-2008, 10:17 PM   #21
mugenb46's Avatar
240-250 is around what i run on all my modded GO's stock also, just run it where you and the engine feel right, if you want more runtime don't be afraid to go higher on temps, and if you can find a NR 6 or 6.5 in sert that will help on the bottom end and boost runtime some
Brian Carey
Pro Twister Mods
615-838-5373
Novarossi 21+5, 21BF 3-port, & GO Tech .21 7-port Turbo!!! $110 shipped!! HoustonAreaRC R/C Items: For Sale/Trade 5 08-05-2008 09:30 AM
Go Tech 5 port MattOCM R/C Items: For Sale/Trade 2 07-13-2008 06:36 PM
First impressions of my Gen 5 Go 7 port! Furadi Nitro Off-Road 6 07-08-2008 03:16 PM
Go Tech 3 Port Race Spec rokitman R/C Items: For Sale/Trade 31 05-14-2008 11:29 PM
Go 3 Port R spec and a 3 Port Sport? brianr34 Nitro Off-Road 1 05-14-2008 04:07 AM
