Old 04-01-2008, 10:34 AM   #31
blktransam's Avatar
Trader Rating: 59 (100%+)
the "old" stuff is still avil. its called "hobby shop gold" its the same exact formula according to Byron (over the phone convo). If you like the new stuff congrats I am not here to argue the fact I had bad luck with it. as for run times I run the picco p7r and get 10 mins of runtime all day long with the 8mm venturi on the "old" stuff. just picked up a RB modded p7r hope to get around 10 1/2-11 on a tank also running the JP3/4 pipe depending on track layout. had a vspec that would get 12-12.5 with no prbs as well
one guy runs a ceo modded vspec and get 14 mins on a tank thats just crazy haha.
I love bryons fuel I just opt. for the first gen is all
blktransam is offline   Reply With Quote
Old 04-01-2008, 06:39 PM   #32
houston's Avatar
Trader Rating: 91 (100%+)
hobby shop gold huh ? when properly tuned and piped , most engines get 10 minutes . just hard to rely on under hardcore racing applications
liverc.com look under results for lunsford cup gas blast 1/8th arena truck pro amain look at the winner
monty
i used a 50/50 mix of old race3000 30/11 and new 30/9 pro racer fuel , seemed to be a great mix for me !
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 04-04-2008, 01:45 PM   #33
houston's Avatar
Talking
great fuel , highly recommended!!
Old 04-05-2008, 09:08 PM   #34
yup . jus tested the fuel. its simply burn well. no stain appear inside the engine.
the nitro fuel simply appear to be coating the engine as well.
novaa is offline   Reply With Quote
Old 04-05-2008, 09:51 PM   #35
losi guy's Avatar
Trader Rating: 38 (100%+)
Send a message via ICQ to losi guy
I have been running this fuel for awhile and it's so good I don't think i'll run anything else.
Spektrum | Avid | DE Racing | Tekno
losi guy is offline   Reply With Quote
Old 04-09-2008, 09:09 PM   #36
MudLife's Avatar
Byrons is good for the price. i run it but i think im going to switch to tq
MudLife is offline   Reply With Quote
Old 04-09-2008, 10:23 PM   #37
houston's Avatar
byron's is the best .
Old 04-09-2008, 10:31 PM   #38
Trader Rating: 26 (100%+)
Send a message via AIM to cheesecake
ive ran about a half gallon of this. i have ran werks fuel also i found tuning easier with the werks but with the gen 2 there isnt a really oil mess like there was with the werks but so far im happy with it i might stick with the gen 2 for a while
cheesecake is offline   Reply With Quote
Old 04-15-2008, 07:20 PM   #39
tudoe666's Avatar
I use gen 2 and have no problems at all with it!!!! My truck seems to start easier on gen 2!! Maybe its my first bit of "nitro good luck"
TUDOE
tudoe666 is offline   Reply With Quote
Old 04-15-2008, 09:45 PM   #40
i ran all sorts of fuel, OD, Werks, Nitrotane and so on...this fuel has been awesome with all my motors, tune has been consistent, temps normal, runtime has been great, most of all i dont get a gummy residue like i get with nitrotane. Werks also leaves residue as thick as honey and i had to use after run oil with OD.
I stopped buying after run oil ever since i started running this fuel, i just empty my fuel tank, run the engine dry on the starter box and the fuel leaves a nice coat inside the engine, zero signs of rust.
Byrons did good!
AVID Bearings- The best bearings hands down
Upgrade-RC- Keeps the bling going
BCE Speed- Holds it down
Tonys Screws- Keeps you from getting screwed
Byrons Fuel- Makes the RC world go round
Jesse is offline   Reply With Quote
Old 04-16-2008, 08:52 PM   #41
GHETTOTEACHER's Avatar
I just switched from tornado to Byrons Gen 2. That was one of the best moves I made! My motors run a hell of alot cooler and the punch is great! My 928 in my truggy has never run hard at 200 degrees until Gen 2 came out. I have my second case on order!! Good stuff!
Herolin <---Traded my Airtronics for an Ipad and Laptop...
Soon to be GHETTOPRINCIPAL..
GHETTOTEACHER is offline   Reply With Quote
Old 04-17-2008, 08:05 AM   #42
RBMike's Avatar
i am a serious engine guy , i treat my engines very well and they do the same for me . i have ran 2 gallons of pro 30%nitro , 9% castor blend and have noticed longer run times by about 10-15% , i like the power it makes and it is easy to tune . the only complaint i have is the anti foaming agent that they added that leaves a residual build up inside my engines which leads to premature bearing failure and scored piston and sleeve from build up flaking off while running the engine(i am very finnicky), something that was never a problem with race3000 blend now i have to clean the engines out more often the reason i will continue to use it is better power and more runtime(and the old race3000 isnt available )
monty
This seems odd to me, I just finished my 3rd gallon of gen2 25% in my C6. I tore my motor down this week for a cleaning after I read your post & found the insides to be cleaner than I have seen in the past. No residue or build up at all. I will continue to use this fuel as long as I can get it.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 05-27-2008, 05:38 PM   #43
xlgraphicspro's Avatar
Has anyone noticed a dark residue in there engine after running the byrons gen 2?
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 05-27-2008, 05:48 PM   #44
i havent noticed a dark residue but a good coat of oil all over everything
Old 05-28-2008, 10:32 AM   #45
Default Engine Cuts off
Hi, I am having a problem where after switching from Gen 1, when I come into the pits after a few laps when I hit the brakes the car instantly cuts off.
It starts back without an issue but this problem never happened before until I switched to GEN 2 after being a loyal Gen1 user.
Any ideas guys?
jelayne is offline   Reply With Quote
Byron's challenge 2008 Leisure Hours Nitro On-Road 148 07-03-2008 11:58 PM
question about Byrons gen2 fuel mike williams Nitro Off-Road 17 06-05-2008 05:45 AM
IMDRA VP Race Fuel East Coast 3 Race Series A/Fuel Racing Forum 0 07-29-2006 11:40 PM
Where can I order Byron's fuel online? grampi Electric Off-Road 9 11-27-2002 09:26 AM
