Old 03-26-2008, 08:52 PM   #1
Send a message via AIM to ofna racer
Thumbs up Is it hard to start a go tech motor with a starter box
I just bought all nice stuff to go racing and i have a 5 port .21 go tech motor never started yet, waiting for warmer weather so i can tune it, i noticed it has tone of compression afraid my starter box will not turn the fly wheel is there n e tips or trick some can share with me i dont want to mess the motor up. just lookin for some thing that will maybe make my life easier when i start it thanks a lot
ofna racer is offline   Reply With Quote
Old 03-26-2008, 08:58 PM   #2
SKOT's Avatar
- Make sure your starter box is fully charged
- Use the extra head shim that should have been included in the box for the first gallon or so
- Pre-heat the engine to above 200* with a heat gun before starting
- Once it does start keep the temps above 200* (wrap the head with foil to keep the heat in if you must)
I'm sure others will chime in. These are just the first few things that came to mind. Good luck. These things are tight, but you won't be disappointed.
http://www.rcsignup.com/racers/displayRacer.cfm?ID=215
SKOT is offline   Reply With Quote
Old 03-26-2008, 08:58 PM   #3
dubum's Avatar
Trader Rating: 85 (98%+)
Loosen the glow plug a bit, make sure the piston isn't at TDC.
dubum is offline   Reply With Quote
Old 03-26-2008, 08:59 PM   #4
22Racer's Avatar
Trader Rating: 67 (100%+)
When you fuel the car blow into the pressure line on the pipe to get fuel right up to the motor. Heat the motor to 200 deg. with a heat gun and try it. If it wont turn it over loosen the plug just a tad. Also use a hot plug, for turbo plugs try a Odonnel 97t or Os p3. I tried a cooler plug and I had to run it leaner to get it to idle.
Good luck! You'll love that motor.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 03-26-2008, 09:17 PM   #5
Tree's Avatar
Send a message via ICQ to Tree
Definately use the extra head shim. I connected my starter box to my car's battery and I used a lot of After-Run oil. I put a lot of oil in the glow-plug hole and carb. Loosen the glow plug a little and wrap the engine head with aluminum foil. Blow into the pressure line to get fuel to the carb and use a heat gun to get the engine temps over 200 degrees F then give the engine a bump on the starter box. Good Luck. Once you get it going you will not be disappointed.
Team Holy Rollers
HiTec Servos
"N-Tune" Nitro Engine Tuning Dials
Tree is offline   Reply With Quote
Old 03-26-2008, 09:41 PM   #6
Default whats a head shime
whats a head shime
Old 03-26-2008, 09:43 PM   #7
Default after run oil
Is it important to use after run oil after ecerytime i park the car for the night
Old 03-26-2008, 09:44 PM   #8
Fastburn's Avatar
Trader Rating: 16 (100%+)
a head shim is a little copper ring, kinda like a head gasket for a car.
It goes between the engine block and the head button where the glow plug is.
Nate Talaskavich
Fastburn is offline   Reply With Quote
Old 03-26-2008, 10:01 PM   #9
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
i usually hang out in monster trucks but i can help with this one,
head shim
http://www.hpieurope.com/graphics/wa...nehead/004.jpg
its the silver thing. above the piston
http://www.hpieurope.com/graphics/wa...nehead/002.jpg
there usually copper
http://www.osengines.com/proofing/osmg2074-shim-b.jpg
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 03-27-2008, 03:30 PM   #10
22Racer's Avatar
I think if you are new to nitro I would not take the head off and add a shim. Although it is very simple a inexperienced person could do more harm than good.
Rex
Old 03-27-2008, 07:35 PM   #11
dubum's Avatar
Thumbs up
Seriously? I think if he was able to get everything out of their boxes he should be able to add a shim.
Old 03-27-2008, 07:58 PM   #12
22Racer's Avatar
As far as after run oil it depends on the fuel you run, with some fuels you don't need after run. Always be very careful not to get dirt in a motor anytime you take off the filter or take the plug out.
Rex
Old 03-27-2008, 10:00 PM   #13
Tree's Avatar
I use Byrons 30% fuel. The reason I used after run oil before starting was because the piston would get stuck when I would try to start it on the box. I used a heat gun and I got the temps to over 250 degrees and the piston would still get stuck. The extra oil helps get the engine to turn over once you have heated the engine head with a heat gun.
Team Holy Rollers
HiTec Servos
Old 03-29-2008, 04:36 PM   #14
Trader Rating: 36 (100%+)
Default heat gun
heat gun is a must. if you don't have a way to heat it up to at least 200. let your local hobby store break it in for you. Also use fuel (monster 30%) thats has an high oil content (at least 12%). And last Take you time.10 tanks takes time.
Mik G is offline   Reply With Quote
Old 03-29-2008, 05:12 PM   #15
Trader Rating: 47 (100%+)
THIS IS A CALL OUT TO ALL OF YOU IN THE Cbus AREA!!!
Can one of you get in touch with "ofna racer" and help
him out? Mabey take some time and show him from the
begining the proper ways of starting and breaking-in his
new motor. If I didn't live so far away, I'd do it myself.
Remember, If you give a man a fish, he eats that day.
But, if you teach a man to fish he eats the rest of his
life. Good luck, "ofna racer".
rageworks is offline   Reply With Quote
***Traxxas EZ Start 2 handheld starter and 4 ez start systems*** MattP R/C Items: For Sale/Trade 6 08-18-2007 06:49 PM
Engine Hard To Start!!! snoop69 Monster Trucks 2 02-10-2006 08:04 AM
hard time starting motor with starter box NTC3Kitty Nitro On-Road 4 07-24-2005 09:15 AM
Pull Start? Roto Start? or Starter Box? jamiekulhanek Electric Off-Road 3 09-09-2004 12:50 AM
Hard to Start ? paulo780 Electric Off-Road 4 01-09-2003 12:18 PM
