Old 03-25-2008, 03:36 PM   #1
DPowers's Avatar
Trader Rating: 79 (100%+)
Default fixing a gas tank
i got a gas tank with a small grack at the seem are they any way of fixing this maybe some glue or something if you have had this problem could you fix it or just buy a new one.
DPowers is offline   Reply With Quote
Old 03-25-2008, 03:39 PM   #2
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
i dont see why a 2 part epoxy couldnt fix it.
MONKEY BUSINESS RACING
Flinging poo at a track near you! Winning hearts and minds everywhere!
www.graphicmonkeydesigns.com
Brooksphotodesign.net
Flying Monkey is offline   Reply With Quote
Old 03-25-2008, 03:59 PM   #3
dieseldog20's Avatar
Send a message via AIM to dieseldog20 Send a message via Yahoo to dieseldog20
answer lies at autozone. there are a couple ways you can do it....
1. J B Weld.... its alittle messy but it will stick to plastic and wont erode away from the nitro
2. they sell a two part epoxy, it looks like a suringe(spell) needle more or less. it has a glue and hardener all in one tube you just squeeze it out and apply.
both will work for how long... depends on your driving. there are a couple other ways i cant remember i used to work at autozone and had people ask about it. i advertised my r/c cars there. but go to an autozone or auto parts store and ask them for something that will bond to plastic and not erode away from fuel. those two should do the trick
good luck
dieseldog20 is offline   Reply With Quote
Old 03-25-2008, 04:00 PM   #4
looper's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to looper
air leaks are nothing to play around with,, i would contact the manufacturer if you bought it new that way.. somehow getting a new tank would be the best option.
with this being on the seam you might be able to melt it back together using your soldeing iron though,, it would at least buy time to get another one. make sure it is clean of fuel and oil before you work on it. denatured alcohol works good for this
looper is offline   Reply With Quote
Old 03-25-2008, 04:02 PM   #5
Send a message via MSN to Adim_X
My recommendation would be to buy a new tank. I have been down the 2 part epoxy road and just havent had much luck. Once the tank gets fuel or wd40 or any lubricant its is damn near impossible to get clean enough to hold epoxy well.
However if you need it to race and can't get another in time, then I would try it. Make sure you clean the heck out of it and try to rough up the area the epoxy will sit. If you engine acts funny after doing this, you could still have an air leak. Try at your own risk.
Privateer:
Mugen MBX7R ECO/Nitro, Hitec, Sanwa, Jconcepts Tires, OS Speed, Bones Fuel, Fantom
Adim_X is offline   Reply With Quote
Old 03-25-2008, 04:05 PM   #6
i got some good epoxy here denny. let me know if you want to try it
Old 03-25-2008, 04:09 PM   #7
DPowers's Avatar
i will probley buy i new one but if they was a for sure way of fixing it to save a few bucks i was going to.
Old 03-25-2008, 04:10 PM   #8
like i said i have some you can use. your welcome to it. its strong stuff and only takes 6 minutes to get set up but 24 hours to totally cure.
Old 03-25-2008, 04:13 PM   #9
DPowers's Avatar
thanks man it broke on me at the money race at dalton i thought they was something wrong with my motor i even blew threw it and didnt find the leak, when i got home i but it in a bowl of water and well you know the rest bubble city well atleast it wasnt my rossi i will buy one before dions this weekend.
Old 03-25-2008, 04:16 PM   #10
ok if you need me to bring it holler at me. if you want to fix it before the weekend let me know when you want to come fix it.
Old 03-25-2008, 08:37 PM   #11
Integra's Avatar
FYI....Jb Weld is NOT fuel proof....it willl seal up temoparily...but will Soak up nitro over time and eventually fall off.....i used it to seal up a pipe to only have it soak up some exhaust nitro and fall off....your best bet would be to get a new tank and be done with it.....but if u Wanted to...Three bond 1211 Would do the trick..its what i use on all my losi tanks on the fuel line and works like a charm.
Old 03-25-2008, 08:52 PM   #12
driftah's Avatar
if ....and only if you are good with a soldering gun you can plastiweld the cracks etc and this works good just be careful not to go too deep,it has saved my butt a ton and fairly strong
driftah is offline   Reply With Quote
Old 03-25-2008, 09:47 PM   #13
Trader Rating: 49 (100%+)
Send a message via AIM to weaponx
Heres is a little tip, that I use. Take a wide tip flat screwdriver. Heat it up, with a small torch, and with the hot screwdriver lightly rub it along the edge of the tank where the top and bottom meet. It will melt the top to the bottom. ( you will have to continuely heat the screwdriver,but this way it will keep you from melting to far into the tank ) But still becareful not to go to deep. Hope this helps.(note I do this to all new tanks,and have never had an issue)
weaponx is offline   Reply With Quote
Old 03-25-2008, 09:53 PM   #14
Suspended
Ya I would just by a new tank and not worry about it leaking.
adamdrake is offline   Reply With Quote
Old 03-25-2008, 10:16 PM   #15
Yea just buy a new one, it isnt worth having a hack job fix go bad on you in the middle or your race, or even just your day at the track. Maybe use one of the methods mentioned above on the old tank to have as a back up in an emergency but dont make it your main tank.
Nitro syco is offline   Reply With Quote
Thanks for fixing RC Tech!!! rccardr Electric On-Road 29 02-26-2008 11:16 PM
fixing a bad cell john stu Electric Off-Road 5 06-26-2007 07:18 PM
Trinity Spyder tank & Violator tank Hugh R/C Items: For Sale/Trade 0 07-21-2006 05:12 PM
Fixing ESC, Reciever, inet-projects Rookie Zone 8 01-15-2006 07:02 AM
Fixing A Shell shortyzz Rookie Zone 4 12-30-2003 01:18 PM
