Old 03-23-2008, 12:22 AM   #1
MaTt 93's Avatar
Send a message via MSN to MaTt 93
Questions?? Making your own fuel ????
Hi,
i have a few questions about this.
1)Is it worth it making my own fuel or would it be cheaper to by it from my LHS?
2) how many people actually make it ?
3) what would i need to do this ?eg. ingredients
4) where would i get the ingredients from ?
TLR 22 - Spektrum - 7.5 Speed Passion V3 - LRP
Durango DEX410R - Spektum - 5.5 Speed Passion V3 - LRP
SECOND PLACE IS THE FIRST LOOSER !!
MaTt 93 is offline   Reply With Quote
Old 03-23-2008, 12:40 AM   #2
OzzyNitroJunky's Avatar
I am going to start making my own fuel soon, It does make it more cost effective to mix your own plus you can mix your specs. Any good hobby shop should have the ingredients to make your own,You will need Nito(off course), methanol,and a lubricant wether it be synthetic or castor type. The fuel I'm using at the moment is 25% nitro with 12% klots bean oil(I was informed this was the best oil to run, Responses would be appreciated). And thats about it, just mix it up and keep it all cool and in a dark area until use.
_____________________
RC8 FT
OS VZB
DX3R
OzzyNitroJunky is offline   Reply With Quote
Old 03-23-2008, 01:12 AM   #3
MaTt 93's Avatar
i'v also heard that nitro absorbs moisture. is that true
Old 03-23-2008, 02:57 AM   #4
chris c's Avatar
Trader Rating: 60 (100%+)
yes very true.....
like brake fluid its hypopoic(sp)
chris c is offline   Reply With Quote
Old 03-23-2008, 04:48 AM   #5
Hi,
1 Here in Holland it pays off to make/mix ur own fuel. But i thought it was only cheaper when u start using large amounts because they (methanol ) are only available in bigger amounts (5L). If you drive often and use much fuel maybe you might consider doing this.
So i am still using 2.5L tornado sometimes 1 liter and i use it for a few months. So i don't think it pays off to mixture it myself.
2 Here in Holland i know some drivers from the forum that make their own fuel. But they are serious drivers who consume much fuel.
3 It depends on how much nitro you want. For example lets say u want to have 16% nitro + 14 % oil for protection and the greasing of your engine and you want to make 1 Liter = 0.04 Gallon?
That means you will have to use 160 ML nitromethane , 140 Ml oil, 700 ML methanol.
The methanol and Nitromethaan are available at your Modelshop they have to be pure. They are more pure than in the Do-It-Yourself store.
You also need oil that is mixable with methanol. What i've read is that for example Castor oil/Rizol, Motul micromotor, Klotz are good to use.
Revell RMS Titanic 1:400
snowmansion is offline   Reply With Quote
Old 03-23-2008, 05:32 AM   #6
buckeye34's Avatar
I use to make my own fuel when i flew rc planes. i used Klotz oil and their nitro. every year here in ohio the Toledo Weak Signals put on a national swap meet and the big distributors are there so i got a good deal on the oil and nitro. that was about four years ago though.i had to get my methanol from a full scale race track but it got too expensive from there so i quit making it. it is BEST to mix a little castor with the synthetic oil to give better cooling of engine. just be sure to MEASURE the correct amounts of fluids. i.e.-- if you want 10% oil you would use 12.8 ozs. of oil....(128ozs. in a gallon divided by 10= 12.8).. then the same with the nitro also based on 128ozs... then fill the gallon the rest of the way up with the methanol... these are u.s. measurements so if you need metric ones just base it from that....hope this helps...
mbx5r
v-spec
jp-3 pipe
hitec 5955tg/steering
ko propo 2367/throttle
m-11
buckeye34 is offline   Reply With Quote
O'Donnell Racing Fuel vs. R2R Fuel SKOT Nitro Off-Road 4 12-28-2007 06:34 PM
Does anyone bother with making their own r/c fuel? ofnahyper Electric Off-Road 17 07-03-2007 06:01 PM
Making fuel last longer? jamiem1987 Electric Off-Road 6 07-31-2006 06:24 PM
<NEW> MONSTER TRUCK FUEL FROM MAXY'S PRO RACING FUEL !!!! <Maxy's> Nelson Racing Forum 0 11-08-2005 09:13 AM
Does O'Donnell fuel make a huge accel. gain on HPI fuel Smoke21 Nitro On-Road 3 05-03-2004 04:44 PM
