Old 03-22-2008, 02:29 PM   #1
ALG
Default Bowfighters
This combination is Bow ties up front and crime fighter at the rear???
What this combination use for steering, acceleration, other???
Thanks for your help
ALG is offline   Reply With Quote
Old 03-22-2008, 02:48 PM   #2
sharkman's Avatar
Trader Rating: 17 (100%+)
Switch it around.
bowties on the rear for foward bite and crimefighters on the front for more steering.
cumberland rc racers
8ight B 2.0 brushless
tekin rx8 1550kv
sharkman is offline   Reply With Quote
Old 03-22-2008, 02:51 PM   #3
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Originally Posted by sharkman View Post
Switch it around.
+1, sounds right.
If you ran the Bowties in front with CF in back, sounds like it would push in the corners off power.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 03-22-2008, 04:06 PM   #4
air8's Avatar
Originally Posted by ezveedub View Post
+1, sounds right.
Then would that combo be called CrimeTies?
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 03-22-2008, 04:07 PM   #5
sp2thielen's Avatar
Send a message via MSN to sp2thielen
is there a certain type dirt or track that this is best suited for???
IMPULSE RC when only the very best will do!!!!
Hobbytown Hobbyplex
Kyosho SP2/ Medial Pro
Kyosho ST-RR/ Medial Pro
sp2thielen is offline   Reply With Quote
Old 03-22-2008, 04:16 PM   #6
air8's Avatar
Usually outdoor tracks. Tracks that have a broken up surface or a rough surface.
Right now my buggy feels great with the Bowties rear and Crimefighters front. Our track is dry with a semi-packed surface. No groove or anything. It's not a smooth surface at all.
--"U Ain't Fast!!"
Chris Pearce
Old 03-22-2008, 05:07 PM   #7
sp2thielen's Avatar
thats what our track is. i will have to try that set up. thanks for the info
Hobbytown Hobbyplex
Old 03-22-2008, 05:26 PM   #8
SteveJa's Avatar
hey jeff..... works good on our track.... I ran this alot last year.......
SteveJa is offline   Reply With Quote
Old 03-22-2008, 07:33 PM   #9
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
I thought that was called Tie Fighters... only works if you're really really EVIL.
"Use the force Luke!"
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 03-22-2008, 07:37 PM   #10
If you are going to use that setup , you want to snip off the inside and outside row of knobs on the crimefighters. If you don't it will probably be too agressive on the steering.
RC Pro Products,Alpha engines,Spektrum , FASTLANE-GRAPHIX.COM,HP Hobbies and Trackside Designs
indaway is offline   Reply With Quote
Old 03-22-2008, 08:43 PM   #11
SteveJa's Avatar
yes that is a great point.....
Old 03-22-2008, 08:58 PM   #12
ALG
Thanks guys, I think this will be good at our track
I will try it out the "CrimeTies" combination,
Have fun
Old 03-22-2008, 09:06 PM   #13
spiti58's Avatar
before you totally cut off the out side row of nobs try them, if too agressive cut them at a 45 degree angle if still too agressive then cut them off all the way. the ones that i am running are cut at a 45 degree angle and they work awesome.
"Crime Ties"= Crime fighters on the front and bow ties in the rear easy way to remember Crime first = front, Ties second = back.
"U Ain't Fast!!"
"Thats how i roll, fast and out of control, nothins gonna slow me down! except mabye the occasional pipe."
spiti58 is offline   Reply With Quote
Old 03-22-2008, 10:37 PM   #14
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
You can also play with the compounds on the tires. I usually run M2's, but at times can be too hard and hooks a rut and rolls me over. Right now I run M2 in the front with the Crimefighters and M3 in the rear with the Bowties and will run the M2 Bowties depending on track conditions.
Teufel Racing is offline   Reply With Quote
Old 03-23-2008, 05:37 AM   #15
buckeye34's Avatar
i never thought of trying that...great tips guys!!!
mbx5r
v-spec
jp-3 pipe
hitec 5955tg/steering
ko propo 2367/throttle
m-11
buckeye34 is offline   Reply With Quote
Bowfighters Theory bobbyblaze Nitro Off-Road 73 09-27-2008 11:11 AM
