Old 03-20-2008, 06:43 PM   #1
levi m's Avatar
Default BEST LOSI 8B UPGRADES?
hi i have a losi 8b the rtr version ive got a v spec and good servos and radio gear in it but what can i do to make it a good race car ive also put king headz motor mount and radio tray brace in it
any opinions would be greatly appreciated
o btw i have about 150$ to spend
IMPROVISION IS THE KEY TO SUCCESS!
**PROUD OWNER OF A TRAXXAS PRODUCT**
levi m is offline   Reply With Quote
Old 03-20-2008, 07:04 PM   #2
I found a shock tower set on ebay. I got rid of the stock silver ones and went with the roller ones. I also have the flex chassis on order.
Losi 8ight-B, flex chassis, O.S. .21
Losi 8ight-T Race Roller, JR 9000 T&S, O.S. MAX 28XZ
Spektrum DX3R
Losi Modified Aftershock
HPI Baja 5B
rescuemann is offline   Reply With Quote
Old 03-20-2008, 07:04 PM   #3
aluminum rear diff inserts, and maybe get one of those new revised diffs they just came out with
mad316 is offline   Reply With Quote
Old 03-20-2008, 07:12 PM   #4
levi m's Avatar
were can i find one?
Old 03-20-2008, 07:32 PM   #5
this is the diff upgrade I was talking about http://losi.com/Products/Features.aspx?ProdId=LOSB3528
this is for the center diff http://losi.com/Products/Features.aspx?ProdId=LOSA4442
this is for the rear diff
http://www.tiltedrc.com/product_info...roducts_id=457
Old 03-21-2008, 12:02 AM   #6
If it's the RTR get rid of the chassis and the shock towers. Take the motor out and the clutch bell and make it a 4 shoe clutch instead of the 2 shoe it comes with. You can if you want replace all of the hindge pins and shock shaft with tini ones.
Thats a start.
LosiMadMan is offline   Reply With Quote
Old 03-21-2008, 01:01 AM   #7
BOOST's Avatar
What are you on about??
The RTR comes with the 4 shoe clutch.
BOOST is offline   Reply With Quote
Old 03-21-2008, 02:04 AM   #8
thecman26's Avatar
Trader Rating: 98 (100%+)
Lightbulb
I know what he means.. The rtr comes with 2 shoes in the 4 shoe clutch....
Just put 2 more shoes in it....
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 03-21-2008, 04:09 AM   #9
tex1's Avatar
Send a message via Yahoo to tex1
Wink
Actually they changed the clutch. It comes with 2 alum and 2 plastic now. It works pretty well but will go away quick.
What I would get a set of hard Alum shoes and run 3 alum and 1 plastic to get a smooth long wear clutch setup. 2 gold and 2 silver springs. 1 gold is on the plastic. $25
Front shock tower. Used will work fine. $15 The rear tower is somewhat protected by the wing so you may be able to get by without it.
Alum Shock caps. These are a must. You are going to have to rebuild your shocks for racing anyways. Front = 54/40 Silver & Rear = 56/35 Green. That is piston type, oil and spring for both ends. $35 for tops and set of rear springs.
Alum inserts for the rear diff case. $20
Change your diff's grease out for real oils. 5-7-2 works fine to just get your feet wet. I run 4-6-3 just about everywhere. Stick with whatever brand your LHS carries the most of. $20
You will want and alum servo horn for your steering servo. $7
The chassis is made of 7075 hard aluminum. Run it for the first year. The hingepins are the same material as the racers they are just not coated. I have been racing for 26 years and can't tell the difference. You will be fine with them. The shock shafts are the same.
Thats $122 If you are creative it can be less.
I would buy myself some good rubber just for the track. Check with your local hotshoes for this one. Longivity is the key here. Find out what they practice with and race with and then look at something in between.
You will want a good pipe for that engine. The stock pipe will be a hand full.
Find a used OS 2050 or a JP-2 and you will not go wrong.
Good Luck, keep it in the middle and have fun!
TEX
tex1 is offline   Reply With Quote
Old 03-21-2008, 08:43 AM   #10
levi m's Avatar
ive got a JP 1 BUT WOW THANKS FOR THE ADVICE is the shock towers the ones from the pro version because i found some used on ebay
Old 03-21-2008, 09:10 AM   #11
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
I run the JP-1 on my Werks 7 port... I think the power band is similar. I run the 14t clutch bell to tame the bottom a bit... remember, the JP-1 is a low-end pipe. I'm also running a 5.5 restrictor! 8-9 minute runtime with my "on/off switch trigger finger" that I need to replace or at least re-train. (Tex was trying to coach me... and I really WAS listening... just my finger doesn't obey what I tell it!)
and...
I run a Mugen clutch setup with the Losi bell. (yes, this works) It is easier to get parts for the "industry standard" 3 shoe clutch. I was running all aluminum shoes with 1.0 springs, but that's pretty "snappy." I'm currently trying it out with 1 carbon and 2 aluminum. (Mugen flywheel, Mugen shoes, Mugen springs)
What Tex told you on parts will get your buggy up to "race spec." The 8ight is an awesome buggy, and the RTR is much better than most.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 03-21-2008, 06:42 PM   #12
levi m's Avatar
i bought a metal servo arm today but were can i get those shock springs here is what all i plan to buy:
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=014
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=001
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=330220325565&ssPa geName=STRK:MEWA:IT&ih=014http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=008
Old 03-21-2008, 06:44 PM   #13
levi m's Avatar
hey mad is this wat you were talkign about?http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=014
Old 03-21-2008, 09:15 PM   #14
Nik
Nik's Avatar
no that is not the diff, you want this http://www.losi.com/Products/Feature...rodId=LOSB3528
Nik is offline   Reply With Quote
Old 03-21-2008, 10:51 PM   #15
Suspended
Trader Rating: 34 (97%+)
The TiNi shafts and hinge pins are a waste since the TiNi coating wears off in under a gallon of use.
FG101C is offline   Reply With Quote
Team Losi LST Upgrades - NIP!!! minimadman2003 R/C Items: For Sale/Trade 17 03-04-2008 06:51 PM
Losi 8 RTR roller with pro upgrades. rossoh10 R/C Items: For Sale/Trade 10 10-04-2007 05:10 PM
Team Losi MF2 W/CR upgrades mrhenning11 R/C Items: For Sale/Trade 5 09-06-2007 06:42 PM
Losi XXX-NT with Picco/upgrades FS/FT SpeedChair R/C Items: For Sale/Trade 3 12-19-2003 05:35 PM
*** Losi XXX buggy with upgrades FS/FT *** KenSmith R/C Items: For Sale/Trade 2 09-06-2002 01:54 PM
