Old 03-19-2008, 02:22 AM   #1
david94's Avatar
Default please help
hey
i have been having some trouble with my 1/8 truggy, when i try to start the car on the starter box it starts the car backwards so when i put it on the ground it drives backwards it does it every time can you please help me.
The truggy is a hobao hyper st pro rtr with the macstar 28 pullstarter the pullstarter brock and i took the spring out and the cord out. the starter box is the OFNA Universal Starter Box with the twin motors.
thanks
david94 is offline   Reply With Quote
Old 03-19-2008, 03:25 AM   #2
BOOST's Avatar
It is pretty damn obviuos the starter box needs to be rewired.
BOOST is offline   Reply With Quote
Old 03-19-2008, 05:16 AM   #3
lowey79's Avatar
How does it run backward? nitro engines are timed (crank porting) to run in 1 direction
lowey79 is offline   Reply With Quote
Old 03-19-2008, 06:40 AM   #4
slaytanic's Avatar
Trader Rating: 20 (95%+)
They will run backwards but like crap.
slaytanic is offline   Reply With Quote
Old 03-19-2008, 07:37 AM   #5
petevette's Avatar
Send a message via Yahoo to petevette
Have you recently serviced the diffs? If so, they may be in backwards. Is starter box spinning the engine counter clockwise?
petevette is offline   Reply With Quote
Old 03-19-2008, 07:48 AM   #6
GSPOT's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to GSPOT
FORWARD = REVERSE?
VTA member #126
GSPOT is offline   Reply With Quote
Old 03-19-2008, 07:58 AM   #7
Trader Rating: 27 (100%+)
Just reverse the way you have the starterbox positive and negative wires on the battery.
jbrow1 is online now   Reply With Quote
Old 03-19-2008, 03:30 PM   #8
Trader Rating: 47 (100%+)
If your standing at the end of the starter box
that the back of your car sets on and run the starter
box motor. The starter box wheel should be turning
counter-clockwise. If not, then switch the battery
or motor wires, which ever is easier.
rageworks is offline   Reply With Quote
Old 03-19-2008, 04:14 PM   #9
DR ZAIRUS's Avatar
Yup!! As said, check out if the starter box turns in the right direction (if you're not sure, test your car with another starter box, or the box with another car).
It could also be the front and rear diffs are in backwards. When you install them, the teeth should be on the left as you look at the front diff from the front and same as you look at the rear of the car for the rear diff.
Hope it helps....
Hong Nor/Jammin' X2
Picco P7 Evo3+JP3
Futaba+KO Propo.
TEAM www.fisio-sport.com
(Valencia, Spain)
DR ZAIRUS is offline   Reply With Quote
Old 03-19-2008, 04:45 PM   #10
losi guy's Avatar
Trader Rating: 38 (100%+)
Send a message via ICQ to losi guy
As Dr Z said if you truggy is running backwards then your diffs are in wrong. When I put my pro kit together i noticed they could go in either way and its really easy to pull them out and turn them around.
Spektrum | Avid | DE Racing | Tekno
losi guy is offline   Reply With Quote
Old 03-20-2008, 01:31 AM   #11
david94's Avatar
hey
thanks everyone i rewired the starterbox and it runs forwards
Old 03-20-2008, 07:06 PM   #12
TeeKuang's Avatar
Originally Posted by david94 View Post
hey
Hyper ST? Check your front and rear diff, the crown gear suppose to be at left side.
Best Regards, Tee Kuang
Rovan 290S
Killer Bee Kill switch | Outerwears | hydraulic brake | Ace DS-1015 |ADA Rear billet hub bearing carrier | Hostile Nightmare MX | RCMOD Closed clutch |
Gasoline POWER : Malaysia Large scale hobby
TeeKuang is offline   Reply With Quote
