Old 03-17-2008, 10:46 PM   #1
Default What truggy engine to buy
This will be my first truggy and not sure what engine to buy. I like O.S. but not sure what to buy. I am building a X-Ray Truggy to race in the Texas R/C Pro series.
Thinks,
Ronnie C.
RONNIE C is offline   Reply With Quote
Old 03-17-2008, 10:59 PM   #2
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Try the OS 28ZX. I would add the hyper flywheel also. Engine screams hard.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 03-18-2008, 12:30 AM   #3
Colt4g63's Avatar
I am really fond of the Vspec's and the P7Rs
Adam Blevins Owner/Operator of AB Mods X-Dyno equipped and World Record holding engines!
www.ABMods.com
Colt4g63 is offline   Reply With Quote
Old 03-18-2008, 05:07 PM   #4
I would recommend the falcon motor. The 21 is very smooth and has plenty of power for a truggy but if you want more get the falcon.28.
blowpopracer is offline   Reply With Quote
Old 03-19-2008, 05:34 AM   #5
I have the O.S. .28 in my truggy right now and it is awesome.
Losi 8ight-B, flex chassis, O.S. .21
Losi 8ight-T Race Roller, JR 9000 T&S, O.S. MAX 28XZ
Spektrum DX3R
Losi Modified Aftershock
HPI Baja 5B
rescuemann is offline   Reply With Quote
Old 03-19-2008, 05:43 AM   #6
portyansky's Avatar
Trader Rating: 54 (100%+)
Vspec!!!!!
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Old 03-19-2008, 07:03 AM   #7
v-spec is the way to go. its smooth and has plenty of power. if you have a little extra money i would buy the O.S speed v-spec. it has a lot more power than than the v-spec but its still smooth
wallnutz684 is offline   Reply With Quote
Old 03-19-2008, 07:08 AM   #8
Maximo's Avatar
actually the OS Speed is less powerful then the regular V-Spec...the OS Speed has a weighted crank which will slow down and smooth out the low end...and it doesn't carry upper power like the regualr Spec..it also makes slightly less torque...the Speed does make slightly more peak HP at 1 point in the powerband............But the OS Speeds only advantage is its smoother and wont spinthe tires as badly on a loose track...... I have both motors as well as dyno results tocback that up....OS Speed is not more powerful then a regular V-Spec... in fact the regualr v-Spec is more explosive and carries better upper RPM HP...
Maximo is offline   Reply With Quote
Old 03-19-2008, 12:08 PM   #9
ezveedub's Avatar
This I find very, very hard to believe. I personally have seen the V-Spec and OS Speed line up, and the OS Speeds that I have have broke-in and tuned kill regular VSpecs. I have several friends with VSpecs and they can attest that the Speed is indeed faster and much more explosive.
Old 03-19-2008, 12:45 PM   #10
Maximo's Avatar
actually if you think about it, the OS Speed was designed to be a smoother version of the V-Spec... they have the same timing, different head buttons, and a different crank design..the main performance difference is the weighted crank.... which has the same effect on the motor as adding a heavier flywheel.... More ballast to resist rapid RPM change, as well as accelerations during the crank rotation.... The weighted cranks allow a motor to be less prone to tire spin, which is some cases will result in faster acceleration due to increased traction......I am not saying the Speed is a bad motor, but saying its vastly more powerful then a regular V-Spec is anything but the truth..
run a OS Speed and a 2007 V-Spec on grass using grippy tires and you will see right away the Speed is not as explosive....
Old 03-19-2008, 05:27 PM   #11
I have a friend who races OS Speeds and he says the same thing. The regular V-Spec is more powerful.
Ken4 is offline   Reply With Quote
Old 03-19-2008, 10:54 PM   #12
Well its between the O.S V-SPEC AND THE O.S. 28XZ. Is the 28 as good a quality as the V-Spec?
Old 03-19-2008, 11:37 PM   #13
Mr. Stiles's Avatar
RB C6 BB7T amazing motor. Enormous ammounts of power and if broken in properly will last a LONG time
Mr. Stiles is offline   Reply With Quote
Old 03-20-2008, 12:06 AM   #14
thecman26's Avatar
Trader Rating: 98 (100%+)
If money is no option...
I second the vote for the RB C6...
With the RB 2045 pipe it has incredible bottom end and MIND NUMBING top end! Absolutely the sickest motor I have ever seen on the track! All this and pretty damn good fuel economy to boot! I would have one tomorrow but I have 2 problems... I suck at driving so the power is too much for my meager skill set and the combo is over $400 which is a lil rich for my blood... So I am stickin with the S3 for now...
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 03-20-2008, 12:56 AM   #15
I have a new C6 & 2045 combo mounted on my lightweight LS2P, but i dont find it that powerful. But my XZ mounted on my old & heavy LSP-R really is brutally powerful. The C6 comes stock with 7mm restrictor, so maybe that explains why its so weak. The stock XZ comes with 9mm restrictor and the power was SO untamable the rpm wouldnt spool down fast enuf which made it difficult to drive, esp when jumping. I finally tamed it down by putting in a 8mm restrictor and adding 1 head shim. Which is more fun to drive? The XZ anytime. But for race, I would use the C6 for its fuel efficiency.
Fast Truggy motor. Dynamite Platinum .28 SG Off-Road Truggy Engine Mpowerz R/C Items: For Sale/Trade 2 01-23-2008 12:14 AM
NOVAROSSI rx21r1wc "Kangaroo" Engine (1/8 Onroad) $225 or Trade for truggy engine! BIGTACO R/C Items: For Sale/Trade 15 08-30-2007 09:21 AM
Orion Wasp Pro .28 engine .... would be a great truggy engine ... F/S... tradhunt R/C Items: For Sale/Trade 7 08-07-2007 11:56 AM
TRUGGY ENGINE. Mambo Singapore R/C Racers 13 06-25-2007 07:37 AM
what engine for my truggy German Muscle Onroad Nitro Engine Zone 25 05-06-2007 09:29 PM
