Old 03-20-2008, 01:38 AM   #16
thecman26's Avatar
Trader Rating: 98 (100%+)
Wheres Mike Elam when somebody needs info about the fabled RB C6??? Hmmm.... Probably working...
He is the guy aroud here that has known the power of the C6 and lived to tell about it... I was his pit guy several times and I was thuroughly impressed with not just the power but the fuel economy! With the right tune those things tear it up!
I would also give a nod to JP FX engines... they are very sweet too!!!!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 03-20-2008, 02:46 AM   #17
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Sirio CL7B STI.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-20-2008, 05:17 AM   #18
I have the speed and the 28xz, the 28 is by far the most impressive engine i've owned.Its power is never ending and its very good on fuel ( 8.30- 9mins in my 8ight T)
LOSI 8IGHT 2.0 ALIGN SERVO'S, RB C5bb,RB C6 L2G,PICCO P7R EVO2,
ASSOCIATED RC8T, NOVAROSSI .28 8PORT, SAVOX SERVOS.
CRT.5 SH .12,
damo666 is offline   Reply With Quote
Old 03-20-2008, 08:52 AM   #19
Maximo's Avatar
The most impressive engine for Truggy is the GRP/Ninja 28......Its not quite as explosive down low as the OS 28, but it pulls pretty good from the OS in the upper midrange and top end...The OS 28 I felt was a little too heavy handed on the low end, and not quite strong enough on the top end....I felt the GRP/Ninja 28 had a better balanced powerband then the OS 28....Of course both motors are killer engines, and choosing between the two is picking straws.
.21 for Truggy I have to recomend the Picco P7R/Jammin JPX engines...... These motors have an excellent powerband and make really big power and torque... Believe it or not but the Picco is actually more powerful then even the mightly RB C6.... So in a Truggy the Picco is a dam fine choice.....
If you want the ultimate Truggy engine contact either Adam at AB Mods or myself for a modified Picco or V-Spec....These motors are strong stock, but once modified they enjoy a substantial jump in power output from bottom to top....
I also have modified the RB C6, once modified its an absolute screamer of an engine...... The C6 is very restricted from factory and responds huge to timing mods.. for some reason RB decided to vent 90% of the C6's exhaust out 30% of the exhaust port volume......
Maximo is offline   Reply With Quote
Old 03-20-2008, 02:24 PM   #20
Mr. Stiles's Avatar
If you are looking for a race application engine, spend the money on a better .21. You will get longer run time between pit stops in the main. Also, they are a little bit easier to handle than a stupid fast .28 that gets only 7-8 minutes between pit stops. Where as the RB C6 BB7T (modified by RBmods) in my Losi 8ight T gets at least 10 minutes between stops. Just another reason to buy a good .21 versus a huge .28+ size engine.
Mr. Stiles is offline   Reply With Quote
Old 03-20-2008, 03:04 PM   #21
I agree that a good .21 is the way to go if you are just starting out. My choice would be a V-Spec also as that is easy to tune and holds that tune very well. next would be the RB C6T7.. good luck with your choice
Mechmark is offline   Reply With Quote
Old 03-20-2008, 06:51 PM   #22
houston's Avatar
Trader Rating: 91 (100%+)
nova plus 21-5k ! this thing has it all seriously excellent porting design to use as much fuel for power as is possible =great torque , smooth pull and ripping top end !!!!! and the bearing issue has all but disappeared on the plus engines ,and if you happen to have a problem try the tko bearings . peter is an awesome guy and i will be testing his new ceramic bearings for the plus engines . i will keep you posted !!! i am sure they will be the $h!t !!!!
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 03-21-2008, 06:58 PM   #23
houston's Avatar
Old 03-22-2008, 12:54 AM   #24
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
My pick would be an O.S. or Novarossi. Lets see what the new Novarossi .28 engine line up has to offer this year. Also, if you go O.S., make sure to get the Hyper flywheel.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 03-22-2008, 06:28 AM   #25
Maximo's Avatar
I am curious to see if the new Nova 28's are smooth and tractable.... i see Novarossi has kept the new .28 using the same geometry as the current 528, with a long 17.6 mm stroke...Usually a long stroke motor makes its power more efficiently at lower RPM's and tends to fall off in the top end..so I am curious if these new 28's are actually smooth and usable, or will they be insane torque monsters with uncontrollable low end... Are the new cranks slugged ?
Old 03-22-2008, 11:08 AM   #26
Originally Posted by Ken4 View Post
I have a friend who races OS Speeds and he says the same thing. The regular V-Spec is more powerful.
Wow!!!
hello is offline   Reply With Quote
Old 03-22-2008, 02:16 PM   #27
MadRussian's Avatar
GRP .21 (or Ninja) is awesome!
MadRussian is offline   Reply With Quote
Old 03-22-2008, 07:01 PM   #28
I run my Xray xt8 truggy. With the os .28 and it is awsome I use the standard flywheal and it works fine. With mugen fibers and 1.0 springs and the truck is ballistick. I also own the new sirio cl7b sti. Great motor very smooth and toque for .21 because of the long rod. The rb is a great engine to. But I will kepp my .28 I 10 plus with the motor and dont have to spend alot of money alumiun shoes. Also with the fibers the truck will clear what ever you throw it. are tripple is over 32 feet and most of the truggies with the .21 sometimes dont clear. I say add another 10 foot to pleanty of power. Also try rocco silver state setup on xray. truck was awsome tons of stearing everywere.
froggiematt is offline   Reply With Quote
Old 03-22-2008, 07:08 PM   #29
Trader Rating: 30 (100%+)
Default o.s. .28
o.s. .28 is the only way to go unless you have time to wait a month for the new grp line of engines to come out i have had a few .21 engines in my truggy and the .28 is better then all of them it is smooth when tuned right and will get 8-9 min. run timew with the red restrictor in the carb the motor rips but at the same time if you have ever seen a mugen-grp .28 you will know they are very fast and now that grp and mugen arent together anymore and grp is coming out with thier own motors they are going to be top knotch hense the reason alot of pros are signing on to run them
jewn_beef is offline   Reply With Quote
Old 03-23-2008, 06:42 AM   #30
Trader Rating: 36 (100%+)
Default engine
whatever you do, please don't buy a Werks .28 pro. If you do ,as soon as u get it , throw the carb as for as u can throw it. I've a piston and sleve on order ( from werks) since Dec. Has good power on the low but os, go, rb was killing me on mid and top end. Go with a .21 It does not take much power to be fast. Smooth is fast....
Mik G is offline   Reply With Quote
Fast Truggy motor. Dynamite Platinum .28 SG Off-Road Truggy Engine Mpowerz R/C Items: For Sale/Trade 2 01-23-2008 12:14 AM
NOVAROSSI rx21r1wc "Kangaroo" Engine (1/8 Onroad) $225 or Trade for truggy engine! BIGTACO R/C Items: For Sale/Trade 15 08-30-2007 09:21 AM
Orion Wasp Pro .28 engine .... would be a great truggy engine ... F/S... tradhunt R/C Items: For Sale/Trade 7 08-07-2007 11:56 AM
TRUGGY ENGINE. Mambo Singapore R/C Racers 13 06-25-2007 07:37 AM
what engine for my truggy German Muscle Onroad Nitro Engine Zone 25 05-06-2007 09:29 PM
