Old 03-21-2008, 05:49 AM   #16
Trader Rating: 66 (99%+)
pwnzor is offline   Reply With Quote
Old 03-21-2008, 08:45 AM   #17
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Originally Posted by Mugen MBX-5 View Post
since you know how to use it... i have this battery: http://www.carolinasrc.com/webstore/...idproduct=6095
what numbers am i supposed to have on the charger?
i put it at 1600 mah (obviously)
but theres the "A" number which i cant figure out, so i put it on 1.0
and theres another number which i cant remember, and have no clue as to what its supposed to be on.
i have a feeling im not charging my batteries properly
The first 2 numbers are right. That's 1600 mah and 1 amp charge rate. DO NOT EXCEED 1 amp for that pack! Duratrax recommends the sensitivity (3rd setting) be set to 6Mv/c for NiCd and 8Mv/c for NiMH batteries. That setting determines how sensitive the charger is on peak detection.
My racing buddy helped set mine up initially... he has had one for a long time and recommended this charger to me. After it is set up initially it is easy to use... just press the center button until the preset number flashes, the + or - to select which one, then press again to stop the flashing, then press and hold until it beeps. It will play a little tune for you when it peaks... it also gives an audible warning if the battery gets disconnected (can happen on a busy pit table) or if you have the polarity reversed when you connect it.
NOTE: Regarding settings...
I use 1 amp charge rate for my hump pack, but only .8 for my 2300 mah transmitter batteries. I also use this charger to charge my starter box battery... the big heavy lead-acid one. Works like a champ, although I don't remember the settings.
You can download the manual here:
http://manuals.hobbico.com/dtx/dtxp4005-manual.pdf
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 03-21-2008, 01:10 PM   #18
Mugen MBX-5's Avatar
yeah, mv/c was the other thing i forgot about. mines currently set at 3.0, i dont know why, i just put it there.
i know how to use it, i just wasnt too sure about what the numbers should be, and manual that came with it was just a 4x5 inch piece of paper that explained how to use it and thats all.
you can charge your starter box battery too? is that with the 2 prongs coming off the back? i thought those were to hook up to a battery source instead of a wall. a power intake not output?
and yeah, this is an awesome charger. it even tells you how much MAH is puts into the battery, right?... or what is that number that goes up while its charging? i assume its the amount of "juice" thats put into the battery?
and that link didnt work, but dont worry about, i dont need it anyways. thanks for the help.
I dont race. Please dont assume I race. I only bash around.
T Lawrence is a scamming scumbag
Tonys Screws l carolinasrc.com l spektrum (?)
Mugen MBX-5 is offline   Reply With Quote
Old 03-21-2008, 02:42 PM   #19
more$thanbrains's Avatar
Send a message via MSN to more$thanbrains
I use the traxxas charger for my reciver packs
works great and have a nice LONG lead
small, light, functional
Xray~Titan~Ko Propo~Orion~Muchmore~Dekelz.com
T2 007 US/EU~CRC Gen-XL~MO3-Pro~NT1~Corally C10X
'73 Ford Bronco sittin on 36" swampers~ 10" lift
more$thanbrains is offline   Reply With Quote
Old 03-21-2008, 05:11 PM   #20
fengraul's Avatar
MRC Super Brain 960 AC/DC Peak Charger (NiCD and NiMH)
user friendly and great features
perfect for both field and home
price is awesome too
http://www.amainhobbies.com/product_...ducts_id/13174
BHP is how hard you hit the wall, Torque is how far the wall moves after you hit it!
Sponsored by: TD Canada Trust----my chequeing account
fengraul is offline   Reply With Quote
Old 03-21-2008, 05:56 PM   #21
Regional Moderator
CarbonJoe's Avatar
Here is what I use for Rx packs. It does NiCD, NiMH, and LiPo, and can do two packs at once.
http://www.hobbico.com/chargers/hcap0290.html
$49.99 at Tower
http://www3.towerhobbies.com/cgi-bin...0290&search=Go
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 03-21-2008, 06:03 PM   #22
portyansky's Avatar
Trader Rating: 54 (100%+)
I have been using this for over 2 years without any problems. http://www3.towerhobbies.com/cgi-bin...&I=LXLCJ6&P=ML
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
WTB a GOOD charger for race packs xrayflorida R/C Items: Wanted to Buy 7 06-19-2008 01:10 PM
Whats a good battery charger? AC/DC pracy Radio and Electronics 5 04-30-2008 03:06 PM
whats is a good charger to charge 4200mah batt & 1-3 lipos asc0989 Radio and Electronics 0 10-21-2007 09:15 PM
WTB: 2 Super Cheap 6-cell packs and a charger Verhalas R/C Items: Wanted to Buy 0 04-07-2006 02:20 AM
WTB: Cheap but good CHARGER Michael Barch R/C Items: Wanted to Buy 2 02-25-2006 01:45 PM
