Old 03-14-2008, 07:05 PM   #1
37 RACING's Avatar
Trader Rating: 43 (100%+)
Default engine break in
I got a Adam Drake Platinum Draked version .21 and it say to break it in buy holding it wide open for 5 tanks!It says richen 3 full turns and holder open!Sounds kinda crazy!
has anyone ever used thje drill method!
37 RACING is offline   Reply With Quote
Old 03-14-2008, 07:20 PM   #2
ALG
sound like Cyrul method,
taka a look at the forum, you will find alot of info on how to run in an engine. Choose one ad stay with it.
ALG is offline   Reply With Quote
Old 03-14-2008, 07:39 PM   #3
HuntersDad's Avatar
Trader Rating: 38 (95%+)
LOL
HuntersDad is offline   Reply With Quote
Old 03-14-2008, 07:39 PM   #4
James khoo's Avatar
Trader Rating: 15 (100%+)
Send a message via Skype™ to James khoo
Try the method at RBproducts.com.
It worked fine for me.
Cheers
James khoo is offline   Reply With Quote
Old 03-14-2008, 07:44 PM   #5
37 RACING's Avatar
the insructions are real disappointing on these motors!This is my first high end motor!Wish i would have went RB!
Old 03-14-2008, 08:21 PM   #6
I did the wide open method and it works pretty well,just don't go wide open work your way up while richening so when it is wide open its so rich it can't rev too high the idea is to use fuel to cool it in between cycles its best to have someone to help.
dogger is offline   Reply With Quote
Old 03-14-2008, 09:15 PM   #7
i have done serveral break in methods and holding wide open really rich works the best for me and other racers i know the engine is so rich the tires barley move
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 03-15-2008, 06:56 AM   #8
The only thing that bothers me about that is the temps.
Does the engine get up to the 200f+ range and do you do all 5 of those tanks on the box and after that the engine is run in
Megacrash is offline   Reply With Quote
Old 03-15-2008, 08:13 AM   #9
Nitroaddicts's Avatar
Great breakin guide here by ron paris.
www.NITROADDICTS.com
Get Free T-Shirts with Nitro Points!
Need Track TShirts?
http://www.facebook.com/AmericanGFX
Nitroaddicts is offline   Reply With Quote
Old 03-15-2008, 01:19 PM   #10
houston's Avatar
Trader Rating: 91 (100%+)
heat cycle the engine 2 times then do the throttle up method , heat cycling is the trick at least 220 degrees F as soon as you can get it there while running . best results are varying throttle and running the car on the ground , dont let the engine really hit the powerband
monty
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 03-15-2008, 02:25 PM   #11
i have used this method for years! RB uses it to break in their engines. you have to use a heat gun to keep the temps up while you are running it wide open that rich. this method equals nice high temps with a heat gun about 240 while running the engine with max oil and fuel!
dubdeuce is offline   Reply With Quote
How not to break in an engine ! Maximo Nitro Off-Road 4 08-05-2008 09:34 PM
Engine break-in ? acsubie Electric Off-Road 3 05-11-2007 07:42 PM
How do you break in an engine? joe of loath Rookie Zone 12 03-26-2007 03:08 AM
RB V12 engine break in help alucard13 Nitro On-Road 7 08-31-2003 08:34 PM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 10:49 PM
