Old 03-12-2008, 02:19 AM   #1
Trader Rating: 22 (100%+)
Default Engine Ports?
kind of a noob question about engine ports
what are the main differences with more ports in an engine?
I'm guessing that more ports make it faster? perform better?
like a 3 vs a 5 vs an 8 port engine?
there are also those added ports such as 5+2 port engines.
please explain
thx
phixd is offline   Reply With Quote
Old 03-12-2008, 02:42 AM   #2
GenReaper's Avatar
Send a message via MSN to GenReaper
Less ports generaly have more bottom end grunt.
Good for short technical tracks.
More ports generaly have better top end but less bottom end.
Good for high speed longer tracks.
Booster ports act like having more ports but are designed to help increase intake charge on the down stroke.
Generaly most motors perform alot better all round with some minor porting work.
Heres a short video of my 3 Port which is modified and running very rich in 37 degree heat, as you can see even tho its fat and a hot day and only a 3 port it still has major balls down the straight with great revs. It will keep up with any 7 port easy if not blow it away.
When i run it a bit leaner it revs even harder but was a hot day so didnt want to kill it.
http://www.zone3adelaide.com/rcmovie...actice2008.wmv
Trex 700E 12S Scorpion 4035 560kv
Trex 600E
HPI Baja 5B SS
My videos : http://www.youtube.com/profile?user=genreaper
GenReaper is offline   Reply With Quote
Old 03-12-2008, 04:45 AM   #3
air8's Avatar
HOLY CRAP!!!! What kind of surface is that? You must be using like 100wt oil or something. J/K. Looks like a real rough surface though.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 03-12-2008, 05:22 AM   #4
GenReaper's Avatar
Dunno what sort of surface the Club calls it but i call it "Ballz Up"
Trex 600E
HPI Baja 5B SS
What size/no. of ports engine for all out performance? Jonro Nitro Off-Road 14 06-13-2008 08:14 PM
Is the number of ports in engine really tied to performance? jasoncsc Onroad Nitro Engine Zone 7 05-08-2004 11:08 PM
Sirio S12 TUP PRO Engine (5+2 ports) hashini Malaysian R/C Racers 16 03-30-2003 04:04 PM
3 Or 5 ports Engine? Cloro Nitro On-Road 3 11-28-2002 12:43 PM
