Old 03-11-2008, 02:43 PM   #1
paco62's Avatar
Default Another Variation of the same old...
Sorry if this is redundant, I've seen variations of this question for different engines but couldn't find the answer for O.S. by searching the threads.
I have an O.S. .21 VG with a JP-4 pipe. I am getting good smoke, what appears to be minimal fuel out the exhaust (should there be any at all?) and it seems to accelerate well both low and on throttle, but my temps seem consistently between 215-240. When I pinch the fuel line, it cuts the engine in about 3-5 seconds, which I read is an indication that it is neither too rich nor lean, but was concerned about the temp. as I thought you should run about 200.
Should I be concerned?
Thanks for the help.
paco62 is offline   Reply With Quote
Old 03-11-2008, 02:46 PM   #2
buckeye34's Avatar
215-240 is fine.. the one thing you really don't want to do is tune to temp.as long as you are getting good smoke, and good throttle response you are good to go. you can use the temp gun to give a "ballpark" estimate. but as before, good smoke and good throtttle response= happy engine.
mbx5r
v-spec
jp-3 pipe
hitec 5955tg/steering
ko propo 2367/throttle
m-11
buckeye34 is offline   Reply With Quote
Old 03-11-2008, 02:46 PM   #3
xlgraphicspro's Avatar
no, your fine under 240 you could even get as hot as 270 and still be fine. 230 is a good baseline for opperating temp.
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 03-11-2008, 02:49 PM   #4
Trader Rating: 36 (100%+)
Try to learn to NOT! tune by temp. While it is a good idea to use temp as a rough guesstimate, total performance is your main goal. Learn how the engine runs best, top to bottom and in between. Engine temps are going to be affected by many things. Ambient temp, humidity, clean vs dirty air filter, etc etc etc. Performance is your best guage Do you race? Someone at your local track should be able to help you out on raceday
NitroOB4You is offline   Reply With Quote
Old 03-11-2008, 03:27 PM   #5
paco62's Avatar
Great information, thanks!
I am going to race, but this is my first nitro car, hence first engine so I am probably being a little too by the bookish (is that a word ). I appreciate all the good info. and feedback.
Old 03-15-2008, 08:18 AM   #6
Moderator
pc9840's Avatar
Send a message via ICQ to pc9840 Send a message via AIM to pc9840 Send a message via Yahoo to pc9840
When in doubt... Lean it out!!
Jesse@pc9840.com <><
"The minimum wouldn't be the minimum if the minimum wasn't good enough"
pc9840 is offline   Reply With Quote
Coned Comm-How much variation is ok? Cardboard Electric On-Road 5 08-12-2004 07:26 AM
