Old 03-11-2008, 09:06 AM   #1
Crim3Wav3's Avatar
Default Smallest restrictor for stock v-spec carb???
as the title says, what is the smallest carb restrictor for a regular v-spec carb?
Whre can you get it? I have the 8 and 9mm that came with it stock, but am curious as to how small they are offered.... Are there aftermarket companies making any? Will any other brands (Novarossi, etc) work?
i've done alot of searching but can't find any info........
anybody?
Crim3Wav3 is offline   Reply With Quote
Old 03-11-2008, 09:40 AM   #2
Regional Moderator
CarbonJoe's Avatar
Not sure if this will fit, but it is made for the OS Speed .21, which is V-Spec based. The carb, however, is different.
http://www3.towerhobbies.com/cgi-bin...&I=LXRJR8&P=SM
On that page, they state "For the stock 5.5mm reducer use OSMG2476", which is for the .12 TZ carb.
Try contacting them and see.
http://www.osengines.com/techsupport/index.html
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 03-11-2008, 09:49 AM   #3
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
i have run a 5.5 and 6 before and both of them really bogged down the motor way too much. I have settled with a 7.5 right now.
micrors4guy is offline   Reply With Quote
Old 03-11-2008, 10:15 AM   #4
Crim3Wav3's Avatar
it will be for a JP Mod V-Spec....
Micro: where did you get the 7.5?
Old 03-11-2008, 10:19 AM   #5
its a nova restricter.
Old 03-11-2008, 11:10 AM   #6
buckeye34's Avatar
a main carries these for $34.99 and they have them in stock. here is the part number....IND-IDV-063S... they are aluminum and 6,7 and 8mm inserts
mbx5r
v-spec
jp-3 pipe
hitec 5955tg/steering
ko propo 2367/throttle
m-11
buckeye34 is offline   Reply With Quote
Carb Restrictor TC3ElectricGuy Nitro Off-Road 35 04-05-2009 05:50 PM
New Go 3 Port R / 0801 pipe / carb restrictor set brianr34 R/C Items: For Sale/Trade 0 08-01-2008 05:06 PM
Mugen X12... better without carb restrictor? Wildewinds Onroad Nitro Engine Zone 3 09-10-2004 07:49 PM
Wasp carb restrictor/venturi? j240z Onroad Nitro Engine Zone 3 05-14-2004 09:24 PM
Carb restrictor thefuzzclub Nitro On-Road 5 09-13-2003 08:47 PM
