Old 03-13-2008, 11:21 AM   #46
Crim3Wav3's Avatar
JP Racing N21B-2002JP 7 Port
Friggin' awesome deal on them at PDL racing....200$ for a JP Black? WOW!
Crim3Wav3 is offline   Reply With Quote
Old 03-13-2008, 11:37 AM   #47
mugenb46's Avatar
+1, this is a very nice engine, the crank is not lightened but the rest of the work inside is super clean and a good value, i did a crank out of one of these for a customer and they are smokin, good linier feel and nice top end
You will be happy with the B3, very responsive on bottom and decent top for a 3 port, take good care of it and it should last a good while, not to alarm you but keep a close eye on the bearings, there has been issues with werks bearings in the past, other than that you should be good to go. Good luck
Brian Carey
Pro Twister Mods
brian@protwistermods.com
615-838-5373
mugenb46 is offline   Reply With Quote
Old 03-13-2008, 11:54 AM   #48
Trader Rating: 36 (100%+)
Direct quote from Ron, taken from SGrid...
"I've not realy had time to make an announce ment on this but
all of our 2008 spec engines now come stock with ceramis rear
bearings. This includes the '08 TL21B3-Pro, TL28-Pro and the TL21B7-
Pro. In addition on the B7-Pro we have changed the porting to increase
fuel economy by aprox. 45 sec-1 minute, made changes to the needles
both in taper as well as adding a second o-ring to the high speed
needle to make it a tighter, stiffer to adjust fit, plus a couple of
other things."
NitroOB4You is offline   Reply With Quote
Old 03-13-2008, 12:18 PM   #49
mugenb46's Avatar
cool, i have always good luck with them, it's been a while though since i ran one.
Brian Carey
Pro Twister Mods
615-838-5373
Old 03-13-2008, 08:12 PM   #50
SteveJa's Avatar
Trader Rating: 17 (100%+)
what can you tell me about this motor? I did not know that nova has an n21bf 2002 7p ???? I have never seen one for sale ? how good of a motor is this (I mean come on it a nova right? should be great?) 200 is cheap... very cheap..... and how good is the company to order from...
I am glad I did not order that n21bf from a-main yet.... this looks killer for not much more....
thanks for any and all info....
SteveJa is offline   Reply With Quote
Old 03-13-2008, 08:43 PM   #51
sp2thielen's Avatar
Send a message via MSN to sp2thielen
hey steve travis is running the 5 port go in his truggy and loves it you should give him a call.
IMPULSE RC when only the very best will do!!!!
Hobbytown Hobbyplex
Kyosho SP2/ Medial Pro
Kyosho ST-RR/ Medial Pro
sp2thielen is offline   Reply With Quote
Old 03-13-2008, 09:14 PM   #52
SteveJa's Avatar
yes, i do need to talk to him about that...
Old 03-13-2008, 10:02 PM   #53
SteveJa's Avatar
I do have the werks b3 now...... I am just wanting another motor... someone please tell me about that 21b2002 7port jp motor..... I am ready to order for that price.... but I just want to make sure before I send the money.
Old 03-14-2008, 06:41 AM   #54
SteveJa, I have the jp modified fx21 5 port and it is awesome! Great run time, holds a tune awesome. Power is killer but the engine is very linear. I dont know about the place listed but the engine is awesome and I would not hesitate getting it.
I run the jp mod 5 port(black engine) in my mbx5t and it has plenty of power.
I also run a falcon engine in my hyper 8.5 and that one is awesome as well. Both engines are the best engines I have ran yet. Hope this helps.
blowpopracer is offline   Reply With Quote
Old 03-14-2008, 07:21 AM   #55
Crim3Wav3's Avatar
PDLracing.com is a great place to buy all your JP parts, engines, accesories....they are a distributor of JP products in the US. I have had lots of success ordering from them for my 3 JP engines (B5Nmod, JPmod V-Spec, and Medial Pro M2K)
the engine is basically bastardized. Has the Novarossi N21B 2001BF case, with a different carb (plastic not metal, though still Nova and probably better), a filled and hardblack coated crank, and a 7 port sleeve (not sure from what engine line but could be from as far back as when they worked with Crono)...i also beleive they have done some work on the sleeve, since it is listed as a Mod Motor.
For the money, how could you resist! I am seriously considering picking one up just to have for an indoor motor.
good luck!
Old 03-14-2008, 07:23 AM   #56
Crim3Wav3's Avatar
from pdl's website:
Technical Data N 21 B 2002 JP Category 1/8 On-Road and Off-Road
C. Capacity 3.49 cm3
Bore x Stroke 16.26 mm x 16.8 mm
Ports 7
Piston Die-cast
Crankshaft 14 mm
Glow Plugs Standard
Carburetor Plastic - 8 mm + Reducer
Old 03-14-2008, 07:32 AM   #57
mugenb46's Avatar
hmm, some of them must have come without the epoxy filled crank, i had a customer send me his Black N21 7 port JP to lighten and fill the crank, just something to check into.
Brian Carey
Pro Twister Mods
615-838-5373
Old 03-14-2008, 08:28 AM   #58
Crim3Wav3's Avatar
Well, i would take your word than. I haven't opened one up yet. Was is Hard Blacked at least?
Even if its not, it is a great little engine....
Old 03-14-2008, 11:45 AM   #59
sonic27's Avatar
mugenb46: I think that was my engine you did Brian.
Crim3Wav3: Yes, it is hard coated black. Be careful on that nova name plate on the side of the case as it comes off rather easy.
sonic27 is offline   Reply With Quote
Old 03-14-2008, 01:22 PM   #60
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
+1 on the "watch the bearings." There have been a lot of problems with the rear bearing in the Werks B3 Pro. (The B7 Pro doesn't have the same issue.)
2 of the guys that I pit with had them. One broke 2 cranks... the other shattered a piston skirt. ALL of those issues were caused by rear bearing problems. Neither of the motors had more than 4 gallons on them.
Now for about $310 the B7 Pro absolutely ROCKS! Very smooth and linear power curve, and more power overall than you'd ever need in a buggy.
The guys here running GO motors seem to like them, but I haven't ran one personally. As for the RB stuff... I don't think you can get a better built, longer lasting motor than RB. I had an old C3 that could hold it's own with the 7 ports down the straight, and those motors will hold a tune like you wouldn't believe.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Breaking in the Motor first time? kashif Electric Off-Road 0 07-09-2008 12:55 PM
motor spool up time ? roadkill Electric On-Road 2 01-16-2008 06:07 AM
time for a new car, motor and lipo RoseTuned Electric On-Road 8 11-06-2007 09:01 AM
Run Time for Werks motor newbie2006 Nitro Off-Road 5 07-25-2007 07:30 AM
ok who can help me this time? quick motor Q the #1 noob Electric On-Road 12 03-08-2006 03:46 PM
