Old 03-11-2008, 05:48 AM   #16
tex1's Avatar
Send a message via Yahoo to tex1
Thumbs up
On the list, I would go with the GO Tech 3 port or 5 port. Seems the workmanship is the best of these engines and they make very usable power to boot.
Off the list I would run the Sportworks V2 .21. It is a true 7 port and comes with inserts. We are seeing 10+ gallons of hard racing, better fuel milage than all of the other motors we run and power that does not get pulled. At the RC Pro finals this engine still had no problems on the big track with lots of traction. We were seeing 10:30 run times. If I were going to buy an engine this would be it. $189
TEX
tex1 is offline   Reply With Quote
Old 03-11-2008, 06:08 AM   #17
I would stay away from go motors. My recommendation would be the s3. good run time,holds a tune and lasts forever. Otherwise if you wanna spend a little bit more I would highly recommend a falcon.
blowpopracer is offline   Reply With Quote
Old 03-11-2008, 07:07 AM   #18
Maximo's Avatar
Picco(P7R/JPX) makes more power and RPM then the GO engines.. ( I am sorry to say that, but the dyno doesn't lie) from working on both motors extensively I can say the metal quality of the Picco is quite a bit better... the Picco cranks use a much higher grade of steel, the crankpins are harder and wear better , and the pistons are harder and will hold an edge longer....... The Picco IMHO is the best value at this price range...the GO engines are a strong performer no doupt, but i feel the Picco is providing more value with better build and material quality and a slight edge in overall performance... I mean you can buy a JPX .21 for $220.00...
Now replacement parts for the Picco's is expensive, much more expensive then the Go engines......I personally run both motors, Go and Picco, and feel both are great mills, but I do feel the Picco has the better initial value....the Go is a better value when you need parts and service..Russ Jones is reason enough to own a Go engine, he's an awesome guy to deal with....
You can't go wrong with either motor, but you also cannot blindly dismiss the JPX 21 as a competitor to the GO engines....
Maximo is offline   Reply With Quote
Old 03-11-2008, 07:09 AM   #19
Maximo's Avatar
Jammin JPX 21 and Picco P7 EVO 2 are identical engines.....
Old 03-11-2008, 07:21 AM   #20
Trader Rating: 96 (100%+)
S3 or the Jammin.
From what Iv'e seen with friends RB's, they are pretty impressive in the power department and delivering upwards of 6 + gallons on stock internals.
K.Copeland is offline   Reply With Quote
Old 03-11-2008, 07:26 AM   #21
xlgraphicspro's Avatar
RB S-7 I CHANGED MY VOTE!!!!!!
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 03-11-2008, 07:35 AM   #22
Maximo's Avatar
Originally Posted by xrayeddy View Post
S3 or the Jammin.
pretty big power difference between the S7 and the Jammin though........the JPX is actually a competitor tot he C6 when it comes to power output, well truth be told the JPX is stronger then the C6..... But the S7 is a very mild motor, the JPX is quite the opposite and near the top of the .21 power wars....... Yes a JPX .21 is a total beast of an engine !
Old 03-11-2008, 07:53 AM   #23
Trader Rating: 28 (100%+)
Like many others said...
GO GO GO...........
Semi Retired.
OWTKAST cpt is offline   Reply With Quote
Old 03-11-2008, 07:59 AM   #24
Hey steve, I was thinking. I know dangerous. Maybe you should just up your max price to $240-260?
you spent more money in engines last year than alot of guys. Just get one good one manRb lasted the longest for me, and I'm gonna buy another to back up my v-spec. I think the back up motor should be better than the one you always run.
this was from a-main
S-3II = 189.99
S-5 = 239.99
S-7 = 259.99 Had this one and it did last over 10 gallons
S-3II = 274.99 Comes with an RB 2020 Pipe
The 7 = 309.99 limited edition celebrating the S-7
Old 03-11-2008, 08:04 AM   #25
I had a slight problem with my go, but it turned out to be the clutch shoes. I have never had an engine this easy to tune. I ran 3 weeks, and never touched the needles, unlike my nove 3 port. I dont know why i didnt try them sooner. Im only getting like 6 mins on a tank, but im chasing setups right now, and having a tough time to get to 200 *
www.carolinasrc.com
derricklong38 is offline   Reply With Quote
Old 03-11-2008, 08:13 AM   #26
hell, if your only getting 6 minutes a tank, and not even at 200 degrees, lean it out on the top a bit, atleast till your temps at 220-230 then you'll get more time out of it. Our heat races are 7 minutes long, so you would have to pit during a heat race, and that would kill any good run.
If your heats are only 5 minutes, I can see why you have no urge to lean it out.
Old 03-11-2008, 08:13 AM   #27
littlemotor's Avatar
SteveJa, ck. PM's.
littlemotor is offline   Reply With Quote
Old 03-11-2008, 08:14 AM   #28
Don't buy used, I think all good motor guys know that!
Old 03-11-2008, 08:33 AM   #29
buckeye34's Avatar
i agree, i bought a used v-spec about two months ago. the guy said it had just over a gallon on it. yeah, a gallon on bad rear bearings... gave the guy $150.00 for it. had to replace bearings,con rod, so i just replaced p/s also. so i have a little over $300.00 for a "used" engine.... will NEVER buy a used engine again. the engine is now my back up engine..."way back up"...LOL
mbx5r
v-spec
jp-3 pipe
hitec 5955tg/steering
ko propo 2367/throttle
m-11
buckeye34 is offline   Reply With Quote
Old 03-11-2008, 11:03 AM   #30
well, I won a Vspec at our local rc series over the summer. I already had a Vspec and thought I could used the money, so I sold my 3 gallon old Vspec to a guy I race with. I warned him to not buy it for one simple reason, it was used and I can't Guarantee it will last any particular amount of time. He agreed and bought it anyway. He put 2-3 more gallons on it and snapped a rod. I felt bad, but he knew what he was getting into.
Breaking in the Motor first time? kashif Electric Off-Road 0 07-09-2008 12:55 PM
motor spool up time ? roadkill Electric On-Road 2 01-16-2008 06:07 AM
time for a new car, motor and lipo RoseTuned Electric On-Road 8 11-06-2007 09:01 AM
Run Time for Werks motor newbie2006 Nitro Off-Road 5 07-25-2007 07:30 AM
ok who can help me this time? quick motor Q the #1 noob Electric On-Road 12 03-08-2006 03:46 PM
