Clutch Nut is, well...stuck
I apparently didn't get my clutch nut tight enough and the flywheel spins freely. Problem is, I can't get the clutch nut off as the locktite has it stuch on the shaft, which rotates keeping the nut from coming loose. Any ideas?
Thanks.
Thanks.
one think ill mention is DO NOT strip the screw, theres NOTHING worse on a rc car than having a stripped screw or a strippes hex key... i had to learn the hard way, a few times. if you dont follow that advice, order new screws from tonys screws, hes the best.
I have pliers with firm rubber handle covers that fit perfectly down the intake and the crank, this stops the crank from turning and does no damage whatsoever to the crank. DO NOT put bare steel down there though. I use this method all the time with many engines and it works a dream!!
Location: If i'm not in England i'm in Southern California
I tried heating the nut with a soldering iron, but that didn't work (maybe I didn't hold it long enough). I don't have anything to stick down the intake, but I've read there are tools for this. Frustrating...
I tried the channel locks, but I couldn't get enough room to get a wrench or needle nose down there and I didn't want to ruin the clutch or the nut.
Double
Double
If it's super stuck i wouldn't use a tool to lock the piston, in fact if poss avoid putting anything in your engine at all times.
Double
Double
Thanks so far for the advice.
Has anyone heard of filling the engine with after engine oil to "hydraulically" lock it?
Sorry, After Run Oil.
Piston Locking Tool
There are two kinds, one for standard and another for turbo plugs. You always want to use channel locks or vise grips to lock down the flywheel to take off the clutch nut. However, sometimes you get the clutch loose enough to not hold the shaft and it creates the spinning problem which sounds like the issue you are having.
Be careful when using a piston locking tool. Slowly take off the clutch nut to avoid damage to your connecting rod.
This is the piston locking tool I use when I run to a situation where the flywheel is loose and not gripping the shaft but with the clutch nut still stuck:
http://rc-mushroom.com/product_info....oducts_id=3771
I like it because it has both standard and turbo style threads.
Double
Double
you should be able to hold the flywheel with your hand and spin the flywheel nut with a socket wrench.
are those 3 bars for the clutch shoes in the way? i dont know if this is supposed to happen, but mint pull out of the flywheel, one is kinda easy to get out, the other 2 are a bit hard, but i know ive done it before. that should make things easier.
Piston Locking Tool
I forget which magazine had it as a tech tip, but they said you could use a popsicle stick to lock the piston. I'm sure the piston locking tool is the prefered method. But if you happen to have a popsicle lying around in the freezer
