Old 03-08-2008, 09:50 PM   #1
Default Is my glow plug working properly?
I took out my glow plug today to have a check on it because my engine wasn't starting properly... anyway when i stuck it onto my igniter.. it didn't glow red but just made a sizzling like sound ?? ? ?
bosley is offline   Reply With Quote
Old 03-08-2008, 09:53 PM   #2
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
well, it means that your running rich and that the gas is basicly submerging the plug in gas and it makes it cold so it wont light, you might want to get a new plug and try it out
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 03-08-2008, 10:47 PM   #3
what new plug should i get then? oh and what is running rich? is it my plug or just the fuel im using?
Old 03-09-2008, 12:55 AM   #4
bobbitrc's Avatar
Running rich is when theres too much fuel running to the engine. basicly your flooding it. Try turning either the high speed needel and or low speed needel clockwise to lean out the fuel mixture.
bobbitrc is offline   Reply With Quote
Old 03-09-2008, 01:39 AM   #5
sptrtrucker's Avatar
Default glow plugs
if it was too rich it would sizzle and pop b ut would glow after a min it sounds like either a new glow plug or even easier ur batt dead in ur ignitor, try changing batt or recharging first on glow plugs every engine can take different ones and do different tasks, look inur book but an os #8 is a good all around. on fuel settings look at ur book it will have a starting point for ur high( this is the large screw needle off the carb)start a 1/4 further out and run the motor to warm temp them start to turn the needle at most 1/8 turn at a time till u hear engine come to life then just turn it out a little bit,make sure u dont lose that smoke trail, also u can get a temp gun and ur book will give u a recommended range, the low end needle is for that low end punch and is located in the center of the throttle arm that ur linkage hooks too. let the truck sit idling for 30 sec then pull full throttle if the truck dies or spits then goes usally rich turn just little in and try again, just remember no smoke motor goes boom, after a little while ur be a pro caus these settings change everytime u run
sptrtrucker is offline   Reply With Quote
Old 03-09-2008, 01:45 AM   #6
um.. could you explain where can i find the high speed needle and low speed needle... Thanks! I am such a complete Newbie to Nitro
Old 03-09-2008, 04:11 AM   #7
dragaddict's Avatar
You need to do a search for a nitro tuning guide. Running your motor too rich or to lean can cause engine failure, here is a pic of the carb and the adjustment screws some carbs have an extra one that is not pictured. What kind of motor do you have?
8ight B 2.0
XXX SCT
RC10B5
dragaddict is offline   Reply With Quote
Old 03-09-2008, 04:58 AM   #8
Default tuning
wow that is a good picture dragaddict that will help him which manual did u get that out of?
Old 03-09-2008, 05:02 AM   #9
I think i've got a .28 thunder tiger engine or something. Not really sure as it was bought second hand from a sponsored racer..
Old 03-09-2008, 05:25 AM   #10
Default tuning
that motor should be like the picture ur seeing just remember when u turn those screws in that lets in less fuel more air and ur lube for ur motor is in that fuel so always make sure u got a smoke trail
Old 03-09-2008, 05:33 AM   #11
Whats a smoke trail? and should i still get a new plug?
Old 03-09-2008, 06:50 AM   #12
dragaddict's Avatar
The pic is out of a manual for my LST. A smoke trail is the smoke you see coming out of the pipe as you are running. I would get a few extra glow plugs if I were you. Due to being new to this you may go through a few learning how to get it in tune.
8ight B 2.0
XXX SCT
RC10B5
Old 03-09-2008, 09:25 AM   #13
dragaddict's Avatar
See if you can find out what kind of motor it is forsure. Is it in a buggy, truggy, ST... what kind of rc product is it. Most of the time you can download the manual for whatever car you have. If it is a thunder tiger you can download the manual at....http://acehobby.com/ace/manual.htm
8ight B 2.0
XXX SCT
RC10B5
Old 03-09-2008, 02:23 PM   #14
i found it.. it was the pro .28 engine .. oh and the engine is in a team magic m1-b buggy !! =P
Much More CTX-D2 Discharger - NOT WORKING PROPERLY Still Bill R/C Items: For Sale/Trade 6 02-03-2008 10:36 PM
Glow Plug Kane-o Electric Off-Road 4 01-25-2007 03:28 PM
glow plug help timmy187 Monster Trucks 3 04-19-2006 07:56 PM
GLow plug. zoombie Nitro On-Road 5 07-06-2003 05:31 PM
Which Glow Plug to Use for MR-12? ttektek Nitro On-Road 6 05-04-2003 08:00 AM
