Old 03-19-2008, 10:45 PM   #16
houston's Avatar
Trader Rating: 91 (100%+)
i will have to give peter a call as i really want to find good ceramic rear bearing for my plus engines
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 03-20-2008, 02:58 PM   #17
Peter Martin's Avatar
Call me Friday...704-562-3535
Peter Martin is offline   Reply With Quote
Old 03-27-2008, 06:50 AM   #18
rcjunky10's Avatar
Trader Rating: 217 (100%+)
Originally Posted by houston View Post
i wonder what the problem is then ?? i am very practiced and knowledgeable when it comes to nitro engines and the only thing i could figure out was that the outer dia. was a lil too big . didn't measure , will soon
Just to update this thread, I replaced the bearings in my 21-5 yesterday using an OFNA bearing puller and an oven preheated to 350 degrees. The front bearing came right out using the bearing puller while the rear fell out after being in the oven for 20 minutes. The new bearings when in without incident. So for those of you running plus size bearings the TKO are a great upgrade for your mill.
Thanks to everyone who chimed in on this point. Thanks to Peter Martin from TKO for his input.
rcjunky10 is offline   Reply With Quote
Old 03-27-2008, 07:31 PM   #19
Default hi Peter.
Hi Peter,
May i know do you carry ceramic bearing for RBC6 t7. by the way are you a rc car players too? cheersss
Originally Posted by Peter Martin View Post
TKO stands behinds our products. Please return the bearing to us for inspection and a refund. Always call or contact us with any issues.
704-562-3535
pmtko@carolina.rr.com
TKO Competition Development
8964 Saint Croix Lane
Charlotte, NC 28277
We tested the bearings in customer and engine builder engines before release
so we are concerned about your results.
Thank you,
Peter Martin
novaa is offline   Reply With Quote
Old 03-28-2008, 12:31 AM   #20
houston's Avatar
bearings went in great in my 21-5k , it might be the tolerance of the nova blocks in the plus2 367 blocks . so far so good.
thanks peter ,
monty
Old 03-28-2008, 05:54 AM   #21
novaa...part # CB-MR25814
Monty...did you get the package this week? Let me know how they work. Call after you run it.
Old 03-28-2008, 08:58 PM   #22
thanks Peter. i found what i want there. on the other hand there isn't ceramic bearing for the front bearing for rb c6 t7??
Old 03-29-2008, 08:40 PM   #23
gixxerman's Avatar
Peter do you guys cary the correct bearings for the Picco p7r Evo 2?
gixxerman is offline   Reply With Quote
Old 03-30-2008, 02:17 PM   #24
front ceramic is CB-607C2RS for C6 and all .21s and .28s
Picco uses front like above and CB-MR25414 rear
Old 03-31-2008, 12:11 AM   #25
thanks
Old 04-01-2008, 06:42 PM   #26
gixxerman's Avatar
Thank you! May I contact you with the number listed above? I will be ordering the this week!!!!
Old 04-01-2008, 06:54 PM   #27
Trader Rating: 39 (100%+)
im replacing the rear bearing in my v spec with a tko ceramic that i ordered yesterday. I heated the oven to 450, let the motor stand for about 7-10 minutes and then took the case out with a glove, lightly tapped the case against the table untill the rear bearing fell out.
I do have a question though, since the front bearing is like new i decided not to replace it, is it safe to re-use a bearing after the block has been heated with the bearing in the oven in order to remove the other? or does the oil from the fuel re-lube the bearing once ran again and all should be good?
slowguy4 is offline   Reply With Quote
Old 04-01-2008, 07:10 PM   #28
houston's Avatar
reusing that front bearing after being superheated is not advised , you should get a new one .
peter; i will try it thanks man , monty
Team Losi 8ight Front and Rear Chassis Braces and KingHeadz Rear Toe meon99 R/C Items: For Sale/Trade 14 07-23-2008 08:24 PM
How to replace the one-way needle bearings for G4S? uniquexme Nitro On-Road 3 08-25-2006 04:51 AM
FS HV Oil Pump, Rings, Main and Rod Bearings SBC hardey Other Items: For Sale/Trade or Wanted to Buy 1 06-22-2006 01:15 PM
OS VZB Vspec front and rear bearings New NismoSkyline17 R/C Items: For Sale/Trade 0 05-21-2006 05:53 PM
main bearings Help? Raw40 Nitro On-Road 6 07-03-2002 05:43 PM
