Old 03-07-2008, 11:03 PM   #1
paco62's Avatar
Default Clutch Nut is, well...stuck
I apparently didn't get my clutch nut tight enough and the flywheel spins freely. Problem is, I can't get the clutch nut off as the locktite has it stuch on the shaft, which rotates keeping the nut from coming loose. Any ideas?
Thanks.
paco62 is offline   Reply With Quote
Old 03-07-2008, 11:11 PM   #2
losi guy's Avatar
Trader Rating: 38 (100%+)
Send a message via ICQ to losi guy
I had to this a few times. I took a pair of channel locks that were new and put a towel around the flywheel and grip real tight so it doesn't slip (don;t want mess it up) and use your wrench on the nut.
Spektrum | Avid | DE Racing | Tekno
losi guy is offline   Reply With Quote
Old 03-07-2008, 11:25 PM   #3
Mugen MBX-5's Avatar
Thanks.
what if you tried heating the stuck screw real fast with a propane torch or something, that might make the loctite melt and it come undone real easy.
one think ill mention is DO NOT strip the screw, theres NOTHING worse on a rc car than having a stripped screw or a strippes hex key... i had to learn the hard way, a few times. if you dont follow that advice, order new screws from tonys screws, hes the best.
I dont race. Please dont assume I race. I only bash around.
T Lawrence is a scamming scumbag
Tonys Screws l carolinasrc.com l spektrum (?)
Mugen MBX-5 is offline   Reply With Quote
Old 03-07-2008, 11:30 PM   #4
BOOST's Avatar
I have pliers with firm rubber handle covers that fit perfectly down the intake and the crank, this stops the crank from turning and does no damage whatsoever to the crank. DO NOT put bare steel down there though. I use this method all the time with many engines and it works a dream!!
BOOST is offline   Reply With Quote
Old 03-07-2008, 11:32 PM   #5
IanWright's Avatar
Location: If i'm not in England i'm in Southern California
Send a message via AIM to IanWright
It's not a screw, it's a nut.
Don't be put off with loctiting it when you put it back, it is a must.
IanWright is offline   Reply With Quote
Old 03-07-2008, 11:37 PM   #6
paco62's Avatar
I tried heating the nut with a soldering iron, but that didn't work (maybe I didn't hold it long enough). I don't have anything to stick down the intake, but I've read there are tools for this. Frustrating...
I tried the channel locks, but I couldn't get enough room to get a wrench or needle nose down there and I didn't want to ruin the clutch or the nut.
Double
Old 03-07-2008, 11:41 PM   #7
IanWright's Avatar
If it's super stuck i wouldn't use a tool to lock the piston, in fact if poss avoid putting anything in your engine at all times.
Old 03-07-2008, 11:41 PM   #8
BOOST's Avatar
Double
....oh man, ya don't put wrenches or pliers down there. But if you can find something that is hard plastic or a handle with a rubber cover (like most pliers have!!) then it will work.
Old 03-07-2008, 11:48 PM   #9
paco62's Avatar
Thanks so far for the advice.
Has anyone heard of filling the engine with after engine oil to "hydraulically" lock it?
Old 03-07-2008, 11:49 PM   #10
paco62's Avatar
Sorry, After Run Oil.
Old 03-07-2008, 11:53 PM   #11
Derby Bros Racing's Avatar
Piston Locking Tool
There are two kinds, one for standard and another for turbo plugs. You always want to use channel locks or vise grips to lock down the flywheel to take off the clutch nut. However, sometimes you get the clutch loose enough to not hold the shaft and it creates the spinning problem which sounds like the issue you are having.
Be careful when using a piston locking tool. Slowly take off the clutch nut to avoid damage to your connecting rod.
Derby Bros Racing is offline   Reply With Quote
Old 03-08-2008, 12:00 AM   #12
This is the piston locking tool I use when I run to a situation where the flywheel is loose and not gripping the shaft but with the clutch nut still stuck:
http://rc-mushroom.com/product_info....oducts_id=3771
I like it because it has both standard and turbo style threads.
Old 03-08-2008, 12:27 AM   #13
Double
dont think a soldering gun will work, maybe even a lighter would work. not sure about that loctite, it shouldnt be that stuck... id get it off
you should be able to hold the flywheel with your hand and spin the flywheel nut with a socket wrench.
are those 3 bars for the clutch shoes in the way? i dont know if this is supposed to happen, but mint pull out of the flywheel, one is kinda easy to get out, the other 2 are a bit hard, but i know ive done it before. that should make things easier.
Old 03-08-2008, 12:38 AM   #14
BigRed's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Derby Bros Racing View Post
Piston Locking Tool
I forget which magazine had it as a tech tip, but they said you could use a popsicle stick to lock the piston. I'm sure the piston locking tool is the prefered method. But if you happen to have a popsicle lying around in the freezer
Lake Superior R/C Car Club
lsrcc.com
BigRed is offline   Reply With Quote
Old 03-08-2008, 02:16 AM   #15
chris c's Avatar
Trader Rating: 60 (100%+)
a zip tie folded in half
insert it into the exhaust port and it should hold it...Use a good thick tie...
Good luck!
chris c is offline   Reply With Quote
yamaha gt 80 dirt 4 speed clutch clutch bike 4 speed clutch cheap savage123 Other Items: For Sale/Trade or Wanted to Buy 8 08-10-2006 12:34 PM
Removing a stuck thrust bearing from the clutch bell Darthswan Nitro On-Road 0 08-01-2005 10:13 AM
MTX-2 clutch assembly stuck!! subman Nitro On-Road 5 04-14-2004 01:49 PM
WANTED:Savage parts-clutch bell, clutch shoes, rear driveshaft,etc..Orlando, Fl. 10gter Florida Racing 0 01-26-2004 08:54 AM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 04:01 PM
