Old 03-07-2008, 09:25 PM   #1
Trader Rating: 35 (100%+)
Default rb 3 port running lean and rich
I have a 2 gallon old rb 3 port and it will run good for a couple laps then lean out or richen up.....i noticed a lot of fuel aroudn the carb and below the carb on the crankcase, i put racers edge carb sealant and it stilled had fuel all over it, maybe the front bearing?? i took the clutch off and flywheel and the bearing looked ok and the seal was still there. Could it be leaking out of the rubber boot??? i am lost here
losiracer22 is offline   Reply With Quote
Old 03-08-2008, 08:23 AM   #2
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Hard to say. Do you have any pics of the engine with the fuel on the outside? Have you owned this engine since new or got it used?
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 03-08-2008, 08:36 AM   #3
houston's Avatar
Trader Rating: 91 (100%+)
first check your fuel lines , could be the carb lock screw seal , could be the front bearing . front bearing would be the most likely if you are seeing massive amounts of oil under the engine . also check your tank , could be broke !!!
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 03-08-2008, 08:54 AM   #4
R40Victim's Avatar
Make sure your high speed needle housing is tight. They seem come loose on the Mach 427s, but haven't seen it on any RB. The one thing we did figure out, was that it takes FOREVER to break one in...
R40Victim is offline   Reply With Quote
Old 03-08-2008, 09:04 AM   #5
Black's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to Black
My brother had the same problem with his motor and I took the carb boot off and stretched it out and RTV'd. Then I sealed the backplate and all was well. Either replace the boot or seal it then you should be ok.
JConcepts/Werks Racing Engines/Ironman Bearings/PowerMaster Fuel/VP Racing
Black is offline   Reply With Quote
Old 03-08-2008, 09:09 AM   #6
i have had the engine since it was new.......i am going to take the boot off and try sealing it, see what that does, if that doesn't fix it i guess it is the front bearing. thanks guys
Rich? Lean? Normal? duratraxrc Nitro Off-Road 2 08-27-2008 11:41 AM
HEN lean and LEN rich...effects? keavze Nitro On-Road 1 11-09-2007 02:58 AM
running too rich or running to lean bumm_off_street Nitro On-Road 7 03-29-2006 07:28 PM
Modded motors running lean? GrandeGixxer Onroad Nitro Engine Zone 1 09-09-2004 05:15 PM
Rich and Lean. R/Cstratus48 Nitro On-Road 1 07-17-2004 09:16 PM
