Old 04-13-2008, 03:06 AM   #16
lowey79's Avatar
Originally Posted by F N CUDA View Post
That's easier than just loosening the plug? Why take it out?
Loosen it, heat it, crank it, tighten it and start it.
If the engine is flooded, the fastest way to get the excess fuel out of it is through the plug hole..... Need the plug out to do it
Each to there own i guess.... everyone has thier own ways!
lowey79 is offline   Reply With Quote
Old 04-13-2008, 03:20 AM   #17
Dave_x8's Avatar
Send a message via MSN to Dave_x8
you said it mate
GO-TECH 21 5-port DOMINATOR
hyper 10 ON-ROAD toyota supra
Dave_x8 is offline   Reply With Quote
Old 04-13-2008, 08:26 AM   #18
F N CUDA's Avatar
Trader Rating: 30 (100%+)
If you loosen the plug and give the motor a few cranks, that fuel is gonna bleed out. Stick the igniter on the plug and it's gonna dry up.
No turning the car upside down and no fuel dribblin all over.
Cleaner and quicker
Yeh to each his own.
F N CUDA is offline   Reply With Quote
Old 04-13-2008, 10:23 AM   #19
Trader Rating: 15 (100%+)
Ok Guys:
Before you make this thread go stupid think about this.
1. If you take the glow plug out.... BE sure to clean the inside of the head first with a shot of air or use some motor spray and Q tip to get to the dirt away from the opening into the plug area.
2. At the track it is not wise to take the aircleaner and tube off the carb unless you remove the engine completely to remove any dirt around the aircleaner and tube.
3. Dirt is your engines worst enemy!
4. Just loosening the glow plug and using the igniter will result in a great accumulation of dirt around the head area as soon as you put the vehicle back on the track because of wet fuel attracting dirt.
So.... Clean out the head area, take out the plug, turn the chassis upside down, drain any fuel and turn the engine over a few times. Replace the plug and away you go!
Did I mention dirt is your engines worst enemy!
7.5man is offline   Reply With Quote
GO 28R/Full Starter Engine GRracing Ver.Team Fully Modified Engine handpiece Onroad Nitro Engine Zone 0 07-28-2007 02:42 AM
Ofna Picco .21B 3 Port engine, good budget engine Cain Electric Off-Road 1 03-26-2007 07:32 AM
selling custom savage roller with engine, truck zillia modded engine.$275 pat360xboxhalo3 R/C Items: For Sale/Trade 2 01-11-2007 04:23 AM
A flood of spam stampedespeed Chat Lounge 9 09-06-2006 08:20 PM
Engine flood problems khany1 Rookie Zone 5 05-02-2006 06:45 PM
