Old 03-05-2008, 09:27 PM   #1
Questions?? Can this engine be saved?
Okay so I am still in the process of my rebuild and all of the following pictures are after I have done my best to clean the engine with denatured alcohol on the inside and simple green + denatured alcohol on the outside. Is this engine worth spending about $15 bucks to get new screws for it and thermo insulator or should I just buy a new engine?
Here are the pictures I took of all the areas I thought were relevant.
Engine Pictures
Cybane is offline   Reply With Quote
Old 03-05-2008, 09:37 PM   #2
GenReaper's Avatar
Send a message via MSN to GenReaper
Depends on the Crank pin, how worn it is, how much slop the rod has while on the crank pin.
Also how much pinch the sleeve has at TDC.
Replace the front engine bearing as well.
Trex 700E 12S Scorpion 4035 560kv
Trex 600E
HPI Baja 5B SS
My videos : http://www.youtube.com/profile?user=genreaper
GenReaper is offline   Reply With Quote
Old 03-05-2008, 10:23 PM   #3
xlgraphicspro's Avatar
Have you run this engine? you showed us the exhaust port side of the sleeve, it can get discolored like that. for 15 bucks I'd try it out. do the bearings feel gritty? and does the front one leak?
If not use the same bearings, because once you start replacing bearings when other parts are questionable. then it's not worth it. the corrosion on the crank is typical of an engine that has sat a while, like a winter without proper maintainance or storage. But if you clean it well with break clean and use alot of after run oil before you refire it up. hell, even a 15 dollar pinch might help. 30 bucks to revive a motor isn't bad.
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
can my batteries be saved? seaball Electric On-Road 11 09-29-2009 01:37 PM
Saved a 11.1V TX LiPo from discharge to 1.8V? ESWLFSE Radio and Electronics 1 04-28-2008 11:07 AM
I just saved $65, here's how! dubum Racing Forum 0 01-14-2008 03:19 PM
GO 28R/Full Starter Engine GRracing Ver.Team Fully Modified Engine handpiece Onroad Nitro Engine Zone 0 07-28-2007 02:42 AM
selling custom savage roller with engine, truck zillia modded engine.$275 pat360xboxhalo3 R/C Items: For Sale/Trade 2 01-11-2007 04:23 AM
