Old 03-05-2008, 02:57 PM   #1
Trader Rating: 27 (100%+)
Default Steering Servo Oscillating
I noticed the other day that my steering servo (ACE DS1015) is oscillating, even when the engine is not running. I have seen this happen to the rebranded AE steering servo as well. Any idea what could be causing this and how to fix it?
Edwin Hartman
Tekno RC Regional Team Manager - Southern Midwest region
Sponsors: Tekno RC - Pro-Line Racing - Tekin - LutzRC - O'Donnell Racing Fuel - TrakPower - Advantage Racing Products - Futaba - Sumo Racing
ehartman_49348 is offline   Reply With Quote
Old 03-05-2008, 04:45 PM   #2
i have had this happen to my JR SERVO& my AIRTRONICS SERVO . i sent them both in to get fixed and they both said that the motor was bad . hope this helps you
659tmaxx is offline   Reply With Quote
Old 03-05-2008, 05:14 PM   #3
It does help a little bit, but I don't really feal like sending it in, as I currently don't have a good back-up steering servo....
Edwin Hartman
Old 03-05-2008, 11:06 PM   #4
air8's Avatar
I just posted my results to this in the Electronics Thread. For me the oscillating was due to the plastic boss molded into the top half of the servo case. The boss was hammered by a hard impact (crashing). Anyways, the servo couldn't find center because the center shaft and gear were moving around about 1/16" and therefore the servo motor couldn't stay centered.
Or there is a stripped gear possibly.
I suggest to remove the four screws off the top of your case. Look at the gears and the inside of the top case. See if there is anything odd shaped or worn out/broken. I thought I would send mine in for repair too. My buddy decided we needed to open it up and see if there were stripped gears. Nope! Just a wollered out hole in the top of the case.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 03-06-2008, 02:00 AM   #5
Mugen MBX-5's Avatar
how come my brand new steering servo makes a twitching sound when it turns on, and sometimes after i drive it, it wont go back to perfectly straight, and it makes a weird sound, and its a brand new 115$ airtronics one..
I dont race. Please dont assume I race. I only bash around.
T Lawrence is a scamming scumbag
Tonys Screws l carolinasrc.com l spektrum (?)
Mugen MBX-5 is offline   Reply With Quote
Old 03-06-2008, 03:37 AM   #6
dgraham225's Avatar
Send a message via Skype™ to dgraham225
what airtronics servo do you have? if its a digital model, they do have sort of a humming sound all the time, some louder than others.. as for re-centering problems, welcome to the wonderful world of airtronics, lol! i have airtronics servos also. that used to be all i would run.. but theyre not as good as they used to be for some reason? ill be switching to JR or futaba soon enough...
Danny Graham
dgraham225 is offline   Reply With Quote
Old 03-06-2008, 04:44 AM   #7
DR ZAIRUS's Avatar
If it helps, my KO Propo Digital FET steering servo also makes a sort of humming sound at times, but it does move ok and go back to center ok...
Make sure there isn't any binding or rubbing in any of the steering moving parts....
Hong Nor/Jammin' X2
Picco P7 Evo3+JP3
Futaba+KO Propo.
TEAM www.fisio-sport.com
(Valencia, Spain)
DR ZAIRUS is offline   Reply With Quote
Old 03-06-2008, 08:59 AM   #8
Ebi
Had the same problem with my DS 1015.
Check the teeth of the smaller gear at the white plastic gear.
Gears not available separat - parts # for the complete gear set AQ 1433
Ebi
Ebi is offline   Reply With Quote
Old 03-06-2008, 10:10 AM   #9
petevette's Avatar
Send a message via Yahoo to petevette
Hey guys, your starting to scare me. I just installed new new XP1015 in my car. I don't have an oscillating issues and hope that I don't get one.
I do have a buzzing sound which I understand to be normal. I heard a digital KO servo buzzing that was so loud it almost drowned out the engine. The XP buzz, but barely noticeable.
Love the power and speed of the 1015s, hope I don't encounter any issues. I had a JR590 that had trouble centering, but just trashed it and installed another one.
petevette is offline   Reply With Quote
Old 03-06-2008, 10:20 AM   #10
Send a message via AIM to JustinD
All I can say is Get the KO PROPO worth every cent......
EB MODS
Mugen MBX6 -EB MOD OS V-Spec / EB MODS FUEL
JustinD is offline   Reply With Quote
Old 03-06-2008, 02:05 PM   #11
have had a couple of the ace servos do that,due to the grease drying out on the gears and because of the backlash on the gears the servo starts hunting for centre,a dab of grease on the gears and it damps it all down,give it a try
dave
fastboy is offline   Reply With Quote
Old 03-06-2008, 02:06 PM   #12
Ebi
A little disappointed to find out that I spent $100 on a servo to find out that is has a plastic gear in it..... Should be all metal for that money! Thanks for the info. I will check the gears.
Edwin Hartman
Old 03-06-2008, 02:31 PM   #13
petevette's Avatar
That plastic gear is actually a good thing. It is a sacrificial gear that is easy and inexpensive to replace should something unforseen happen to the servo.
Old 03-06-2008, 11:39 PM   #14
im using a Airtronics 94359 High Torque Aluminum Gear Servo
Old 03-07-2008, 04:52 AM   #15
dgraham225's Avatar
thats an analog servo man, it shouldnt be humming like a digital. i cant tell you exactly whats wrong, but be prepared to replace it, especially if it doesnt re-center! i have one of those too, lol!
Danny Graham
steering servo? C_Money Electric Off-Road 7 12-07-2007 03:06 PM
Steering servo and Throttle servo same speed? straightaway Nitro On-Road 4 11-06-2007 07:21 PM
Which Steering servo for a TC3? NT Electric On-Road 7 10-25-2006 02:14 PM
RC18T servo, servo saver, and steering rack Bansheeman R/C Items: For Sale/Trade 0 07-27-2005 08:27 PM
Steering Servo.... vtl1180ny Electric On-Road 1 01-20-2004 01:16 AM
