Old 03-05-2008, 02:06 PM   #1
KDub75's Avatar
Trader Rating: 14 (100%+)
Default V Spec question
How can I tell if I have an updated model V Spec without taking the engine apart. Thanks!
KDub75 is offline   Reply With Quote
Old 03-05-2008, 02:28 PM   #2
linerv's Avatar
look at the crankcase, the updated one looks similar to the OS speed. Go online find a Speed picture, then compare the bottom of the crankcase.
linerv is offline   Reply With Quote
Old 03-05-2008, 02:38 PM   #3
KDub75's Avatar
Thanks!
Old 03-05-2008, 03:14 PM   #4
buckeye34's Avatar
also on the newer version on the bottom of the case where the backplate screws in the "nubs" run the entire length of the case. the older versions "nubs" are just long enough for the screws to go into.
mbx5r
v-spec
jp-3 pipe
hitec 5955tg/steering
ko propo 2367/throttle
m-11
buckeye34 is offline   Reply With Quote
Old 03-05-2008, 03:29 PM   #5
ollie 45's Avatar
Trader Rating: 18 (100%+)
What's the difference? Is one better than the other. Looks like mine is the newer model.
ollie 45 is offline   Reply With Quote
Old 03-05-2008, 07:55 PM   #6
I've cracked 2 older crank cases, hopefully new one has that sorted
Kev Lewis,
I'd like to thank my personal Sponsors :-AKA Tyres Australia, Ryper Hobbies and Just Hobbies
The Gear :- Associated RC8 B3 powered by OS Engines
Soapy is offline   Reply With Quote
Old 03-05-2008, 11:35 PM   #7
sickboy's Avatar
Trader Rating: 72 (100%+)
The chances of comming across a nib old style v-specs is about 0. They sold through them over a year ago. There was a 2 month period last year when you couldnt find a v-spec anywhere because the ones were gone and the new ones were not ready.
sickboy is offline   Reply With Quote
Old 03-06-2008, 06:26 AM   #8
buckeye34's Avatar
the newer one has better rear bearings. the older ones had problems with the bearings leaking and going bad. also i think the newer ones have a silver backplate but i could be wrong on that.
mbx5r
v-spec
jp-3 pipe
m-11
Old 03-06-2008, 05:33 PM   #9
sickboy's Avatar
you are correct, the old ones had black back plates. i forgot about that.
World GT Club Racing - To spec or not to spec is the question???? Mr. McGoo Electric On-Road 722 11-01-2014 06:05 AM
LRP TC Spec Question garrettsdad Radio and Electronics 2 06-12-2008 04:38 PM
Question about OS V spec. !!!!!!!!!!!!!!! dead1dave Nitro Off-Road 1 06-08-2008 04:46 PM
OS V-Spec Question raydog Nitro Off-Road 3 02-23-2008 09:24 PM
OS v-spec question.. need help Pinnacle003 Electric Off-Road 9 10-30-2005 09:51 PM
