Old 03-10-2008, 06:46 AM   #61
Send a message via AIM to David Alberico Send a message via Yahoo to David Alberico
I don't run for OS. but last year I had a con-rod snap. I sent my engine in and they took care of me as a customer. I think this is good business ethics and I would definitly buy another OS engine just because of that.
Castle Creations, J-Concepts, WMD Products, Clints Creations
David Alberico is offline   Reply With Quote
Old 03-10-2008, 12:13 PM   #62
Maikaitan's Avatar
there are 2 version of the vspec... the later version has an updated main bearing.... the old one has a 10 ball baring... the new one has a 9 ball bearing...
also, the new version has a different part number for the crankcase... externally, it's hard to tell... but a trained eye can tell the difference... the easier way to tell is the packing that they come in... the older version is packed in foam, the new version is in bubble wrap...
we had ran the new version without any problems... the old one suffers bearing problems that leads to conrod breakage...
hope this helps....
HobbyThingzBlk 201-E, Tampines Street 23, #01-118, Singapore 520201. Tel: 65-67828311, HP: 65-97465015. www.hobbythingz.com, team@hobbythingz.com
Regional Sole Distributor for Team Associated, Orbit Electronics, J Concept and PolyButler. Dealer for Tamiya, Kyosho, GS, Proline, Byron, Os Engines, RB, Futaba, Sanwa, KO.....
Please note that we are closed every Tuesday and P.Holiday. Hours are: 12pm-9pm.
Maikaitan is offline   Reply With Quote
Old 03-10-2008, 12:37 PM   #63
buckeye34's Avatar
Originally Posted by Swen View Post
I race for OS, and you can count the balls. It went from a 7 ball bearing to a 9. Not positive on the numbers but they are different in the '07 and up motors. Also, the hump on the bottom where the back plate screws into runs the length of the bottom of the case on the new motors. On the old style it was only long enough to house the screw.
Originally Posted by SkarTisu View Post
Almost, Jon.
Older V-Specs have 8-ball rear crank bearings, 07 V-Specs have 9 ball rear bearings.
here you go maikaitan....
mbx5r
v-spec
jp-3 pipe
hitec 5955tg/steering
ko propo 2367/throttle
m-11
buckeye34 is offline   Reply With Quote
Old 03-10-2008, 11:20 PM   #64
Maikaitan's Avatar
yes... the hump on the crank case is right...
i'm positive about the balls... confirmed that it's from a 10 to a 9.... not 7 to 9...
anyway, if you have the 9, then you are pretty safe....
Old 03-11-2008, 01:43 PM   #65
Registered User
Loop&Roll is offline   Reply With Quote
Old 03-11-2008, 01:45 PM   #66
Registered User
Originally Posted by Kraig Krueger View Post
Kendall, what I am saying is that often in RC racing, racers look at the number of gallons run on a motor as a measure of longevity. This is not an accurate measure when fuel mileage differs. I will give you an example that will help explain this:
These numbers are exaggerated to make it easier to understand. This is not a representation of any company's motor performance, just an explanation of how fuel mileage comes into play.
We will say that each motor drives 1 mile for every 5 minutes driven.
For ease of math we will say we have extra large tanks and they will hold a gallon.
Kendall's motor gets 5 minutes per tank
Kendall's motor will last 10 gallons
Kraig's motor gets 15 minutes per tank
Kraig's motor will only last 5 gallons
Kendall's motor: 5 min/tank *1 tank/gal *10 gal*1 mile/5 min
Distance driven: 50 miles
Kraig's motor: 15 min/tank * 1 tank/gal *5 gal*1 mile/5 min
Distance driven: 75 miles
Even though Kendall's motor went through 10 gallons and Kraig's only lasted 5, Kraig's lasted 50% longer.
Which motor would you rather have?
Kraig
WTF... this is exactly why i put a tacho on my mugen, its done 500k's now!!
Just blew my motor!!!!!!!! playboy Nitro Off-Road 21 05-29-2008 09:02 PM
help! aps dynocharge blew! GAMMACRUSH Radio and Electronics 3 12-25-2007 01:16 AM
engine blew out! rob3412 Rookie Zone 4 04-05-2007 07:04 PM
My engine blew. NEED HELP fable_faiz Malaysian R/C Racers 2 07-29-2006 10:07 AM
GT7 Blew up ratter Electric On-Road 9 02-11-2005 11:09 PM
